OEM Audio Plus
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 05-10-2013, 08:03 PM   #1
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
Question Drivetrain slop?
OK this is not a problem or issue, I'm sure the average driver will not notice this but I will describe what I experience in hopes that someone else has noticed and could point me to maybe a part to tighten things up.
Example: When driving a constant 50MPH on the highway with your foot already on the gas, if you let off you can feel a small amount of movement in the drive train below you. And if you let off right there and press the gas again to resume maintaining that 50MPH you will again feel the movement beneath you. It just feels like there is some slack somewhere.
Is this something where a transmission collar is needed for extra support to minimize the movement?
jordanrw260 is offline   Reply With Quote
Old 05-10-2013, 08:09 PM   #2
moto-mike
Tuner
Drives: 335SC BRZ (ret), STI, RB25 S13
Huge issue on this car. You'll want the whiteline subframe and diff inserts to take care of it. Driving them back to back is like night and day. I thought there was some throttle response/delay issue with the ECU at first until I drove a properly tightened up car. Some videos online of the diff movement.
moto-mike is offline   Reply With Quote
Old 05-10-2013, 09:02 PM   #3
86drift
86drift's Avatar
Drives: Toyota 86 GT
I have this too. Most of the slack is in the diff. But there's also some in the CVs.
Don't know if there's a lot you can do about it.
86drift is offline   Reply With Quote
Old 05-10-2013, 09:24 PM   #4
jordanrw260
Can you tell me which item numbers you a referencing from the whiteline homepage? http://www.whiteline.com.au/do_segue...ehicle=2012-ON
Old 05-10-2013, 09:33 PM   #5
Captain Snooze
Because compromise
Captain Snooze's Avatar
Drives: Red Herring
With due respect I beg to differ. I do not know what it is the OP is referring to. Let me rephrase that. I know what it is he is referring to just that I have never been aware of this "problem". Even the OP states "small amount".
Old 05-10-2013, 09:41 PM   #6
MY13FRS
***** Super Senior Member
MY13FRS's Avatar
Drives: 13 FRS
Yup, I had to adjust my driving style for this car. You have to let go of the clutch quick, like you're dumping the clutch, and add throttle. Takes practice, but once you got it, it works. You can't feather the clutch on this car.
MY13FRS is offline   Reply With Quote
Old 05-10-2013, 09:47 PM   #7
mrk1
Drives: Sterling BRZ Ltd
I completely agree with the slop being a problem. On my car I have installed the Whiteline rear subframe inserts (kdt922) and also installed STI engine and trans mounts. It makes a world of difference.
Diff mounts will be soon.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-11-2013, 05:44 AM   #8
mswhong
Yes, I have this issue on my car as well.. the drivetrain slop in this car is terrible but with some bushings and other products (from whiteline or any other company) it should go away
mswhong is offline   Reply With Quote
Old 05-11-2013, 07:05 AM   #9
Captain Snooze
Because compromise
Drives: Red Herring
Could someone please explain what this drivetrain slop is? I really don't know what the complaint is.
Old 05-11-2013, 07:35 AM   #10
mswhong
It's just the drivetrain moving when taking your foot on off the gas.. It's not very pronounced but you can definitely replicate it.
It's similar to when you're driving along a road that has a few bumps and the revs sort of bounce around due to the transmission moving about laterally and longitudinally.
The Following User Says Thank You to mswhong For This Useful Post:
Captain Snooze (05-11-2013)
Old 05-11-2013, 08:22 AM   #11
Captain Snooze
Because compromise
Drives: Red Herring
The problem I have with bumpy roads is trying to keep a constant throttle. That is my foot on the throttle gets bumped around. I think the throttle spring is too light.
(Sorry, off topic)
Old 05-11-2013, 01:16 PM   #12
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
[QUOTE=moto-mike;925858]Huge issue on this car. You'll want the whiteline subframe and diff inserts to take care of it. Driving them back to back is like night and day. I thought there was some throttle response/delay issue with the ECU at first until I drove a properly tighten
Agreed, I went white Whiteline KDT926/Perrin combo + KDT925, HUGE difference, the issue was driving me insane for a while until U I installed all of them.
Bu-Tang is online now   Reply With Quote
The Following User Says Thank You to Bu-Tang For This Useful Post:
jordanrw260 (05-11-2013)
Old 05-11-2013, 01:36 PM   #13
SkullWorks
Drives: SSM LT MT BRZ
You can definitely feel the drivetrain moving around in this car,
It bothers me considerably but I was thinking it only felt so pronounced because I was trying to compare it to my 240 with solid mounted everything and a one-piece driveshaft. In reality it is no worse than any other car, I think the reason so many people DO notice it in this car is the overall characteristic of the car is to be tight, and the drivetrain slop seems a bit out of character for the car, I wouldn't be surprised if the factory left a bit extra in so they could sell us stiffer mounts...ala STi (does TRD offer mounts yet?)
I need to finish my coffee
SkullWorks is offline   Reply With Quote
Old 05-13-2013, 01:19 AM   #14
Turdinator
Seņor Member
Turdinator's Avatar
TRD are doing a range of stiffer bushesfor the 86.
http://www.trdparts.jp/english/86_pe...atestnews.html
And i definitely agree there is a lot of driveline slop in this car.
1974 TA22 Celica
2013 86 GT
drive train slop
Search this Thread:
Advanced Search
Pulled battery for 5 minutes, now massive gas pedal slop post_break Issues | Warranty | Recalls / TSB 9 10-11-2012 01:12 AM
Aftermarket Drivetrain Parts wootwoot Engine, Exhaust, Transmission 0 07-26-2012 05:23 PM
Subframe/Drivetrain Thoughts.... TrackDog Scion FR-S / Toyota 86 GT86 General Forum 12 11-10-2011 11:53 PM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
