| DIY (Do-It-Yourself) Guides For all DIYs. |
#23 |
FRS Rear Mount Turbo
Drives: 2013 FR-S Raven, Rear Turbo
So actually what we have here is a failure to communicate. It's a fog light with your headlights on and a brake light when you hit the brakes. Looks like the best of both worlds. A little safety and a little more safety +2. If anyone gets a ticket then we'll reevaluate the situation.
Great DIY. What the hell, its there, might as well do something fun with it. |
#24 |
Running in the 90s
Regardless of personal opinions on whether or not this should be done, the quality of the DIY is excellent. Well done.
Did you place any sealant between the bulb sockets and the housing?
藤原とうふ店(自家用)
MattR's Tofu Runner |
#25 |
Drives: 07 STI
Wow, no...you're twisting my words around for your own benefit. Take a deep breath and try to follow along here. If you actually READ what I said, it's that because of the location of the light on the car and what it is actually intended and designed for, you will get the most functionality by putting the light on a dedicated switch or tapping into your front fogs and using it in bad weather. It's really that simple. Having a 4th brake light offers absolutely no benefits to the driver. But, if that's the look you're after then by all means, to each his own. Again, I'm simply offering information to those who don't know what the light is actually for or those who want to wire it up correctly.
#26 | |
BRZ #575
Drives: 2013 BRZ #575
ZILLA
BRZ #575 SWP Limited 18x8" Drag DR-31 +48 | 235/40/18 | 6000K HID Low/High | Wrapped All Red Tail Lights | Rear Fog + Brake Light Combo Mod [Video] |
#27 | |
BRZ #575
ZILLA
#28 |
BRZ #575
Thank you. The sockets have a domed /suction cup like rubber shape to them which seemed to do a great job sealing them up when I inserted the sockets into the holes. Hard to explain but I was comfortable leaving them as is with no sealant. That way they can come out easy too, if I have to change a bulb.
ZILLA
| The Following User Says Thank You to ZILLA For This Useful Post: | MattR (07-10-2012) |
#29 |
FR-S Owner!
Drives: 2013 FR-S Ultramarine 6AT
Well I think this is just awesome, and exactly the thing I've been wanting to do with mine since I first saw the light assembly in pictures. Very well done on the tutorial. Thanks!
#30 |
Drives: Currently own a 3000GT
This is what i've been looking for. Only difference is i want to have it flash like this.
http://www.blaize-electronics.com/pr...rake_light.htm |
#31 |
Drives: 2013 Ultramarine 86
What kind of bulbs did you use/buy from?
#32 |
Thanking Meister Mod
Drives: 1994 Toyota Supra-SW-BL/AT-61mm
Hey guys, stop arguing.
It is what it is. Some people would like it as a brake light, some as only a foglight. Either way, this thread is useful for somebody and let's not clog it up with random crap.
![]() "Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." - The Ancient BRZ Sacrament by Zaku |
| The Following 3 Users Say Thank You to Guff For This Useful Post: |
#33 | ||
Power Ranger Elite
Drives: '14 BRZ (WRB/GBS)?
| The Following User Says Thank You to jimmillion For This Useful Post: | blackfireball5 (07-12-2012) |
#34 |
#35 | |
Drives: Mazdaspeed 3
It's technically illegal to have the rear fog light (or really ANY fog lights) on during fair weather conditions. I doubt you'll find a cop in the US who will ticket you for it, though. The lights are aimed in such a way that they can be distracting to drivers, especially rear fog lights. Rear fogs are aimed directly at driver eye-level so as to increase visibility in foggy conditions (as you would expect, given their name). Also, it's doubly illegal to have a fog light used as both a fog AND a rear brake light. There are strict regulations on this. Again, I highly doubt you're going to find anyone of any official capacity who will cite you on it, but there it is. On the flip-side of the coin, many European cars DO have the rear fog light retrofitted into a brake light on the USDM models. They usually have the reflectors changed and are aimed differently, though. Just be aware that modifying the lighting on your car shouldn't be taken lightly. There are a ton of regulations on brightness, light aiming, position on the vehicle, etc. Modifying the lighting (which is safety equipment) on a vehicle can be dangerous to yourself and others around you. Hope that doesn't count as random crap
| The Following 2 Users Say Thank You to Fenrir For This Useful Post: | Moshpit37 (07-12-2012), robotvoice (07-13-2012) |
#36 | |
That's fine, and people who do follow this DIY will do so at their own discretion with your comments in mind.
#37 | |
Drives: 2013 Ultramarine Scion FR-S
In the state of Texas(where I live), state law requires only 2 brake lights. http://www.txdps.state.tx.us/RSD/VI/lighting.htm So I guess I could remove the third brake light right away? |
#39 |
FR-S Owner!
Just a quick FYI: I'm working on this right now and the red wire was for the regular tail lights only, not the brake. I am only putting one light in there and wanted it for the brake light only, and when we spliced the red wire it wasn't the correct one.
#40 |
Drives: 2013 BRZ, 2002 WRX
I finally got this done. Took a bit of time to get it wired properly -- I wanted it to look like it came from the factory.
![]() I also integrated the blinking module. ![]() Here's a link to video: |
#41 |
Drives: Firestorm FR-S
Also just did this, great DIY. Took 3-4 hours taking my time.
One key thing to note, the housing for the red fog light has 2 lenses. When you drill out the holes be careful not to get the debris in between the outer and inner lenses. If you do you'll have to bake the light to separate everything and clean. I found out the hard way. The light output is perfect with the 194 bulbs. |
#42 | |
FT86Club Official Vendor
Drives: Scion FR-S (Hot Lava)
#43 | |
Sent from my SCH-I800 using Tapatalk 2
#44 | |
Did any of you BRZ guys also have a hell of a time getting the light fixture out of the bumper? I ended up taking all bolts and plastic pop rivets out of the bottom diffuser and still had to flex the bumper a lot to get that thing out of there. I was afraid I was on the verge of breaking the bumper! |
| Tags |
| custom, fog, fog light, foglight, rear fog light |
| How-To: Remove Rear Deck & Third Brake Light | Moshpit37 | DIY (Do-It-Yourself) Guides | 23 | 06-14-2013 06:41 AM |
| Third brake light...(top mount) | Slide | Cosmetic Modification (Interior/Exterior/Lighting) | 45 | 03-07-2013 09:46 AM |
| Third brake light out? | Longhorn248 | Subaru BRZ General Forum | 17 | 08-02-2012 09:44 AM |
| The third brake light looks like a car! | Longhorn248 | Subaru BRZ General Forum | 12 | 06-06-2012 06:14 PM |
| FR-S Rear brake light... | MF_DEUCE | Photos, Videos, Wallpapers, Gallery Forum | 70 | 05-05-2011 02:53 PM |
