Old 10-29-2012, 02:17 PM   #1
doggy
doggy's Avatar
Drives: Scion FRS Firestorm MT
Toyota logo instead of Scion on the Airbag? YES please :)
Did what i wanted to do from the first day i got my FRS I aint wanted 86 airbag cuz its expensive - and to be honest - looks worse then FRS / SUbaru one - cuz logo is just pressed in instead of normal one...
Soooooooooo
I jumped to my local junkyard - and cut Toyota logo from Toyota Corolla airbab along with background. Got home - removed it from the plastic / rubber background - and found out that Scion logo is smaller then Toyota sign... Hmmmm
I removed Scion logo from airbag, and started cleaning place for the new logo background. Used my dremel with sanding head to clean out all the unesesary plastic, and to make surface clean and flat.
After sanding down scion logo background - it was time to trim down Toyota logo back cuz it was a bit too thick. So sanded it down as thin as posible to make new Toyota logo sit flush with the surface.
Sanded Toyota back as flat and thin as posible:
Once got everything even and flush - used some superglue to glue backround in place.
Once background is glued - i did the same with the Toyota logo Its sitting nice and flush now.
All the work took me like 30 min And its well worth it over buing 86 airbag
Will get better pics once i put back my interior:
doggy is offline   Reply With Quote
The Following 36 Users Say Thank You to doggy For This Useful Post:
Asphalt~86 (01-08-2013), avusblue (10-31-2012), BabaYaga (08-29-2014), calis5nest (10-30-2012), Carban (01-24-2013), charged86 (03-30-2013), danthedirt (10-29-2012), enjoi23 (12-12-2012), Enraged21 (04-04-2013), Freeman (02-19-2013), Gixxersixxerman (04-29-2013), idreamofdrifting (01-28-2013), Jeff86 (11-29-2012), jstans84 (02-06-2013), Khalis (10-31-2012), ML (10-29-2012), MmmHamSandwich (04-28-2013), mrha (10-29-2012), nataku (02-26-2013), redKnight (01-08-2013), Retro86 (02-05-2013), RidetheTran (10-31-2012), russv (10-30-2012), sbxjap (01-27-2013), shawnperolis (04-19-2013), SkAsphalt (09-04-2013), Sportsguy83 (10-30-2012), Starkiller (05-26-2014), SubarooMike (10-29-2012), tbwoodlee (12-24-2012), Touge Monster (03-05-2013), TuxedoCartman (10-29-2012), xpicer (12-13-2012), Yruyur (10-30-2012), Zaku (03-02-2013), zohare (02-01-2013)
Old 10-29-2012, 02:19 PM   #2
Celica00
Celica00's Avatar
Drives: 86
does the cover just pop off? i'm a little hesitant to try
Celica00 is offline   Reply With Quote
Old 10-29-2012, 02:25 PM   #3
doggy
doggy's Avatar
By cover what do you mean? Airbag it self is pretty easy to take out, but removing Scion logo is another story...
Old 10-29-2012, 02:30 PM   #4
JDMenrique
DEEEERP
JDMenrique's Avatar
it looks like you did a good job. it may be a little too invasive for me to try but i definitely like the badge swap!
JDMenrique is offline   Reply With Quote
Old 10-29-2012, 02:31 PM   #5
CBR600RR
Drives: Raven Black
How did you remove the Scion logo?
Old 10-29-2012, 02:32 PM   #6
JDMenrique
DEEEERP
JDMenrique's Avatar
i also couldnt help but to notice that your dash is pulled apart... any plans?
Old 10-29-2012, 02:33 PM   #7
doggy
doggy's Avatar
Flat screwdriver (thin) lift one end of the badge - and use sharp knife to cut 'legs' that are on the sign Badge is rubber like - so its easy to cut all those 'legs'...
Well- soon will post what im up to gauge pods are already done - now working on CF dash pieces that will be up for sale...
The Following 2 Users Say Thank You to doggy For This Useful Post:
jstans84 (02-06-2013), SkAsphalt (10-30-2012)
Old 10-29-2012, 02:55 PM   #8
jarviz
jarviz's Avatar
Drives: Raven FRS MT
wow looks amazingly clean! good job!
jarviz is offline   Reply With Quote
Old 10-29-2012, 03:01 PM   #9
SubarooMike
SubarooMike's Avatar
Drives: Subaroooo
I looks truly amazing. Fantastic work! A+++
SubarooMike is offline   Reply With Quote
Old 10-29-2012, 03:28 PM   #10
ALbadboy
ALbadboy's Avatar
Drives: 2013 Subaru BRZ Limited (WRB MT)
Very nice work!
ALbadboy is offline   Reply With Quote
Old 10-29-2012, 03:49 PM   #11
Asphalt~86
Drives: Asphalt AT
What sort of glue did you use? My only concern would be 1. Having a toyota emblem embedded in my head in the vent of an accident. 2. It falling off while I am cruising around with someone and be that cheap guy
If the above questions or answered I am totally doing this.
Asphalt~86 is offline   Reply With Quote
The Following User Says Thank You to Asphalt~86 For This Useful Post:
20valvewynn83 (01-25-2013)
Old 10-29-2012, 04:31 PM   #12
doggy
doggy's Avatar
Airbag - once deploing - is ripping apart and piece with the logo ussualy folds down, so even if the logo flyes off - more of the chance to find it in your pants pockets Glue im using - is hard to rip off with screw driver or plies... So... As airbag cover / logo pads are made from rubber like plastic - there are lots of options for the glue to use on them, as im located in different country - it would be hard for me to recomend something...
Old 10-29-2012, 04:33 PM   #13
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Best job I have seen done at this so far. Looks great.
jadewbj is offline   Reply With Quote
Old 10-29-2012, 08:17 PM   #14
Shazbot
Shazbot's Avatar
Could you show how you pull the Cover off the steering wheel. I just don't want to bust any clips, or rip something as I am trying to unseat it.
Looks great!
Shazbot is offline   Reply With Quote
86 Airbag installed! Trojan_SC Cosmetic Modification (Interior/Exterior/Lighting) 218 02-09-2015 04:45 AM
WTB/Trade for GT 86 airbag Lawnik Interior Parts (Incl. Lighting) 0 09-30-2012 10:47 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-13-2012 12:46 AM
Question about side airbag Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 11 01-30-2012 08:02 PM
