| Subaru BRZ General Forum All discussions about the Subaru BRZ coupe |
Drives: Researching the BRZ
BRZ ‘s “boomerang” LED strip mystery
When exactly does it come on? Is it designed to work in conjunction with the HID lamp only?
Can it be used as a DRL (day running light), with or without the specific DRL lights? I’d love to see a pic with just the DRL and the LED strip simultaneously lit. Anybody? |
| The Following User Says Thank You to DrakeM For This Useful Post: | 86design (07-03-2012) |
Drives: 05 92X Aero OBP, 13 BRZ LTD SWP
These will both be lit when you have the light selector in Parking Lights.
Per the Owners Manual: O = Off - The daytime running lights turn on. AUTO - The headlights, parking, daytime running lights and so on turn on and off automatically. (Vehicles without a keyless access with push button start system: When the engineswitch is in the "ON" position. Vehicles with a keyless access with push-button start system: When the push-button ignition switch is in "ON" mode.) Parking Lights - The side marker, parking, tail, license plate, daytime running lights and instrument panel lights turn on. Headlights - The head lights and all the lights listed above (except daytime running lights) turn on. Last edited by thermobox; 07-03-2012 at 06:08 PM. |
| The Following User Says Thank You to thermobox For This Useful Post: | gmookher (12-04-2012) |
You mean the regular DRL’s and the LED’s?
Drives: 2013 BRZ Limited
You can run just that and the DRL LED strip by selecting the option one click above "auto" - it looks pretty awesome but the interior will dim.
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Isnt that the parking light setting?
No lie, I've been driving around with them on just because ![]() First car I've owned that looks badass and I cant help it! |
| The Following 5 Users Say Thank You to Kido1986 For This Useful Post: | 86design (07-03-2012), racecaresuaceb (05-16-2013), speedracer38 (07-04-2012), tripjammer (07-06-2012), WRXGuy1 (07-05-2012) |
Drives: '13 BRZ Lmtd
The "boomerang" lights come on with the headlights and with the switch set for parking lights. The much brighter 3 LED strip running lights above the fog lights come on whenever the car is running and the hand brake is off and the HID headlights are off. When driving with the switch in the parking lights setting the running lights, boomerang lights, side markers above the wheels, tail lights, and marker plate light will be on.
Last edited by DSPographer; 07-03-2012 at 06:51 PM. Reason: Corrected for running lights off when HID are on. |
I’m starting to understand (my bad for not properly explaining this from the beginning)
So I could drive with both the “boomerang” and the dedicated day running lights, but only if the regular and the side markers are also on? In other words, there is no way to drive with just the boomerangs and the DRL’s? Just the two, and no other lights? |
#8 | |
As Seen On The Internet
Drives: NA8, WRX, BRZ 6MT Limited
"regular"?
Parking lights setting will give you boomerang, led strip, side marker, and rear lights on. If you turn your headlights on, it seems the led strip (DRL) turn off! ![]() Fog lights only come on if you have your headlights on - though there will likely be a work around DIY mod to change that if you want them on with parking lights. |
#10 |
ZC6A2B82KC7J
Drives: 2002 WRX
I switch it to parking mode when it is overcast. Seems like the headlights don't turn on until it's really dark so I use the halos for the in between times (too dark to read the gauges but not dark enough to need headlights). I don't think they're bright enough to see in full daylight and I don't like having the interior dimmed during the day so I don't bother with them when it's sunny out. I have yet to turn on the fog lights other than to test them out when I first got the car. I couldn't tell any difference with them on or off.
| The Following User Says Thank You to Spaceywilly For This Useful Post: | Marchy (05-17-2013) |
#11 | |
I think this is the way OEM fog lights normally work. I think glare from low-beams in the fog can be reduced by using the leveling adjustment to point them down. So, there may not be a need to make the mod to turn them on with the parking lights. |
#12 |
Working on independent fog light mod. Trying to do it without major rewiring.
#13 | |
I'm different, yeah I'm..
Drives: Attitude
On my WRX I had them wired to run from the switch independently of headlights as my DRLs, which I disabled.
#14 |
Vindictive S.O.B. Member
Drives: '13 FR-S
I was disappointed by how dim the boomerangs are, especially off axis. The DRL strip likely will overpower it.
I am hoping to find a way to toggle the DRL's manually. |
#15 |
Drives: 2013 Subaru BRZ Premium, Black
I'd love to at some point find a way to mod it so the LED strip in the headlights are always on when the car is running since it does look cool when they are on.
| The Following User Says Thank You to Shizuma For This Useful Post: | meWant (12-07-2012) |
#16 |
Drives: '89 911, '06 GTI, '13 BRZ
I would welcome this.
2005 Honda XR650L (for sale)
2008 KTM Superduke 990 (for sale) 1989 Porsche Carrera 3.2 Coupe 2006 VW GTI/DSG 2013 Subaru BRZ WRB Limited 6MT |
#17 |
Drives: '05 Mazda3
Way too many lights in the front imo. Subaru should've just eliminated the front LED DRL strip and used the "boomerangs" or "halos" as the DRLs. Simple.
| The Following 3 Users Say Thank You to oldskule For This Useful Post: |
#18 | |
Drives: '13 FR-S
Unfortunately looking at the headlight it seemed like it would be an enormous pain in the ass to modify the boomerangs or even access whatever illuminates them. If the element is easy to replace and is led then it might be easy to make brighter, but it looks like it uses some kind of plastic to distribute the light so keeping it even and pretty might be a challenge. I'm with you though, if the boomerangs could be made bright enough to serve as DRL's and I could completely remove the led DRL strips, I think I'd prefer that look. |
#19 | |
Drives: '05 Mazda3
#20 | |
Site Moderator
Drives: 97 ITR, 00 GS-R, 96 GS-R Race Car
-Dave
97 Integra Type-R, 00 Integra GS-R, 96 Integra race car and a 2013 BRZ-L! |
#21 | |
Grip>Slip
Drives: 13 SWP BRZ LTD 6MT
#22 |
Drives: 2013 WRB BRZ Premium 6MT
I'd have to disagree, the halo's are no way near bright enough to be DRL's. Besides, having the LED strip and the bommerangs on make it look really aggressive!
| The Following 2 Users Say Thank You to WRXGuy1 For This Useful Post: | meeskee2 (05-20-2013), tripjammer (07-06-2012) |
| no front LED strip? | Lydin | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-03-2012 01:05 AM |
| FR-S SNS 200 mystery NAV/XM/Receiver | FR-S-Ohio | Electronics | Audio | NAV | Infotainment | 2 | 05-31-2012 05:58 AM |
| About the LED strip on the GT86 | Sasquachulator | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 05-14-2012 11:14 PM |
| Mystery Clay Model From Toyota Video | Dark | Other Vehicles & General Automotive Discussions | 16 | 02-18-2011 03:21 PM |
