Old 03-10-2019, 03:32 PM   #1
FRSure
Drives: Toyota
OFT not reading, and giving me CEL
I just had this problem today when I plug in my OFT. Usually, my OFT is never running. I just wanted to change the tune.
However, once i plug in my OFT, my dashboard beeps once. Then my dash lights up like a Christmas tree.
Here is what happen what I plug it in.
This is what happens on my OFT.
But my car is already on. I tried with engine on and engine off (on position)
I tried pulling the code with my OBD2 sensor.
Here is what I get.
After I unplug my openflash tablet, some lights turn off.
Only my ABS and traction light is on, until I clear the code with my OBD2 Bluetooth adapter.
Anyone know what's wrong with my car/OFT?
Thank you!
FRSure is offline   Reply With Quote
Old 03-10-2019, 04:42 PM   #2
Fast_ish
Fast_ish's Avatar
Drives: 2014 FR-S
are you using any extensions with the oft cable?
theres also a facebook group dedicated to oft support
OpenFlash Tablet BRZ/FR-S/86 Tuning & Support
https://www.facebook.com/groups/1861442760851576/
Its Fast...... ish
Fast_ish is offline   Reply With Quote
Old 03-10-2019, 05:26 PM   #3
FRSure
Drives: Toyota
Nope, no extension. I tried replugging many times too
Old 03-10-2019, 07:06 PM   #4
steve99
Dont plg in or remove oft or any other obd device while engine is running or ignition on.
Always stop wngine and turn igntion of before pligging in or re!oving any device on obd port else you can cause interruption to cann buss communocations and get issues your having.
Also when flashing or reading ecu you need to have ignition full on but engine stopped.
Logging is only time you want engine on
Old 03-10-2019, 11:05 PM   #5
FRSure
Drives: Toyota
Right. I tried it too. I plugged it in with my car off. Then I turn on the car, and all my lights on my dash will light up. So I’m not too sure what can be the issue. Right as I plug it in , half a second later, all lights on my dash light up. The OFT will not communicate with my ECU as shown in the picture
Old 03-10-2019, 11:26 PM   #6
steve99
Might be fault with oft cable, causing issue with cannbuss
If its ubder a year old oft guys might send you replacement cable
I think this car is giving me tinnitus. f0rge Scion FR-S / Toyota 86 GT86 General Forum 90 08-20-2014 12:14 PM
Happpy Thanks Giving Simpleviet Northern California 1 11-28-2013 03:40 PM
Giving thanks? PB86SS AUSTRALIA 5 09-02-2013 01:45 AM
Giving us a bad name here... ugh. raul Scion FR-S / Toyota 86 GT86 General Forum 108 08-19-2013 04:45 PM
Giving her what she deserves 86 Legend ASIA 25 05-23-2013 02:28 PM
