Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
09-29-2012, 07:34 PM | #1 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
CARSMO duckbill spoiler installed on BRZ Limited
I've never found the BRZ limited spoiler to my taste. It's shaped oddly and doesn't seem to know if it wants to be a wing or a spoiler. I also think the shape of the BRZ/FR-S in the rear is nicely complimented by a duckbill rather than a wing or the odd spoiler the Limited comes with.
We begin here with the boomerang spoiler, booma-wing, axe-heads, etc: You may have noticed the car is dirty, I didn't wash it at this point for a reason I'll get to later. Unpacking the CARSMO spoiler, I find it packaged well against the careless whims of the USPS. It had two layers of bubble-wrap with extra end-caps to protect the tips. Here it is unpacked. It came with a microfiber towel and a couple CARSMO stickers too. So pop the trunk and remove the liner and the four rubber plugs covering the bolts under the "wings" of the stock spoiler: Removed: After removing the four bolts with an 8mm socket, there are five plastic pins that continue to hold the center of the spoiler on. The outer two are rectangular with tabs: The center three are plastic pegs: Squeeze the tabs on the rectangular pins and pull the spoiler away from the trunk lid. It'll pop off, just be careful you don't drop the spoiler on your paint when it comes loose. The two spoilers next to each other: Now, the reason why not to wash the car first is because the spoiler traps a lot of dirt underneath it. That needs to be cleaned up and the scuffs from the spoiler taken care of. Time to wash the car. But those holes need to be covered. A vinyl shop could provide some scrap pieces to cut up for this. I had a vinyl contingency sticker that I could use. Cut out 9 pieces and apply them to the holes from the inside of the trunk. Wingless and sealed: I also took this opportunity to debadge. This is not needed to install the CARSMO spoiler unlike the TRD spoiler. But I wanted to do something a bit different with my badges. Now while cleaning, when the dirt is cleaned from the trunk, get some Scratch-X or similar and neaten up the scuffs. This serves a double purpose because it will also remove any wax on the paint. When applying paint, vinyl, double-sided tape, glue, etc. the longevity and durability of the project is *directly* proportional to the care taken in prepping the surface. You want no wax or oils on the paint where the wing will be stuck on. Nice clean paint: Now that you've got nice clean paint, apply more vinyl patches on the outsides of the holes: Test fit: Use blue painter's tape to mark the spoiler's position so it can be replaced easily once you get the tape started. Now prep the spoiler for applying it. Peel back the ends of the tape to create tabs that can be pulled when the spoiler is in place: With the spoiler in place, pull the tabs to expose the adhesive and press the spoiler to the trunk. Then wax the spoiler and trunk to finish. And it's on! More pics: This is why I debadged: BRZ badge in the FR-S location. |
The Following 59 Users Say Thank You to Draco-REX For This Useful Post: | 20valvewynn83 (09-30-2012), Allch Chcar (12-22-2016), Ashphalt_Angel (03-23-2015), ATL BRZ (10-08-2012), BabaYaga (09-11-2014), baldolera (09-30-2012), bestwheelbase (11-05-2012), boxer 2.5 (10-12-2013), Chee-Hu (10-02-2012), Choco (09-09-2014), dabocx (09-30-2012), danthedirt (09-30-2012), djdnz (10-01-2012), Efferalgan (07-10-2013), Enalband24 (11-03-2014), Giccin (11-27-2012), Gintsuki (11-20-2013), Guff (09-30-2012), Gums (03-12-2013), humanshield (09-01-2013), idanvan (09-20-2013), jaymeister (09-29-2012), JDsThatGuy (05-14-2015), JEFFSTYLE (09-08-2013), jimmillion (12-01-2012), JoeHK (08-20-2015), johnb831 (11-07-2013), lionbacker54 (03-12-2015), Loki2x (09-30-2012), lordgrover (07-17-2014), Meehow86 (02-19-2013), Metabrz (06-04-2013), meWant (09-29-2012), microbionic (02-28-2013), mission2toilet (04-05-2014), Mr.Impreza (03-03-2016), Mx5racer (08-05-2015), n2oinferno (11-11-2013), Nigelr32 (10-14-2014), No Limit Motorsport (10-01-2012), NWFRS (11-08-2013), OjiGeorge (09-30-2012), onabulletride (01-03-2014), Plumbus (09-21-2020), Ray@Carsmo (09-29-2012), RazBRZ (10-01-2012), ShoGun (09-30-2012), SkAsphalt (10-01-2012), slaxx (01-07-2013), Snoopyalien24 (11-27-2012), stalon320 (09-30-2012), SurfAndSand (08-04-2014), Surok (09-29-2012), tobin (10-10-2013), TofuJoe (08-05-2015), travace (09-29-2012), tripjammer (09-29-2012), Turbowned (09-30-2012), WhiteLightning (02-26-2014) |
09-29-2012, 08:00 PM | #2 |
Drives: Widebody '94 Miata R-Package
Looks great thanks for the detailed write up!
I <3 my Miata. But I <3 my new BRZ even more! |
09-29-2012, 08:01 PM | #3 |
#1362
Drives: 2014 Ice Silver WRX
looks great uh.. can i have your limited spoiler? haha
The Following User Says Thank You to mezdup For This Useful Post: | elitegunslinger (02-02-2017) |
09-29-2012, 08:06 PM | #4 |
Yo dawg!
Drives: I have a car..?
Looks awesome bud! Great write up. DIY section?
09-29-2012, 08:28 PM | #5 |
Drives: Ford Focus ST
Nice work! The spoiler looks great, I can't wait to get mine.
09-29-2012, 08:29 PM | #6 |
Corner Junkie
09-29-2012, 08:29 PM | #7 |
Drives: WRB BRZ limited 6MT
You know that is one cool looking spoiler. You are right the stock limited spoiler is ugly. This one is pimp!
The Following 2 Users Say Thank You to tripjammer For This Useful Post: | MObrz5 (05-19-2014), Ray@Carsmo (09-29-2012) |
09-29-2012, 09:02 PM | #8 |
Wise old man
Drives: 86 GTS
awesome!
The Following User Says Thank You to Surok For This Useful Post: | Ray@Carsmo (09-29-2012) |
09-29-2012, 10:50 PM | #9 |
DEEEERP
i dont wanna sound like a dummy, but is the only thing holding that spoiler the tape? i take its probably strong but still...
this will definitely be something i do. thanks!
09-29-2012, 11:35 PM | #10 |
Drives: Argento FR-S
looks great! not just the wing, but everything!
wheel/tire specs?
The Following User Says Thank You to philstar For This Useful Post: | Draco-REX (09-30-2012) |
09-30-2012, 03:54 AM | #11 |
Drives: Scion FR-S
What front lip is that?
09-30-2012, 05:04 AM | #12 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Damn... you got GREAT TASTE in mods!
Carsmo *AND* WedsSports!! LOL
[CENTER]
Build thread |
The Following User Says Thank You to stevo_12v For This Useful Post: | Draco-REX (09-30-2012) |
09-30-2012, 08:00 AM | #13 | ||
Corner Junkie
The KORU/HTA lip for the BRZ. Last edited by Draco-REX; 09-30-2012 at 12:18 PM. |
The Following 2 Users Say Thank You to Draco-REX For This Useful Post: | bestwheelbase (11-05-2012), stalon320 (09-30-2012) |
09-30-2012, 01:18 PM | #14 |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
looks great!! congrats
#attackbydemons #imcomingbackbish
The Following User Says Thank You to 86design For This Useful Post: | Ray@Carsmo (09-30-2012) |
Similar Threads | ||||
CARSMO Rear Spoiler (FR-S/BRZ) Introductory Group-Buy | Ray@Carsmo | Groupbuys | 206 | 10-26-2012 01:47 AM |
~*# CARSMO FR-S Rear Spoiler #*~ | Ray@Carsmo | Exterior Parts - The Rest | 147 | 09-17-2012 10:00 PM |
New rear spoiler choice: Carsmo rear spoiler | Ray@Carsmo | Cosmetic Modification (Interior/Exterior/Lighting) | 46 | 08-10-2012 02:20 AM |
TRD Spoiler Installed | JDMSushi | AUSTRALIA | 9 | 08-07-2012 12:49 PM |
Carsmo rear spoiler test fit request on BRZ | Ray@Carsmo | Southern California | 12 | 07-27-2012 08:25 PM |
