Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 09-12-2012, 10:06 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
How to remove the stock antenna
Please bear with me as I'm working on getting all the photos needed for this guide.
Last night with some help I removed the stock antenna so I could wrap my roof. I could not find a guide for this so we figured it out ourselves. Look at the image below for the rest of the references.
Step 1, remove push pins from headliner
This is very easy and should only be difficult if you're doing it wrong. The push pins are two pieces. Slip a screw driver very carefully under the push pin. You want to grab the black portion of the push pin. This part pops down and you'll see the retaining clip is white plastic. Again, you're shimming your screwdriver between the black and white plastic, not under both. If you get under both the white and black plastic you can break the push pin. It should take very minimal force to pop these.
Step 2, pop loose the side panels
Marked in the picture below you'll see a red arrow to a red square. The red square is where the retaining clip is. Grab the panel from the top near the rear window and slowly pull back until you can pop this clip. You're not removing the panel, just popping this clip loose. Take your time, it didn't require a lot of work, literally 2 seconds once we knew how to pull on the panel. Simply sit in the back seat, and pull it towards the middle of the car.
Step 3, unscrew the antenna
Now that you have the headliner loose enough you can pull it down a bit and see the antenna. There is a big nut and a wrench will easily pop it loose so you can unscrew it by hand. I dont have the exact size because we used a resizable wrench. It's rather large.
Step 4, unclip the antenna
The antenna is taped to a bracket, cut the tape, then push in the tabs on the connector to release it. Then remove the nut that you loosened, and there are two small clips holding the antenna in place. Push them in and it will pop loose.
There is no tape holding the antenna on. It was slide right off once loose and the tabs have been pushed in. I hope this helps some people.
post_break is offline   Reply With Quote
The Following 14 Users Say Thank You to post_break For This Useful Post:
2point0 (09-18-2012), Ammonia (10-16-2013), axelo (01-01-2016), brz604 (06-10-2015), Chad86 (06-16-2014), Choco (10-14-2014), encity5 (09-12-2012), FlyLow (12-02-2013), jonzhuxD (06-10-2013), Joxer (04-06-2013), SPT Legacy (12-02-2014), Tama-Y (05-11-2013), voyager2285 (06-17-2014), zoomzoomers (09-21-2012)
Old 09-13-2012, 06:19 PM   #2
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
That's awesome. Mine would have turned out much cleaner if I had removed the antenna first. Might end up doing it over. Thanks for the info.
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
kmbkk (09-16-2012)
Old 09-16-2012, 11:26 AM   #3
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex, OC-135
Thanks for this write-up! I plan to remove the stock antenna when I put on my sat and Sharkfin antennas, and was wondering how to remove the stock one.
kmbkk is offline   Reply With Quote
Old 09-21-2012, 06:38 PM   #4
NemeGuero
Didn't happen to snap any pics of what the roof looks like without the antenna did you?
NemeGuero is offline   Reply With Quote
Old 09-21-2012, 08:22 PM   #5
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
You shouldn't have to.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-21-2012, 08:46 PM   #6
kmbkk
kmbkk's Avatar
Hopefully I won't, but if I do this definitely helps!
Old 09-21-2012, 09:06 PM   #7
mach330
Drives: Ultramarine frs
Great writeup.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 09-21-2012, 09:45 PM   #8
post_break
post_break's Avatar
Here ya go.
http://i.imgur.com/Vjb55.jpg
The Following 2 Users Say Thank You to post_break For This Useful Post:
brz604 (06-10-2015), Tama-Y (05-11-2013)
Old 11-01-2012, 03:47 PM   #9
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Originally Posted by post_break View Post
To a normal person, it might look good...lol to me it looks bald. Still going to do this though, thanks for the write up!
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 05-11-2013, 04:32 PM   #10
Spidey
Spidey's Avatar
Drives: 2013 FR-S, '85 Corolla GT-S Hatch
Thanks for this!
Spidey is offline   Reply With Quote
Old 06-16-2014, 03:31 PM   #11
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Thanks! I am getting my entire car wrapped in less than a week. I already removed all badges and now I need to take off the antenna and the sticky pieces under the rear plate. No front plate so I am good there. Any suggestions to prevent the plate from bumping or scratching at the botom while I drive to the shop? The shop will not do any removal prep work. I guess I could always bring my GooGone and spray wax with me...
Chad86 is offline   Reply With Quote
Old 06-16-2014, 03:36 PM   #12
jonzhuxD
Drives: Ultramarine FR-S
Originally Posted by Chad86 View Post
Thanks! I am getting my entire car wrapped in less than a week. I already removed all badges and now I need to take off the antenna and the sticky pieces under the rear plate. No front plate so I am good there. Any suggestions to prevent the plate from bumping or scratching at the botom while I drive to the ship? The shop will not do any removal prep work. I guess I could always bring my GooGone and spray wax with me...
Why don't you cut up an old towel or similar and puncture some holes in it to put between the plate and the car?
jonzhuxD is offline   Reply With Quote
Old 06-16-2014, 04:12 PM   #13
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Nice neon sign
ToyoburuBRZ is offline   Reply With Quote
Old 06-16-2014, 05:48 PM   #14
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Excellent idea, thanks. Need everything wrapped with no hole cutouts. Is the antenna as straight forward as is outlined? This is on a 2014.
Search this Thread:
Advanced Search
How do you remove factory antenna? srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 7 08-10-2012 07:37 PM
Stock Antenna Photo schtebie Cosmetic Modification (Interior/Exterior/Lighting) 0 07-20-2012 07:17 PM
how do you remove odor from fabric? prest1ge Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 07-03-2012 08:45 AM
Anyone know how to remove headlights? Memphis Cosmetic Modification (Interior/Exterior/Lighting) 25 06-12-2012 07:31 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
