ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Forced Induction
Old 10-12-2012, 01:47 PM   #1
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
Map Sensor Hookup?
i want someone to help on how to hookup a map sensor for the BRZ for turbo application?
ft86-UAE is offline   Reply With Quote
The Following User Says Thank You to ft86-UAE For This Useful Post:
ericvanderwoodsen (02-14-2013)
Old 10-12-2012, 10:56 PM   #2
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Lift up small plastic cover on intake manifold take sensor out and replace with omni for honda k series motor. But in all honesty, if you have to ask this, i would not attempt to do this myself! Just sayin
Silverdub is offline   Reply With Quote
The Following User Says Thank You to Silverdub For This Useful Post:
ft86-UAE (10-13-2012)
Old 10-12-2012, 11:45 PM   #3
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
If your asking about wiring up a gm 3 bar or something like that you'll need the Oem wiring diagram for the car and you can get the wiring for the map from google, but I would stick with a plug and play.
ANTI_LAG is offline   Reply With Quote
The Following User Says Thank You to ANTI_LAG For This Useful Post:
Old 10-13-2012, 12:13 AM   #4
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
I put a 4 bar S2000 Honda map sensor in my setup. plug and play.
3 bar will work fine too. Just because you need help with a map sensor does not mean you are not capable of building an awesome turbo setup. I wondered about the same thing when I did my rear turbo FRS. I just was not educated yet on the map sensor, now I know and so will you when your done. People will be asking you how to do things. Press on, live and learn.
Roadstercycle is offline   Reply With Quote
The Following 8 Users Say Thank You to Roadstercycle For This Useful Post:
bakerr6 (04-25-2014), ericvanderwoodsen (02-14-2013), ft86-UAE (10-13-2012), jamesm (11-23-2013), nix (10-15-2012), normancw (04-26-2014), SocalMonsta (05-19-2015), Strife26 (01-08-2018)
Old 10-13-2012, 06:58 AM   #5
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
Thanks a lot for the Help
Old 10-15-2012, 09:44 PM   #6
ANTI_LAG
ANTI_LAG's Avatar
Please note that there is a different map sensor from the 01-05 (AP1) to the 06-09(AP2), you would want the AP2 if your ordering by this model, 06+SI would be the easiest way to make sure you dont get shipped the wrong map.
We will be having a thead on here soon where we list all the parts we have for the turbo community and we will have these.
Dave
Old 10-16-2012, 01:16 PM   #7
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
i have fitted a Yamaha 2 bar map sensor (jet sky). and we are running fine now. Thanks.
Old 10-16-2012, 04:08 PM   #8
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Go the Jetski parts - good work
Toyota 86 test driver
Tradewind is offline   Reply With Quote
Old 10-16-2012, 05:00 PM   #9
Cnidus
Drives: 2012 Toyota 86 GT (Black) :)
In fitting one of these is a full retune required immediately to rescale the map etc? Or can it be done as prep for a turbo install?
Cnidus is offline   Reply With Quote
Old 11-23-2013, 05:14 PM   #10
350zgoingFRS_lol
BIG Dreamer =D
Just* from what i have read on here ( never done) when installing a new sensor you need a ROM to go with it?… correct me if wrong, but i was just reading the FI threads with this topic also…but I'm assuming its the calibrations for the new sensor to make everything happy again lol
350zgoingFRS_lol is offline   Reply With Quote
Old 11-23-2013, 05:31 PM   #11
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
New Map = you need a new tune
Old 04-25-2014, 11:35 AM   #12
Howardwei
P3 external boost sensor
Does anyone know how to hook up the P3 external boost sensor? I was not awared of the Omni plug n play.So I bought the external sensor since the gauge vendor sells. them.
http://www.p3cars.com/add-ons-and-ac...-boost-sensor/
The analog sensor would hook up to the vacuum boost tap on the manifold. I assume cuttings will be done?
Howardwei is offline   Reply With Quote
Old 04-25-2014, 02:01 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Hook vacuum line up to sensor, run wires to gauge, done. I prefer using a vacuum manifold, but you will probably need to purchase a T fitting and maybe some extra vacuum hose then cut an existing vacuum hose and put the T in with the output going to your external boost sensor.
The Following User Says Thank You to King Tut For This Useful Post:
Howardwei (04-25-2014)
Old 04-25-2014, 06:01 PM   #14
Howardwei
Yea I just have trouble with the wiring part. My jr kit has a pcv somewhere in that vacuum line from the manifold. I assume you just install the whole T joint with sensor upstream of that pcv?
Search this Thread:
Advanced Search
Is P0108 (MAP sensor) common ? regal Issues | Warranty | Recalls / TSB 0 10-06-2012 12:21 PM
Understanding the BRZ/FR-S/86 Occupant Detection Sensor Turbowned Issues | Warranty | Recalls / TSB 13 08-27-2012 10:58 PM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-12-2012 11:46 PM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
