ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Old 10-12-2012, 06:48 PM   #1
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
500 Mile - Complete fluid change
We hit 500miles today, and decided to do a complete fluid change before we hit the track this weekend.
Some of the goods we used.
Removed the OEM oil filter with K&N high performance filter.
The filter is slightly taller by about 1/4"
The oil was fairly clean, with no unusual contaminants. The magnetic drain plug did a good job collecting small particulates.
We used exactly 5.5 quarts of Amsoil 0w20.
Remove the Undertray to access the transmission.
Remove drain and fill plugs:
Transmission had a good amount of particulates that came out...normal for a new tran. Oil was dark brown still translucent.
Helps if your trans is warm for the fluid to drain easily.
We used about 2.6 quarts of Redline MT90
Next is the rear diff.
Also helps here to warm up the fluid to drain more easily.
You can see how much small particulates collected on the magnetic drain plug.
We used about 1.25 quarts of the Motul Gear 300
.....ready for the track!
Touge Factory is offline   Reply With Quote
The Following 6 Users Say Thank You to Touge Factory For This Useful Post:
chucky12012 (10-15-2012), einzlr (10-15-2012), ft86Fan (10-12-2012), RRnold (11-05-2012), RWD-boxer (10-15-2012), so26 (10-15-2012)
Old 10-12-2012, 08:11 PM   #2
Skye
Drives: TR2,CooperS,BRZ
Is subaru gear oil as used in STI transmission OK for BMZ tansmission?
Skye is offline   Reply With Quote
Old 10-12-2012, 10:45 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
I had some grunge on the diff plug as well. I suspect the next change will have less on it.
Old 10-12-2012, 10:49 PM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Wondering if extra s is working well in this missions.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-12-2012, 11:49 PM   #5
xn7485
Drives: 1995 Acura Integra GS-R
Your choices of fluid changes are exactly the same as mine, except I stuck with an OEM filter. Just happy to see this combo used at a professional shop!
xn7485 is offline   Reply With Quote
Old 10-12-2012, 11:56 PM   #6
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Any change in shifting notchiness with that fluid?
michaelahess is offline   Reply With Quote
Old 10-13-2012, 07:21 AM   #7
roddy
roddy's Avatar
I'm using the MT-90 in my transmission as well, and there was an improvement in shift quality. Not a huge one, but noticeable. To be honest it shifted pretty good to start with. I've noticed now that the temperatures are starting to dip under freezing overnight, the 1-2 shift is a little stiff until I've put a few miles on the car. I'm very tempted to try gmookher's suggestion of the Pentosin MTF2 (75W80) fluid for the winter.
Old 10-14-2012, 05:54 PM   #8
bluesubie
For those that are asking, the STI specs GF5 and you want a GF4 in a BRZ transmission. GF5 is fine for the rear. Extra-S is GF5.
-Dennis
bluesubie is offline   Reply With Quote
Old 10-14-2012, 09:56 PM   #9
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Just changed my diff fluid with Motul Gear 300 also. Still debating as to which tranny fluid to use.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 10-15-2012, 11:03 AM   #10
Touge Factory
Drives: ZN6
The notchiness of the transmission didn't change. Fluids won't change that.
That slight grind from 1st to 2nd... I didn't notice this until the weather here started dipping into the 40's in the morning (even with the OEM fluids). After the first shift, it's perfect every gear with the MT90.
Old 10-15-2012, 11:05 AM   #11
Touge Factory
Drives: ZN6
You could try the MT-85 (75w85)
We had this in our Evo's in the winter, and honestly with chicago temps dropping below 0 at times - it's just in the matter of the fluids getting up to temp.
Old 10-15-2012, 12:46 PM   #12
wheelhaus
wheelhaus's Avatar
Drives: 2013 BRZ, 2011 Kawasaki Z1000
No, the AWD design Subaru uses means the tranny case also houses the front differential. The front diff is a hypoid design and needs the GL-5 requirements. Our FRS/BRZ transmissions are just that, transmission only. Some of the GL-5 stuff could deteriorate brass synchros, etc. Use something GL-4 rated.
wheelhaus is offline   Reply With Quote
The Following User Says Thank You to wheelhaus For This Useful Post:
einzlr (10-15-2012)
Old 10-15-2012, 01:18 PM   #13
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
What kind of bolts are the drain/fill plugs? I can't tell if they are squares, torx, or triple squares.
Grimlock is offline   Reply With Quote
Old 10-15-2012, 01:28 PM   #14
einzlr
Drives: several
People have been talking about significant brake fade; you didn't mention switching to performance brake fluid ???
einzlr is offline   Reply With Quote
Search this Thread:
Advanced Search
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 263 05-13-2018 12:49 PM
Motul Complete Fluid Changeover Sale! No Limit Motorsport Engine, Exhaust, Bolt-Ons 595 05-26-2017 12:11 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 09:57 PM
$98 Brake Fluid Upgrade Texas BRZ Tracking / Autocross / HPDE / Drifting 15 10-22-2012 02:50 AM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 02:05 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
