| Wheels | Tires | Spacers | Hub Specific topics relating to wheels and tires. |
Drives: Slowly
Light, wide wheels with good fitment
I'm thinking about wheels and could not give a damn what they look like.
Requirements: 17 or 18 inches diameter 9 or 9.5 inches wide Offset around +40 Obviously bore of 56.1 Target weight around 8kg. Anyone know what fits the criteria?
Drives: 86
The problem at this stage is the lack of off the shelf 5x100 wheels for anything bigger than 18x8.
but it's gonna change when the car releases. i guess we should all be patient. i'm planning to go 17 or 18 x 8 front and x 9 rear. not sure what offset will be best due to the limited info released. bore is not an issue as you can just get those hub rings. |
Drives: Slowly
That's all true and obviously why I posted the thread.
There isn't much out there now, but I know there's more than nothing. It's just hard to find the info and if they have to be custom made, I'll have to order them now.
Drives: 86
But the thing is, we don't know how much offset we need to fill the guards. I'd wait till April when the Japanese gets their cars and starts changing wheels.
Drives: Slowly
I could care less about filling guards.
I've had someone measure one and know what will fit, I just have to find them.
Drives: 86
In which case just find a design u like which is within your weight target and order a custom set.
Drives: Slowly
No need. Got the answer I needed over on a Subaru forum.
Registered user
Drives: 99 impreza coupe
#10 |
form follows function
Drives: '95 M3, '07 Si, '13 BRZ
Kosei K1 Racing. No clue on fitment, but it's the wheel to have for e36 M3s.
#11 |
Hot Dog
Drives: quicker than arghx7
Well don't leave us hanging, what did they say?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#12 |
Drives: 2.5 RS daily, Evo 8 track
Location: A little town called none of your goddamn business
#13 |
Because I am considering the BRZ over FRS? I guess you got me
#14 |
Drives: 2000 MR2 Spyder
#15 |
#16 |
They're also crazy cheap. That's kind of the trade-off. Perfect track wheel. Daily driving not so much, but if you don't mind replacing a wheel every so often, it's still the cheapest option for light wheels.
| 10.5" wide tire possible?!? | Xiao | Wheels | Tires | Spacers | Hub | 51 | 04-15-2013 02:28 PM |
| Third brake light...(top mount) | Slide | Cosmetic Modification (Interior/Exterior/Lighting) | 45 | 03-07-2013 08:46 AM |
| Wheel size and fitment | bsclywilly | Wheels | Tires | Spacers | Hub | 48 | 03-27-2012 11:34 AM |
| Wheel fitment | sfwg | Subaru BRZ General Forum | 6 | 10-28-2011 05:33 PM |
| How wide do you think steelies would be OEM? | RegisBou | Engine, Exhaust, Transmission, ECU | 24 | 02-24-2010 02:23 AM |
