follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
Rexpeed
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes
Suspension | Chassis | Brakes Relating to suspension, chassis, and brakes.
Old 01-23-2013, 08:31 AM   #1
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Anyone installed Whiteline KDT924?
Has anyone installed the Whiteline KDT924 yet?
Keen to know what it does i can't tell from the whiteline pictures.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-23-2013, 08:52 AM   #2
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
I haven't installed them, but pretty sure they're diff mount bushings?
Walldodger is offline   Reply With Quote
Old 01-23-2013, 09:16 AM   #3
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
They are not available yet in the USA.
They replace the entire rear deferential mounts.
The two black mounts in the rear subframe seen here.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
DriftEightSix (01-23-2013)
Old 01-23-2013, 10:24 AM   #4
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Send a message via AIM to Ricepuddin
It's suppose to prevent some movement in the rear diff, this movement results in a negligible amount of drive train loss. I know the 2008–2010 WRX rear diff movement was so bad you could feel and hear it hit the bottom of the car under heavy acceleration. I had these (well white line diff inserts) on both my 2009 and my 2011 WRX, the 09 needed them the 11 didn't.
My advice is, unless you notice a large about of shift in the drive train while accelerating (other than in the transmission), I'd avoid these. What you gain isn't worth the increase in NVH
Sent from my Nexus 7 using Tapatalk HD
Ricepuddin is offline   Reply With Quote
The Following 2 Users Say Thank You to Ricepuddin For This Useful Post:
DriftEightSix (01-23-2013), ProjectD (01-24-2013)
Old 01-23-2013, 10:29 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
id install the rear cross member bushings before doing these
Old 01-23-2013, 10:56 AM   #6
IMOA
Drives: 86 GTS
The other option is the KDT925 kit. This is an insert kit like the KDT922 subframe inserts for both the front and rear diff bushes. Not as solid as complete bush replacements but generally a much better NVH tradeoff (and if they aren't they're easy to remove). These are meant to be shipping within a couple of weeks.
IMOA is offline   Reply With Quote
The Following User Says Thank You to IMOA For This Useful Post:
Old 01-23-2013, 04:35 PM   #7
DriftEightSix
Pegasus White
Drives: 86
Yeah I have a set of KDT922 waiting to go in. I was thinking if these were worth while improvment I was going to hold off installing KDT922 and install both at the same time. It sounds like I might just go an install the KDT922's and wait further reviews of KDT924's
Thanks for all your feedback.
Now to just wait for the whiteline LCAs
Old 03-08-2013, 11:19 PM   #8
Racecomp Engineering
Yes installed KDT924 today ( INSERTS).
Full review shortly.
Old 03-09-2013, 04:51 AM   #9
86drift
86drift's Avatar
Drives: Toyota 86 GT
I've had KDT922 and KDT925 for the last few months.
Can't say I really noticed the crossmember inserts but the diff inserts are very noticeable.
With all diff inserts installed I found the cluncking from the driveline was too loud and was worried about placing extra shock loads on the drivetrain.
After testing different combos I found that if I installed the inserts on 2 of the 4 bushes it was a good compromise.
86drift is offline   Reply With Quote
Old 03-09-2013, 04:57 AM   #10
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
who sells these today, quanto costo?
Huehuecoyotl is offline   Reply With Quote
Search this Thread:
Advanced Search
Installed the Whiteline transmission bushing(no pics sorry) gmookher Engine, Exhaust, Transmission 9 06-27-2013 02:30 AM
KW V3s don't fit Whiteline COM C top hats eleu2166 AUSTRALIA 46 05-13-2013 08:52 AM
Installed the Whiteline crossmember bushing(no pics sorry) gmookher Suspension | Chassis | Brakes 10 01-26-2013 03:00 PM
Whiteline Performance 86drift Suspension | Chassis | Brakes 44 10-14-2012 06:07 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
