follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Scion FR-S / Toyota 86 > Scion FR-S / Toyota 86 GT86 General Forum
Old 12-31-2011, 06:36 PM   #177
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (WRB)
Laguna Seca
Deslock - 1:45.647 - Logitech G27 (MT w/ paddles)
Tsukuba
Deslock - 1:07.135 - Logitech G27 (MT w/ paddles)
My times with the clutch are about 0.5 sec higher.
Was gonna give it a go last weekend, but I cut my left hand pretty badly, so I wasn't able to play until today. Since I don't have time to learn Nurburgring before the deadline, I only raced the two shorter tracks.
I could shave another second or two off Laguna Seca with more practice, but Tsukuba has me stumped... I just don't get that track.
Deslock is offline   Reply With Quote
Old 12-31-2011, 06:41 PM   #178
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
If i improve my time can i still post it or the one i posted the final count?
4agze is offline   Reply With Quote
Old 12-31-2011, 08:20 PM   #179
RaceR
Drives: 2010 Cooper S, 74 Beetle
Originally Posted by merlin2111 View Post
You are running your laps with a stock car though right? not the 408 bhp version?
Updated!
Yeah, stock of course. Meant to write 208bhp/413pp. Messed up the first number in the bhp part...
For the record, Ill highly doubt the GT86 will do above 400bhp. ichitaka05 had a fully tuned and probably maxed out car at 393ps. That would be around 387bhp.
RaceR is offline   Reply With Quote
Old 12-31-2011, 08:57 PM   #180
Franisco
Franisco's Avatar
Drives: D31a
Nur- 8:54.058
Tsukuba- 1:06.852
Both with Dualshock
Originally Posted by White Comet View Post
No one's buying a Yaris to wind the piss out of it and possibly slam into a mountainside pretending they're the ultimate Tofu delivery person.
Franisco is offline   Reply With Quote
Old 12-31-2011, 10:37 PM   #181
RaceR
Originally Posted by Michel View Post
Nice lap !
A few tips :
- Don't keep it in the higher rpm's so long, just shift..
- No need for 2nd gear in a lot of corners
- @ 3:44 , that's a very important corner as it can make or break a good laptime since your topspeed will be much higher all the way uphill. Your topspeed in this section is 175km/u, for me it's 186km/u.. that's a lot.
- cornerspeed @ 6:32 is about 10km/u down
- @ 7:18 don't brake.. just lift throttle for a split second..makes a huge difference.
Great analysis on a good lap. Ill add.
- Do oil change and drive some more miles.. If you have not done it. Some horses makes a difference on Nordschleife.
- As pointed out with examples, go for high exit speeds before long straights. This is very important on Nordschleife. Optimizing cornering entry is 2. priority.
- Your line and use of track width and curbs are very good. But at times you can be even more aggressive on the curbs. This is GT5, not real life, so your car will be fine. ...Especially at 2.06-2.10 you can even use more than the red and white curbs for better exit speed.
- At 1.26 your speed were between 194-199km. My replay showed 214-220 trough same corner, and corner entry at 223. You do not have to brake here. Only lift a little..
Your gear changes looks a lot like mine I think. Maybe I too should shift gear sooner/not hold the gear for that long in some cases. Ill try some day. But I max out most gears pretty good. I am losing some torque, but max output is at 7000 rpm. Bhp is at is highest in the 6500-7500 range when looking at the output curve. Id rather stay in the 7400-7550 range than dropping down in the 5900-6400 range.. Ill try to do my average change just a tad sooner in some cases and see if it makes a difference..
Michel, do you sometimes/often shift before seeing the "rpm-bar" getting red?
Old 01-01-2012, 07:28 AM   #182
Michel
Nordschleife Addict
Michel's Avatar
Drives: '92 SW20 Turbo
Always, except on the Döttinger Höhe, I keep it in 5th gear all the way up untill Antoniusbrücke..then I shift to 6th gear.
Michel is offline   Reply With Quote
Old 01-01-2012, 07:47 AM   #183
TurboMan
Drives: none
tnx for tips and advices. i really laughed when you said about curbs i avoided them because i thought they actually slow you down a bit and they can throw you out of balance and off the track ...
also i really didnt even thought about corner exit on long straights are so important ...
tnx again to you and michel
TurboMan is offline   Reply With Quote
Old 01-01-2012, 10:32 AM   #184
Deslock
Deslock's Avatar
Only TWO more days left for these courses!!! Look for a poll for next months track!
The poll for January's track that merlin2111 mentioned:
http://www.ft86club.com/forums/showthread.php?t=3068
Old 01-01-2012, 08:29 PM   #185
RaceR
Thanks for this thread merlin.
Good fun posting times..
For all the people that would like do keep driving the GT86 on Nordschleife. I have made a new thread with 8 different leaderboards/challenges on that track.
Including stock, tuned and drift leaderboards.
http://www.ft86club.com/forums/showthread.php?t=3091
Old 01-01-2012, 09:39 PM   #186
Deslock
Deslock's Avatar
Originally Posted by lynk26 View Post
If anyone knows how to transfer ghost files, let me know, because when I export the replays to the xmb and then save it on my thumb drive, I get a folder with a bunch of different files. I would think I'd only need the replay data, but I'm not 100% sure.
Tonight, I googled and found out how to import and export replay files via USB stick. Following instructions at http://www.gtplanet.net/forum/showthread.php?t=176743, I imported and watched some replays from http://www.gtplanet.net/forum/showthread.php?t=235888.
To answer lynk26's question, after you export the files, you'll get the following folders:
PS3 > SAVEDATA > BC#S#####-RPL### (with 5 files)
Out of curiosity, I opened the smallest file (PARAM.SFO) with a text editor and it has the course, car, driver, and date in it.
I zipped up that folder tree for my 1:45.647 Laguna Seca ghost run and attached it to this post (because I used OSX, there is also a __MACOSX folder in the zip... you can ignore it). Can someone extract the PS3 folder tree and follow the step in the link above and see if my replay successfully imports?
The naming convention I used:
[car]-[psn_user]-[track]-[date of race yyyymmdd].zip
Also, can you guys that attained fast times at Nurburgring and Tsukuba follow the steps and post yours?
Old 01-02-2012, 02:32 PM   #187
Redliner
Redliner's Avatar
Drives: Peugeot 206; Suzuki GSR600 k8
Hi !
My time for the Nürburgring-Nordschleife: 8:28.201 (dual-shock)(with oil change)
But one question: are you all driving with the Analog sticks or with the digital-buttons? Cause I can't play with those sticks and wodering how especially Dragonitti can drive soo fast xD Anyway, lots of respect for the fast guys!
Redliner is offline   Reply With Quote
Old 01-03-2012, 12:54 PM   #188
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
times for these courses are closed if you would like to keep racing on the nord then hit up RaceR thread. We have a january thread going now for a new track.
merlin2111 is offline   Reply With Quote
Old 01-04-2012, 11:29 PM   #189
Boxer 86
I ♥ My Spinning Triangles
Boxer 86's Avatar
Drives: 1989 Mazda RX-7 GTU
Personally, I'm going to call BS on anyone that ran faster than an 8:20 on the ring. There's no way it can happen with the car 100% stock. I have been doing laps and pushing as hard as I can and I can only muster up about 8:25.5, and I know I'm not the fastest at all, but I do not see 8:18 or anything less than that being possible on a stock setup, and especially on a dual shock. I want to see videos of the laps that are below 8:20 before I even begin to believe them. And it would have to be the data logger laps with the lateral and longitudinal g-forces and the rpm vs speed data on there to prove SH tires and no eninge/trans mods. Even upgrading the flywheel, clutch or driveshaft will be noticed in the graphs. The only thing that would be hard to detect would be an upgraded LSD and the glass and chassis stiffness. And to get times that low, some of those things have to be tampered with. If someone can prove indefinitely that nothing but the completely stock car was used, then I will rest my case and admit I was wrong but until then, as I said, BULLSHIT.
Lover of true sports cars.
I drive an '89 FC, and wish to own a BRZ
Visit my tumblr, and follow my basic yet interesting car life.
Boxer 86 is offline   Reply With Quote
Old 01-05-2012, 01:44 AM   #190
RaceR
EAT YOUR WORDS!
In this case I will not even bother with the DS3 excuse..
Ill try to post some evidence (downloadable replays) in my Nordschleife thread to help out the slower guys..and skeptical people like u...
Old 01-05-2012, 01:51 AM   #191
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: '00 Subaru 2.5RS
When did you became god of GT5? There's a ton of better driver than you, so chill out
ichitaka05 is online now   Reply With Quote
Old 01-05-2012, 08:21 AM   #192
Kiwi
Drives: Volkswagen Golf GTI
Boxer 86
Getting under 8:18 is definitely possible with a stock car.
Here is a time I've done with a complete stock car with an oil change.
This was done with a wheel, but I know that even ds3 drivers are able to get fast times with practice.
I'm pretty sure that I'm not the fastest person ever but I think it can be said that practice makes perfect.
Kiwi is offline   Reply With Quote
Old 01-05-2012, 09:27 AM   #193
Dragonitti
at slow guy complaining about being slow
Old 01-05-2012, 11:56 PM   #194
Boxer 86
Boxer 86's Avatar
Lol I never said I was god, I was just so dumbfounded how someone could get the car around so damn quickly! Like I said if I was proved wrong I would eat my words. Maybe I just had a rant because I posted that after doing lots of laps and not coming up with any better line or driving style to make me faster and I was just angerfied.
I started thinking after I posted it that I sounded like a, in the words of james may, ****.
competition, gt5, stock
Search this Thread:
Advanced Search
POST YOUR FASTEST GT5 NURBURGRING TIMES.... FT-86GOD Other Vehicles & General Automotive Discussions 96 07-15-2012 11:45 AM
0-60 times from video (auto) ? carbonBLUE Engine, Exhaust, Transmission, ECU 18 12-09-2011 11:20 PM
Official Production GT86 Photos old greg Photos, Videos, Wallpapers, Gallery Forum 30 11-27-2011 01:35 AM
Stock or JZ? Samdajiggaman Engine, Exhaust, Transmission, ECU 62 05-25-2011 05:12 PM
GT5 tsukuba times (FT-86) OldSkoolToys Other Vehicles & General Automotive Discussions 60 04-26-2011 09:35 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
