Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-09-2018, 05:47 PM | #1 |
Drives: 2014 Scion FRS (Red)
coilover install question
Hey guys,
I am planning on installing ohlins coilovers. I understand that it is recommended to replace some of the oem bolts in the front and back. I cant seem to find it. Can you guys let me know which ones and part numbers? Thanks |
04-09-2018, 07:05 PM | #2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Replace them for what reason?
04-09-2018, 07:10 PM | #3 | |
Proud of BOXER
Drives: Subaru Boxer
I believe there are some suspension bolts that Subaru specifies to not re-use and to replace with new ones. Something about threads getting elongated and proper torque specs, yadda yadda.
The Following User Says Thank You to Clipdat For This Useful Post: | finch1750 (04-10-2018) |
04-09-2018, 07:24 PM | #4 |
Loading...████████] 99%
Drives: #0517
subaru part numbers from https://parts.subaruonlineparts.com/...-h4-gas-engine
front 901000371 - strut upper bolt (x2: one for left and one for right) 901000394 - strut lower bolt (x2: one for left and one for right) 902380008 - strut nut (x4: 2 each for left and right) rear 901000435 - strut bolt (x2: one for left and one for right) 902350032 - strut nut (x2: one for left and one for right) i think i have the bags for toyota p/n's at home, but honestly i will probably forget to check
R1 3 5
╘┼┼┤ . 2 4 6 |
The Following User Says Thank You to asdf For This Useful Post: | strat61caster (04-09-2018) |
04-10-2018, 05:33 PM | #6 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
There are a lot of fasteners that Toyota says are non-reusable. Here is one example. |
The Following User Says Thank You to Sapphireho For This Useful Post: | strat61caster (04-10-2018) |
04-10-2018, 07:10 PM | #7 | |
WTF. Never knew that. Wonder how many people actually do replace them lol |
04-10-2018, 07:30 PM | #8 | |
Drives: #0517
Toyota did send me new bolts and nuts when I bought TRD springs, though!
R1 3 5
╘┼┼┤ . 2 4 6 |
04-10-2018, 08:06 PM | #9 |
Drives: 2013 FR-S Series 10
That is weird. They are torqued fairly tight so maybe they stretch a bit.
04-10-2018, 08:41 PM | #10 |
¯\_(ツ)_/¯
04-10-2018, 10:12 PM | #11 |
The diagram only shows the nuts are non-reusable, not the bolts.
The Following User Says Thank You to wparsons For This Useful Post: | nikitopo (04-19-2018) |
04-10-2018, 10:19 PM | #12 |
I’ve out 130lbs on those hub nuts several times now, maybe they assume people will use a 12pt head and chew it up over time?
04-10-2018, 11:31 PM | #13 |
Mine are rusty from the winter so I think might be better to get new
04-15-2018, 10:05 AM | #14 |
Would you guys replace the bolt on the endlink?
Similar Threads | ||||
Help w/ Coilover Install | Waffle86 | Northwest | 15 | 09-12-2017 04:47 PM |
Coilover install | JerryMichaels7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 02-05-2014 03:31 PM |
Quick Question about Doing coilover install | Xdragonxb0i | DIY (Do-It-Yourself) Guides | 3 | 05-31-2013 02:14 PM |
HKS Coilover install | gtauto | AUSTRALIA | 16 | 04-21-2013 07:37 AM |
Suspension (Coilover) Install Question | crizkay | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 02-28-2013 09:17 AM |
