Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 04-11-2013, 04:09 AM   #1
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Door speakers upgrade / replacement
Not a full DIY but some links and photos...
Speaker wiring harnesses:
http://www.crutchfield.com/p_1207103...Harnesses.html
Door and dash speaker adapters:
http://www.subaruaudio.net/subaru-sp...nd-scion-fr-s/
DIYs with door panel removal instructions:
http://www.ft86club.com/forums/showt...highlight=door
More photos coming of the speakers and final installation...
mike_ekim1024 is offline   Reply With Quote
The Following User Says Thank You to mike_ekim1024 For This Useful Post:
ThaBigUnit (04-11-2013)
Old 04-11-2013, 10:57 AM   #2
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
cool pics bro?
njccmd2002 is offline   Reply With Quote
The Following 2 Users Say Thank You to njccmd2002 For This Useful Post:
mike_ekim1024 (04-11-2013), YamahaR86 (12-12-2013)
Old 04-11-2013, 11:04 AM   #3
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
well what speakers are you putting in?
Huehuecoyotl is offline   Reply With Quote
Old 04-11-2013, 01:44 PM   #4
mike_ekim1024
I actually don't know how to edit image inline.. so just adding more attachments.
I cut some double sided foam from a roll in half - wish I had single sided sticky foam, but after touching it a bunch it became un-sticky . I used krazy glue to glue the wires neatly to the adapter and the speaker basket so they don't rattle, and yes that is cardboard in the speaker basket holes - I found some thick cardboard, cut it in small pieces and folded it in two. If I didn't use some kind of spacers, the screws wouldn't seat right, or I've have to screw in at an angle.
Using Earthquake VTEK-62Xi because I have an inside connection. They're 2-ohm so plug and play They're not going to introduce window shattering bass, but they are an improvement over stock.
Next up is installation...
Old 05-12-2013, 07:02 PM   #5
mike_ekim1024
A few more photos after finally putting in the both speakers. I used longer sheet metal screws that had the same threading. And yes, that is cardboard I used as washers for screwing the speakers into the adapters. Hey, it works and sounds fine.
mmontes (08-13-2013)
Old 08-13-2013, 04:04 AM   #6
mmontes
Drives: limited brz
How's the sound quality with these speakers?
mmontes is offline   Reply With Quote
Old 08-13-2013, 04:26 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
VTEK just kiked in YO
The Following User Says Thank You to ZionsWrath For This Useful Post:
Jaylyons1 (03-02-2014)
Old 08-14-2013, 01:40 AM   #8
mike_ekim1024
It's the stock head unit and amp so it's not night and day, but there is definitely more bass. And the extra tweets add a little more crispness. With a new head unit it would probably be more significant.
Boofneenee (11-01-2014)
Old 08-23-2013, 03:26 PM   #9
PatrickSAN
Drives: SWP GR 5DR
Nice job on this.
PatrickSAN is offline   Reply With Quote
Old 08-27-2013, 03:04 PM   #10
White64Goat
Does adding the adapter cause the speaker to contact the backside of the door card now? Factory speakers make the speaker opening/knee pad to vibrate, does this also cause the vibration?
Old 08-27-2013, 03:17 PM   #11
PatrickSAN
Drives: SWP GR 5DR
The speakers do not come in contact with a 3/4" adapter.
The vibration is due to the sound waves hitting the inside of the door panel/door card and/or the knee panel. The lower and louder the bass the more vibrations that they will generate (speaking in generalities, of course).
Any speaker will do this, and it is not a property of a particular speaker or setup. Adding deadener to the surfaces can reduce the vibrations.
The Following User Says Thank You to PatrickSAN For This Useful Post:
chanomatik (04-21-2014)
Old 09-02-2013, 01:51 PM   #12
White64Goat
Did you install foam baffles (cup) behind speakers to keep water out of the speaker?
The Following User Says Thank You to White64Goat For This Useful Post:
Kriser (07-30-2015)
Old 02-17-2015, 07:00 PM   #13
TB9
Drives: 2014 Subaru BRZ Limited CBS
Update?
TB9 is offline   Reply With Quote
Old 02-17-2015, 08:29 PM   #14
PatrickSAN
Drives: SWP GR 5DR
Originally Posted by TB9 View Post
Update?
What sort of update are you looking for? I don't think that he used baffles but the speakers fit with the adapters from subaruaudio.net .
Search this Thread:
Advanced Search
door speakers not working number1Tango Electronics | Audio | NAV | Infotainment 21 08-27-2014 09:40 AM
Thoughts on the BRZ radio/gps/speakers - Should we upgrade? dorkymork Electronics | Audio | NAV | Infotainment 21 01-30-2013 12:04 PM
Best drop-in replacement speakers RYU Electronics | Audio | NAV | Infotainment 4 10-10-2012 02:15 AM
Front door speakers. Calum Electronics | Audio | NAV | Infotainment 5 08-11-2012 04:49 PM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 02:57 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
