follow ft86club on our blog, twitter or facebook
FT86CLUB.COM
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Wheels | Tires | Spacers | Hub
Wheels | Tires | Spacers | Hub Specific topics relating to wheels and tires.
Old 05-13-2012, 10:04 PM   #1321
mottor
mottor's Avatar
Honestly if I lower it at all it'll only be like an inch or an inch and a half. What do you mean by tuck? Example?
mottor is online now   Reply With Quote
Old 05-13-2012, 10:29 PM   #1322
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Drives: 2011 Subaru WRX
Rears tucked
No but seriously, The natural arc of the suspension wants to carry the wheels inwards (toward the center of the car When looking from the front or rear). Lowering the Car and having the car sit in a different position on the suspension arc effectively makes them tucked..or sunken in. The other factor is a small optical illusion that happens when a car is lowered vs. regular height. If a car has 3 inches of wheel gap, and the edge of the tire sits an inch inside of the wheel well, it won't look so tucked, because of the excessive wheel gap. Lower that same car 2.5 inches, to the point where there's 1/2inch wheel gap and keep that same inch of tire to inner fender clearance, the wheel will look much more tucked.
If you're going for a certain Flush/semi-agressive look. Always Lower to desired height first, THEN get wheels. You'll get optimal results that way
Here is an Civic Type R with wheels that are tucked.. or conservative.
Heres an MR2..with what most would say is TOO aggressive
Past to Present
CoryUyede is offline   Reply With Quote
Old 05-13-2012, 10:32 PM   #1323
oldskule
oldskule's Avatar
Drives: '05 Mazda3
Basically meaning when the wheel isn't pushed out enough towards the fender (not flush enough). A good example is Pekingduck's car, I believe he's lowered on stock wheels. Specifically the rear wheel.
oldskule is offline   Reply With Quote
Old 05-14-2012, 12:03 AM   #1324
mottor
mottor's Avatar
Ahhh yeah, I know what you mean, just didn't know the word for it. Any idea what width/height would be necessary to keep it from looking like that? (Not sure if this has been covered already).
Old 05-14-2012, 12:10 AM   #1325
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Your "flushness" is a factor of both width AND offset. One number is meaningless without the other
Past to Present
Old 05-14-2012, 12:17 AM   #1326
mottor
mottor's Avatar
Yeah, just figured that one out. I'm looking some more for something with either less offset or more width or a combination (like 17x8 and +35 maybe). Thanks for the lesson.
Old 05-14-2012, 12:39 AM   #1327
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
For the sake of keeping steering geometry true. Its best not to veer too far away from stock offset. +45-+40 is fine. going to the low 30s isnt ideal really. Something slightly more aggressive would be like a 7.5 inch +45 . Very common sizing. Your wheels will stick out 9-10mm more. You could go semi aggressive and and do a 8 or 8.5 +45. This will stick out about 15 or 21mm more. Lower the car first or wait for other members and see what fit you like from others experimenting
Past to Present
Old 05-14-2012, 12:51 AM   #1328
mottor
mottor's Avatar
Duly noted. And that's the plan anyway is to wait and see what others' results are. OZ Allegeritas are pretty nice, though I may want something a bit more unique. Guess we'll see.
Old 05-14-2012, 02:04 AM   #1329
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
I guess i'm lucky, I've got a Set of 5x100 18x8.5 +48's i've got sitting in the Garage that i'm going to Test fit on the BRZ, that'll give me a really good idea what i need for a perfect fit
Wheels CAN be a fairly expensive purchase, let other people figure it out =p
Do it once and do it right.
Past to Present
Old 05-14-2012, 09:52 AM   #1330
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: 97 ITR, 00 GS-R, 96 GS-R Race Car
It'll come down to clearance on both sides. There seems to be PLENTY on the outside, but we don't know about the inside.
-Dave
97 Integra Type-R, 00 Integra GS-R, 96 Integra race car and a 2013 BRZ-L!
Old 05-14-2012, 11:04 AM   #1331
civicdrivr
Lightness is a sickness
civicdrivr's Avatar
Drives: 03 Acura CL-S6 & 13 Scion FR-S 6MT
Well, my friend just posted this:
That was a 15x7 Rota that was on his Civic. He was doing about 30mph one a side street when it happened. He said he could barely contain his laughter as the barrel of the wheel rolled down the block and into someones yard
2003 NBP Acura CL-S 6MT, very very sleepy, 1 of 480
2013 FR-S 6MT, Asphalt, First 86
civicdrivr is offline   Reply With Quote
Old 05-14-2012, 11:07 AM   #1332
Dave-ROR
Site Moderator
Dave-ROR's Avatar
That looks like an impact for the rim to have that damage.
-Dave
Old 05-14-2012, 11:11 AM   #1333
igorot
Sneakerhead
igorot's Avatar
Drives: 2003 Honda Civic Si
Yeh, there has to have been previous damage to just go off like that
igorot is offline   Reply With Quote
Old 05-14-2012, 11:50 AM   #1334
Duff_man
Duff_man's Avatar
Drives: Ultramarine FR-S
I'll prolly wait until next summer to buy a fancy set of wheels and tires( RPF1 or OZ alleggerita hlt most likely). But for now I'll keep it on stock wheel and tires, but since I really hate painted/machined finish on stock wheel, I'm going to order a few cans of matte black or white plastidip and give them a bit of a facelift
Duff_man is offline   Reply With Quote
Old 05-14-2012, 11:04 PM   #1335
SmartedPanda
SmartedPanda's Avatar
Drives: Toyota Camry '92
I'm cheap/broke, any rims that fit the stock BRZ tires?
SmartedPanda is offline   Reply With Quote
Old 05-14-2012, 11:16 PM   #1336
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Question or statement?
Any 17x7-17x8 with approx 40-45 offset should be fine..
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post:
TuxedoCartman (05-15-2012)
Old 05-14-2012, 11:40 PM   #1337
dabocx
dabocx's Avatar
Drives: Scion FRS
SSR type f in 18X8.5 or 17X8.5 both are +44 in a square setup.
Would 245s be possible on all 4 corners with this setup?
dabocx is offline   Reply With Quote
Old 05-15-2012, 03:04 AM   #1338
blags
Drives: Toyota 86
245's should fit
blags is offline   Reply With Quote
Old 05-16-2012, 02:34 PM   #1339
mines13
FT86Club Official Vendor
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
I was actually considering on doing the Type F 17x8.5 fitment, I sold a set of these wheels to a customer at my old place and really liked them.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere." -Colin Chapman
My build thread
mines13 is offline   Reply With Quote
Old 05-16-2012, 03:14 PM   #1340
M-17
Lone Wolf Status
M-17's Avatar
Drives: 09 Legacy to ?? BRZ
Damn pot holes. At least these people found something good about them.
I'm At War With The World Cause I.. Ain't Never Gonna Sell My Soul, I've Already Made Up My Mind, No Matter What I Can't Be Bought or Sold...
M-17 is online now   Reply With Quote
The Following 2 Users Say Thank You to M-17 For This Useful Post:
civicdrivr (05-16-2012), Future (05-16-2012)
Old 05-16-2012, 10:51 PM   #1341
kanundrum
Drives: 2013 Whiteout FR-S
kanundrum is online now   Reply With Quote
Old 05-16-2012, 11:51 PM   #1342
igorot
Sneakerhead
igorot's Avatar
doesnt fit well at all imo
Search this Thread:
Advanced Search
How to embed a YouTube video in a post ichitaka05 Site Announcements / Questions / Issues 34 03-13-2013 12:05 PM
Any news or updates for Oz post here Calais AUSTRALIA / NEW ZEALAND 92 07-28-2011 05:55 AM
Post your Desktop Ricepuddin Off-Topic Lounge 112 05-06-2010 03:48 PM
Post your Workspace. Ricepuddin Off-Topic Lounge 1 11-25-2009 07:52 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
