Old 05-16-2013, 05:28 PM   #1
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Aftermarket Header help!!!!
Hey guys, so I bought my FRS about 2 months ago and have already installed a Milltek UnRes catback exhaust and put in a drop-in Cosworth airfilter. Also changed the oil (at 1,500 miles) and put in Amsoil and also fitted a drain plug underneath the car. After these modifications, the car feels more alive. BUT I want to take it to the next level (FI is in the future, don't have the funds at the moment) so I'm looking to purchase headers.
As I don't own a car lift (can only put the car on stilts), the passing emissions and CEL all worry me. The CEL doesn't worry me as much because I will eventually purchase an ECUtek that will take care of that. I live in stuck-up California and they are real assholes when it comes to these things. So I want to keep a system that keeps the 02 sensor and doesn't require me to throw on the stock header every 2 years to pass smog. Some companies that I've looked into are JDL, Rev Works, and Borla.
So I'm asking you what's your experience the headers on your car, did you install yourself, and to calm me on any of my many worries above. I'm really excited to modify my car instead of having the ricer-image of only putting an exhaust on the car lol. Thanks guys
chiefshayan is offline   Reply With Quote
Old 05-16-2013, 05:35 PM   #2
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
I ordered JDL UEL headers ETA June to arrive. They are uncatted, which most UELs are but if you are concerned about emissions, consider going a catted header (most at the moment are EL). UEL vs EL really depends on your preference on the typical boxer rumble. As a note of caution if you are planning FI in the future, they will require a new set of headers for turbo setups.
If you are planning to get a stock dyno baseline then see the gains after header and/or tune it may be easier letting the tuner install the header after the first run. I'd imagine it can be done on stands but of course it would be easier on a lift.
hyper4mance is offline   Reply With Quote
Old 05-16-2013, 05:42 PM   #3
hyper4mance
this should also help
http://www.ft86club.com/forums/showthread.php?t=31555
Old 05-16-2013, 05:50 PM   #4
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
I just ordered the P&L header and it has the option of being catted. So far people have said that there are no CELs either.
ScottDRFT is offline   Reply With Quote
Old 05-16-2013, 05:50 PM   #5
chiefshayan
Originally Posted by hyper4mance View Post
Thanks that helped a lot. I think I want to go UEL, the sound is more like a subaru whereas the EL sounds a bit light for me. So you're saying if I want to go FI, I need to replace the stock headers? Makes sense. Are you at all worried about passing smog with the JDL headers? I would love to go uncatted..
Old 05-16-2013, 05:51 PM   #6
chiefshayan
Those look sweet. Any worries of going uncatted and passing smog?
Old 05-16-2013, 06:41 PM   #7
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Yeah that's one of the reasons I went catted, plus the I heard the catted one was a little bit more tolerable as far as the sound goes for a daily driver.
Old 05-16-2013, 07:31 PM   #8
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
They also fit with the vortech kit, and will work with the P&L turbo kit so you won't need to buy a new header.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 05-16-2013, 07:49 PM   #9
Xdragonxb0i
Drives: ex500r
Im running the p&L for about 500miles now
My Car just got a CEL p0420.... im thinking one of the sensors got loose. will check tomorrow
Xdragonxb0i is offline   Reply With Quote
Old 05-16-2013, 07:57 PM   #10
TheSlickOne17
Drives: 07 scion tc 06 Evo 9 mr 10 4runner
I ordered the UEL borla and a bung spacer so my CEL wont come on.
But isn't the law in Cali if you have a new car you smog every 4 years now not 2?
TheSlickOne17 is offline   Reply With Quote
Old 05-16-2013, 08:02 PM   #11
mad_sb
Drives: 2013 Asphalt FR-S
Fa20club.com's header has catted option AND converts to the turbo manifold so if you plan to go turbo in the future you can save 700 or so off the fa20club turbo kit.
Old 05-17-2013, 11:27 AM   #12
hyper4mance
NA headers are not always designed for FI, so just make sure before you buy them they suit your needs in upgrade path. I plan on sticking to NA since the turbo lag for autox does not suit my needs. SC is an option, but id rather spend the money on autox or trackdays for the bike/car.
I'm not sure how emissions is in your area, but most say the cat delete in the header should still pass assuming you have a cat in the midpipe. I'd check with local people according to your state for help.
Old 05-19-2013, 03:59 PM   #13
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Were you able to fix it?
Old 05-19-2013, 07:46 PM   #14
Eyesacky
Eyesacky's Avatar
Drives: DGM BRZ Limited "Freyja" +2 Miatas
I have the Borla UEL. Had a CEL for a few weeks but then it went away.
'13 BRZ + FSTI wheels, Borla Catback and UEL Headers
||)===*(O).==(||
Eyesacky is offline   Reply With Quote
cel, frs, header, headers, modify
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 04:47 PM
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 01:20 PM
What is the best header for my set up? CSI:86 Engine, Exhaust, Transmission 25 05-11-2013 03:36 PM
FS JDL EL Header JDLAutoDesign Engine, Exhaust, Bolt-Ons 8 02-16-2013 04:42 PM
