Old 05-30-2013, 12:24 PM   #1
jonbonazza
EL vs UEL headers
I see many people on here prefer UEL headers, but honestly, wouldn't EL be better? Seems to me like the flow would be more even and result in better fluid dynamics.
I am no physicist, though, so I could be way off. :P
jonbonazza is offline   Reply With Quote
Old 05-30-2013, 12:32 PM   #2
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
EL does flow better, UEL gives the boxer rumble which many people like.
Flat Black VW is offline   Reply With Quote
Old 05-30-2013, 12:36 PM   #3
jonbonazza
Ah gotcha. Thanks! Does the EL sound bad or just not as good as UEL? lol
Old 05-30-2013, 12:42 PM   #4
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Different. The EL sounds 'racier'. More like a regular 4 cylinder.
Grimlock is offline   Reply With Quote
Old 05-30-2013, 12:55 PM   #5
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Is there such thing as a audio clip or youtube of a stock 86 with just the uel header? Most clips i find are ones with exhaust and other mods.
Marcoscrdo is offline   Reply With Quote
The Following User Says Thank You to Marcoscrdo For This Useful Post:
Freetime (05-30-2013)
Old 05-30-2013, 01:45 PM   #6
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
Looking for this too
edit - Found it. This is from the linked thread.
http://www.ft86club.com/forums/showp...5&postcount=23
Freetime is offline   Reply With Quote
Old 05-30-2013, 01:52 PM   #7
jonbonazza
That... doesn't look like stock exhaust to me, but it might just be the camera angle.
Old 05-30-2013, 02:09 PM   #8
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
The tips are too round to be stock and the muffler is too shiny to be stock.
Old 05-30-2013, 02:15 PM   #9
Opposed
Drives: 2013 Asphalt FR-S
[ame="http://www.youtube.com/watch?v=W4pExkk_YrQ"]Rev Works UEL Header on Stock Exhaust BRZ - YouTube[/ame]
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
The Following User Says Thank You to Opposed For This Useful Post:
Marcoscrdo (05-30-2013)
Old 05-30-2013, 02:15 PM   #10
FR-S Matt
UEL vs EL has come up several times. Not seeing a very massive difference between tuned UEL vs EL sub 300 whp. Very minor if anything and not noticeable. It comes down to, can you sacrifice anywhere from 3-10 whp (depending on FI or not) for your boxer rumble? That's literally the difference you're going to see running UEL instead of EL.
EL would be a must for the stage 2+ turbo kits pushing above 400 whp or someone who wants to squeeze every ounce of hp they can out of a part. Even then, no one can tell you that you can't run a UEL at that whp level.
The Following User Says Thank You to FR-S Matt For This Useful Post:
WolfpackS2k (05-30-2013)
Old 05-30-2013, 02:25 PM   #11
jonbonazza
Err.. okay, so, dmittedly, I have no experience with H-motors (boxers), but in a typical I4, you would be ditching the header in favor of an exhaust manifold when going turbo... how does this work with a boxer motor since the ports are split into 2s, with each duo on oposite sides of the motor? In a V6 or V8, also with split cylinders, you would twin turbo teh SOB and call it a day, but that would be overkill on this tiny motor.
Old 05-30-2013, 02:31 PM   #12
FR-S Matt
I don't have much experience with them either as this is my first run with one. I've just been comparing dyno charts done between headers. Turbo manifolds are very similar although ones like the P&L Header, or the FA20club manifold is a hybrid header (NA or FI) based on a V-Band clamp that wraps in the front determining where the pipe goes. The longtube design has also produced pretty substantial numbers tuned.
Old 05-30-2013, 02:56 PM   #13
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
UEL (mine is borla :/ ) lose the rumble as soon as you go FI except at idle. Just an FYI.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-30-2013, 03:10 PM   #14
Marcoscrdo
Marcoscrdo's Avatar
Whats wrong with the borla uel header? I felt like it was most popular so felt like i would go for it /shrug
Whats the best one then? Most people ive seen at meets got the borla
4-2-1 vs 4-1 headers Hawk77FT Engine, Exhaust, Transmission 22 04-17-2016 03:29 AM
Headers? BuBlake Engine, Exhaust, Transmission 30 04-22-2014 11:46 AM
Uel vs el which headers do you have and why? Mike86 Engine, Exhaust, Transmission 38 05-16-2013 03:50 AM
Headers tdoggy57 Engine, Exhaust, Transmission 10 01-13-2013 06:09 AM
Headers UEL vs EL Decameron Engine, Exhaust, Transmission 38 08-31-2012 01:00 PM
