follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 10-01-2012, 11:27 AM   #1
Mo707
Mo707's Avatar
How to remove door panel?
I've been looking and I haven't found anything on this. Can someone help me out?
Mo707 is offline   Reply With Quote
Old 10-01-2012, 12:05 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Pop the silver painted vertical bit on the interior pull handle, gently with a flathead wrapped in a clock, starting at the bottom, once you start it down there, you should gently be able to pull it out. Remove the two screws behind this piece.
Pop the cover behind the opening handle with a small flat head, remove the screw behind it.
Pop the pop thing in the upper corner by the hinges, take that out.
Now starting right by that pop, gently pull the door straight out a quarter inch or so just until you hear the interior pop clips come loose, work around to the other side.
The door card will now be hanging from just the rubber window thing, pull the door straight up a few inches till it releases, then pull toward you a bit so you can remove the two cables from the lock mechanism and the wires for the window/lock unit and the curtisy light if equiped.
michaelahess is offline   Reply With Quote
The Following 4 Users Say Thank You to michaelahess For This Useful Post:
Gp1666 (06-12-2013), PoorMansRacing (12-06-2013), tripjammer (01-25-2013), Z3D (02-18-2013)
Old 02-18-2013, 05:32 PM   #3
Z3D
Thanks, just pulled them off, Very quick. Actually easiest door panel I have done.
Z3D is offline   Reply With Quote
The Following User Says Thank You to Z3D For This Useful Post:
tripjammer (02-19-2013)
Old 02-19-2013, 12:35 PM   #4
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I am going to do this and install some Dynamat in the doors and speaker, plus the JPM Coachworks alcantara speaker grills.
tripjammer is offline   Reply With Quote
Search this Thread:
Advanced Search
Japanparts has the OEM under panel kit listed! Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 224 04-08-2015 02:12 PM
Panel Removal for rear speakers? sesmls Electronics | Audio | NAV | Infotainment 8 08-01-2014 06:43 PM
Getting rid of scratches on door panel? evasquez7 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 09-30-2012 02:28 PM
CF wrapped dash panel Z0rr0 Cosmetic Modification (Interior/Exterior/Lighting) 34 08-29-2012 09:32 PM
Is this what they mean by panel fitment issues? ahquit Issues | Warranty | Recalls / TSB 7 08-21-2012 03:19 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
