| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 Ultramarine 86
DIY - "JDM" Side Vent Piston Badge (Red)
*Before I begin, I'd like to say that this DIY is partially for kicks and giggles. That said, I am in no way responsible for any scratches, marks, or other damage to you or your vehicle in any way whatsoever. PROCEED AT YOUR OWN RISK.*
This DIY is to turn your boring old USDM Piston Badge into a ghetto "JDM" Piston Badge. USDM Piston Badge JDM Piston BadgeTools you will need: Cleaning Solution (I used ONR). Microfiber Cloth (Clean, so you don't scratch your paint).And finally... A red Sharpie Marker (Ultra fine point. I bought a new one to make sure it was clean and didn't touch any other surface prior to this. It was $1 at a local Staples store).Step 1: Clean your badge and the area surrounding it. If you are using ONR, be sure to dilute it. You don't want concentrated soap on your paint! Once clean, move onto step 2.Step 2: ![]() Start by angling your Sharpie 45° to get the edges of the badge. Go slowly and take your time. You wouldn't want to mark the badge or worse, your paint. Fill in the remaining grey areas when you finish the edges. If you do mark the badge, bust out your microfiber cloth and apply light pressure to rub it off (This is a very important step as I didn't have a microfiber cloth when I did my first badge and has to use my shirt Doggy is sad.Step 3: ![]() Do the same with the center, 45° to cover the edges and slowly fill in the rest. The center ring is a little tougher to do but certainly by no means hard. The ultra fine point of the Sharpie fits snugly in the crack. Look closely from different angles to make sure you cover all of the grey areas. Step 4: Repeat for the other side and let dry overnight. You're finished! Here are pictures of the finished product: ![]() ![]() Comparison pictures: ![]() ![]() The ghetto "JDM" badge's red is nowhere near as bright as the authentic one but I like this shade more on a darker car. What do you guys think?
Drives: Bugatti Veyron
Nail polish or gel pen looks like it would have worked better
DADA
Drives: 2013
Yeah that doesn't look very good, paint needs to be more noticeable .. Like he mentioned nail polish or spray paint with a tiny brush?
I'm gonna try mine this weekend. Thanks for DIY , I'll be keeping fibre cloths handy! |
Drives: 2013 Scion FR-S-white out
Did mine with caliper paint
| The Following 12 Users Say Thank You to Plxdjake89 For This Useful Post: |
Deleted
"Did mine with caliper paint"
Very nice! Would it improve with the cylinder area (background of the rod) painted black? Want for my whiteout... |
#7 | |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Again, photoshop before actually doing it! Or if you did it, and didn't like it, gives you more of a reason to order real JDM ones and replace them.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#8 | |
| The Following User Says Thank You to Khalis For This Useful Post: | Plxdjake89 (08-29-2012) |
Drives: SWP 86 GTS 6MT
Here in Aus we have the base(GT) and high(GTS) spec 86, the GT has the black piston badge and the GTS has the red piston badge.. Does japan have the same thing or do all their specs have red piston badges?
#10 |
Drives: 86 ZN6
#11 |
Drives: 13 fr-s whiteout
Testors red paint and a super fine paint brush and an artist friend of my with no hand movement!
I'll be back!!
| The Following 11 Users Say Thank You to F3dzo For This Useful Post: |
#12 |
NW Region Moderator
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
#13 | |
#14 | |
Drives: 2013 Whiteout Scion FRS
| "vent" setting very warm to hot | MTeator | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 02-12-2023 10:35 AM |
| "86 Piston" License Plate Frame (part 2) | 86_ZN6 | Exterior Parts - The Rest | 122 | 12-22-2013 06:35 PM |
| "86 Piston" License Plate Frame | 86_ZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-05-2013 12:30 PM |
| WTB/Trade: Black FR-S fender "vent" panels with 86 badge | JWA | Exterior Parts (Aero, Lighting, Etc.) | 7 | 09-19-2012 10:42 PM |
| "86 Piston" License Plate Frame | 86_ZN6 | Exterior Parts - The Rest | 136 | 07-20-2012 12:00 AM |
