Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 08-03-2012, 01:58 PM   #1
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Audible shifter rattle
Sorry I had to start a new thread since some shifter threads were about the pattern cap coming off. I get this audible shifter rattle in all gears around 4000 rpm and up where it rattles during acceleration, constant throttle, and deceleration. I even took the shift knob off and it still rattles so it has nothing to do with the knob. Anyone experiencing the same thing?
Hanzo is offline   Reply With Quote
The Following User Says Thank You to Hanzo For This Useful Post:
Brzce (09-03-2012)
Old 08-03-2012, 05:05 PM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: FR-S Whiteout MT
Does it rattle even when you have your hand on the shift nob? I've never heard my shifter making rattle noise. I always keep my hand on the shift nob unless I'm just cruising at a speed.
Sigh-on-Rice is offline   Reply With Quote
Old 08-03-2012, 05:11 PM   #3
Hanzo
Hanzo's Avatar
Yes the rattle changes pitch if hold on to it.
Old 08-04-2012, 05:01 AM   #4
Sigh-on-Rice
FYI, I tried slowly revving to 6k rpm with my hand both on and off the shifter. It did not make any audible noise. The shifter didn't shake any more than when it's in neutral at idle too. I later tried going back and forth between 50 mph and 60 mph in 2nd (up to red line) on freeway, but it made no noise.
Old 08-04-2012, 09:15 AM   #5
Hanzo
Hanzo's Avatar
Thanks for testing it, maybe mine is an isolated case or maybe your engine runs smoother because of the fuel you use.
Old 08-05-2012, 11:08 AM   #6
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I have the exact same noise. Rattle comes from the shift lever starting from 4000rpms and up. Sound varies slightly depending on load & throttle.
Just picked my car up from the 1k service and they claim that it's 'normal'.
Tried removing the shift knob, even driving without it. With no knob it's a little quieter but still there.
I've popped the shift cap off and krazy glued it, still there.
Thinking of swapping shift knobs?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-05-2012, 11:14 AM   #7
Hanzo
Hanzo's Avatar
Noh I like oem. Also it has nothing to do with the knob.
Old 08-05-2012, 11:22 AM   #8
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I have a buzz/rattle too, but if I remove my knob the sound completely goes away.
Have you removed your knob during one of these events to find out if it is the cause? If it is, not a huge deal because it can be fixed with a aftermarket knob.
If it's still there, then you might have a potentially bad issue. If the knob removal doesn't fix it I would next try replacing the oem shifter bushing.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-05-2012, 11:30 AM   #9
ultra
Curious cat.
ultra's Avatar
Yeah Hanso you're right, it's not the actual knob. Unfortunately that's just the only part I can fiddle with myself at the moment.
It seems more like the shift lever itself is transmitting whatever noise it is into the cabin.
Thinking that, other than something inside the transmission case, it might be the reverse lockout cable, or the shifter bushing, or perhaps some heat shield or something contacting the transmission. Really no clue though and the dealer wasn't helpful at all. Hoping you might have better luck having someone in the States troubleshoot yours.
At any rate it's annoying. If I can figure out how to get the centre console off I might have a peek but I'm no big time mechanic.
If the tranny goes...warranty.
Old 08-05-2012, 02:38 PM   #10
ultra
Curious cat.
ultra's Avatar
PS, if you try revving your car up in neutral while parked can you replicate the rattle?
Also, oddly, mine only seems to do it once the car's warmed up. Doesn't seem to rattle at all first thing in the morning on my way to work.
Old 08-05-2012, 03:18 PM   #11
Hanzo
Hanzo's Avatar
It still makes the noise without a knob. I don't think there is anything wrong with the shifter bushing other than it's pretty stiff consider how much vibration our engine makes.
Old 08-05-2012, 03:20 PM   #12
Hanzo
Hanzo's Avatar
I don't think it rattles when it's not in gear.
Old 08-05-2012, 03:30 PM   #13
ultra
Curious cat.
ultra's Avatar
I'm able to hear the rattle when revving the engine way up while in neutral. Blipping only - if I hold it steady at high RPMs I can't hear it.
I can replicate it easily and consistently at WOT from 5k up in every gear from 2nd onwards (1st too short and 5th and 6th too tall to be sure). Knob or no knob. Happens.
Could be shifter bushings but since our cars are pretty new stuff shouldn't really be anywhere near to wearing out yet.
At least I know I'm not the only one so thanks. The description of your shifter rattle sounds identical to mine and it's been driving me nuts since it's the only flaw with an otherwise perfect new car. Mine's had it since new as far as I can tell (although I didn't drive it hard until very recently due to the break in period).
Please do chime in if you figure it out (or the stealer does).
The only other cure might be a loud ass exhaust or something to drown out the rattle with more noise. :p
Old 08-05-2012, 03:59 PM   #14
Jayde
Jayde's Avatar
I've noticed the rattle too. Seems to be coming just from below the shifter boot where it meets the collar, since I can grasp the area with my hand and noise does change.
Jayde is offline   Reply With Quote
The Following User Says Thank You to Jayde For This Useful Post:
Hanzo (08-05-2012)
Search this Thread:
Advanced Search
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 11:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 01:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
FR-S Shifter Video xravexboix Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 08:20 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
