Old 06-24-2013, 07:02 AM   #1
Nothing
Drives: FRS
Question Vented hoods and turbos
I thought I had kept an eye out for this but does anyone here with a vented hood have some pics of how this lines up with the turbo and motor? I want to see how rain may be able to get in and look at options to get all this heat up and out of the engine bay.
If this has been discussed, please point me in the right direction and kill this thread.
Nothing is offline   Reply With Quote
Old 06-24-2013, 08:17 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Off the top of my head, I believe @Supermassive has a vented hood and P&L Turbo Kit.
Edit: Yes, he does
http://www.ft86club.com/forums/showthread.php?t=23457
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Nothing (06-24-2013)
Old 06-24-2013, 11:16 PM   #3
Nothing
Drives: FRS
Well I was hoping to see some others post here but it looks like @Supermassive is the only person with one.
I was looking more at these hoods with the vent almost (?) over the gap where our turbos are mounted.
Seibon DV
http://ft86speedfactory.com/seibon-c...od-dv-509.html
Seibon VS
http://ft86speedfactory.com/seibon-c...od-vs-510.html
The DV looks like it has better ventilation since there are two areas for the air to escape.
Either one would be painted to match the car.
Old 06-25-2013, 12:01 AM   #4
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I have the VS hood and it vents the heat really well. The vent basically sits right on top of the the turbo. Here's a pic I took after I I stalled the hood. For reference the drivers side is to the top of the pic and the front of the car is to the right of th pic. The gold at the bottom is the intake pipe and the turbo is towards the top. Hope this helps.
kmbkk is offline   Reply With Quote
The Following 3 Users Say Thank You to kmbkk For This Useful Post:
blackfireball5 (03-03-2014), Murseman27 (06-25-2013), Sportsguy83 (10-11-2013)
Old 06-25-2013, 09:01 PM   #5
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I'm about to cut a giant hole between the engine and radiator in my hood to extract excessive pressure in the engine bay during race conditions. It's more about allowing air to flow through the IC and radiator and then releasing that huge volume of air seen at high speeds. Given how well sealed up the bottom of the engine bay is for aerodynamics I'm seeing a lack of flow through while racing. Hood vents will allow the IC and radiator to work more effectively and you'll also end up with more front downforce.
The aftermarket hoods are vented conservatively which is fine for street guys and will still help substantially.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
charged86 (09-22-2013), wbradley (09-07-2013)
Old 06-25-2013, 10:09 PM   #6
tonyfrs86
tonyfrs86's Avatar
Drives: 2013 raven frs
it seems that all after market hoods are carbon fiber..any aluminum ones or anything or am i going to have to cut up my own hood?
tonyfrs86 is offline   Reply With Quote
Old 06-25-2013, 11:53 PM   #7
Nothing
Drives: FRS
I can't remember if you're back in the country with your car again or not. But can you get a few pics further back for scale? Maybe leave a light from your phone on so it illuminates up from that area? Anything further back showing how the vent and engine line up would help a lot. :happy0180:
Old 06-26-2013, 12:53 AM   #8
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I am back in the country, but on leave in TX for another week. I'll get the pics you requested when I get home!
Old 06-26-2013, 02:47 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thanks,
Phil Grabow
The only real concern I have with a vented hood at this point is sitting in traffic in the rain and getting my turbo blanket and wrapped downpipe wet. I would be willing to cut my OEM hood to add some vents if there was a vendor who made a kit with good directions and templates.
The Following User Says Thank You to King Tut For This Useful Post:
yomny (02-27-2015)
Old 06-26-2013, 03:11 PM   #10
DJCarbine
Thupercharged
DJCarbine's Avatar
What about hood spacers? I know people generally hate them as they leave a gap at the rear of the hood and looks like you just had an accident and didn't mend it correctly....
I would say the chances of anything getting wet underhood are less with hood spacers vs a vented hood though. Would be easy to test real world application with a trip to the hardware store for some nylon/delrin spacers and a temperature sensor
2013 FRS
Vortech V3 11psi
Old 06-26-2013, 04:09 PM   #11
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Would removing this weather strip allow some air to vent, similar to raising the hood?
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
cf6mech (06-27-2013)
Old 06-26-2013, 04:57 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I heard that removing that strip was one of the things the VCMC team did to help with the cooling of their Full Blown kit. I have been meaning to contact them to see exactly what they did.
Old 06-26-2013, 05:08 PM   #13
DJCarbine
Thupercharged
DJCarbine's Avatar
Looks like it might be an alternative that doesn't alter appearance of stock hood, I wonder how big the gap would be compared to a spacer
2013 FRS
Vortech V3 11psi
Old 06-26-2013, 09:54 PM   #14
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
If I remember correctly they just removed that entire plastic piece by the windshield. I'm not sure if that is what's holding the windshield wipers in place though, so removing it probably wouldn't be a good idea for a DD.
campy is offline   Reply With Quote
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 05:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 03:30 AM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 43 07-22-2012 11:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 10:57 PM
