DIY (Do-It-Yourself) Guides For all DIYs. |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
DIY - Master Cylinder Brace - Grimmspeed
Hey all. Houston86.com back with another DIY. Here is how to install most Brake Master Cylinder Braces. Most of the designs I've seen use these mounting points.
Normally, the firewall supporting the brake booster and master cylinder flexes while braking. You have to waste a certain amount of energy in that flex before energy is used for braking. This brace removes the flex improving response. Feedback + Definitely does its job - firms up the pedal, brakes respond sooner. From feel, I think the pedal travels 40% less than before. Good bit of kit + Mechanically simple, does not interfere with strut tower braces. + looks the part. I like the powder coated mild steel + Always good feeling to know its made in the USA Thanks @GrimmSpeed for making this and providing excellent support. Matt was very professional when I called him questions about the instructions. Definitely categorize as a high quality human. Product Shots ![]() 20121101-GrimmspeedMCB-01 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCB-02 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCB-03 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCB-04 by VictorN07, on Flickr DIY It is an easy install, just wanted to make sure all doubt is removed with some good pictures. It took longer to setup and take pictures than to do the actual mechanical work. This guide is intended to supplement the official instructions. As always we are not responsible for damage to you or your vehicle. Be safe. ![]() 20121101-GrimmspeedMCBDIY-01 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-02 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-03 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-04 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-05 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-06 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-07 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-08 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-09 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-10 by VictorN07, on Flickr ![]() 20121101-GrimmspeedMCBDIY-11 by VictorN07, on Flickr
The Following 19 Users Say Thank You to F1point4 For This Useful Post: | amram (03-28-2014), cbryant514 (06-09-2017), DocWalt (11-10-2014), Firestorm_86 (09-09-2014), Flow (08-09-2014), FriedRicr (04-08-2014), gmookher (11-02-2012), GrimmSpeed (11-02-2012), GT86_PRAGUE (01-23-2015), Hanakuso (11-02-2012), jimmy4thenguyen (09-13-2013), kwood9000 (11-01-2012), MasonL1997 (07-21-2016), mezdup (04-13-2013), normancw (03-24-2013), RazBRZ (11-02-2012), RehabJeff86 (09-25-2013), rookie (09-17-2016), Tristor (02-22-2018) |
Professional Smartass
Drives: White Out FRS
That was fast. Looking good!
The Following User Says Thank You to post_break For This Useful Post: | F1point4 (11-01-2012) |
Drives: 1995 Acura Integra GS-R
I like how you guys come out with a DIY of all the stuff I've got planned to do.
The Following User Says Thank You to xn7485 For This Useful Post: | F1point4 (11-01-2012) |
Nice write-up. I just got mine today and will be installing this weekend.
Photo Specialist
Absolutely you may. Appreciate you asking first
yeah great write up
Drives: Scion FR-S
on my frs there is a bracket holding electrical wires where you say there is only a sticker. what do I do with that bracket?
#9 | |
Matt Beenen Engineering |
#10 |
Drives: Toyota GT 86
Just installed it today on the AT car. Was also puzzled initially when found some "odd" harness which is not mentioned in the manual but installed the brace anyway - the "additional" harness just rests quite comfortably on top of the MC brace body. Doesn't looks as it even requires any additional bracket. Whould be nice mentioning this point in the manual for AT users though so that they are not puzzled as me today
#11 |
Here is how the place for installation looks on AT cars, the bracket and after installation.
The Following 4 Users Say Thank You to Efferalgan For This Useful Post: |
#12 |
Drives: Whiteout FRS
just installed mine, Thanks for the write up!
#13 |
Drives: tornado Grey Manuel
do you have them in RH drive?,,, otherwise I'll be making it from scratch which will be costly in regards to time and resources! and wont look as sweet as yours
#14 | |
Tags |
brakes, diy, grimmspeed, master cylinder brace, stopper |
Cusco FSB with master cylinder brace - A heads up for AT owners | CircuitJerk | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 03-15-2014 07:25 AM |
Master Cylinder Brace Development - Any Interest? | GrimmSpeed | Brakes, Suspension, Chassis | 411 | 05-14-2013 05:04 PM |
