Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
12-10-2019, 03:15 PM | #85 |
Drives: 2023 BRZ
There is a difference between me not being able to provide proof and it not existing. That said, it is good to have a healthy dose of skepticism for things read in forums, so I understand where you're coming from.
Director of Rocky Mountain 86CUP
12-10-2019, 06:05 PM | #86 | |
I would be more apt to finding 5-20 gallon drums of VP or Sunoco quality race gas instead of running the e85 from the pump. Just my 2 cents |
The Following 4 Users Say Thank You to fika84 For This Useful Post: |
12-11-2019, 07:20 AM | #87 | |
Only happy when it rains.
Drives: series.blue
In general I've seen people say to run a tank of 93 every month, or every 4 or 5 fill ups, or people run a gallon of 93 every time they fill to cancel out the vast majority of issues e85 can cause. |
12-11-2019, 10:08 AM | #88 | |
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | fika84 (12-11-2019) |
12-11-2019, 10:55 AM | #89 |
The Following User Says Thank You to fika84 For This Useful Post: | DarkSunrise (12-11-2019) |
12-11-2019, 04:51 PM | #90 |
Drives: 2013 frs red
Drag reducing agents in the fuel.
12-11-2019, 05:57 PM | #91 |
I think it has more to do with who is supplying the fuel.
12-12-2019, 06:45 AM | #92 |
Drives: series.blue
09-28-2021, 01:23 AM | #93 | |
I am currently having to replace my engine with about 25,000-30,000 miles on primarily E85 due to scoring/pitting to the cylinder walls and damage to the piston rings, only making about 30psi average of compression across the cylinders. I was also dealing with a prolonged issue with my OCV's and the exhaust cam phaser on the right side of the engine, so that's not to say that running E85 was the only cause of the issue. However my tuner and a Subaru master tech came to the conclusion that the damage to the cylinders and rings was most likely caused by a lack of lubrication from using E85 without a lubrication additive. I have a AVO turbo and was at 350whp and 280fl/lbs on 12PSI at the time but after this loss I am going to use pump gas until I can come up with a more permanent solution. I know it's just a story and "anecdotal evidence" but for what its worth, just throwing it out there. |
09-28-2021, 06:44 AM | #94 |
^ I think the boost was the bigger problem. I appreciate your post but many have gone 6 figures or close to it on ethanol. I've never read about boosted cars lasting that long.
The Following 4 Users Say Thank You to Lantanafrs2 For This Useful Post: |
09-28-2021, 12:06 PM | #95 |
Drives: Crapcan
Looks like not enough ring gap to me
09-28-2021, 12:50 PM | #96 |
friendly
Drives: 17' 86
Back in my mazdaspeed 3/6 days when we were experimenting with ethanol we would run into an issue called "black death". Effectively what would happen was engine oil would mix with some fuel in the HPFP and cause a black sludge to develop on the HPFP internals and prevent the HPFP from working. The HPFP would function again after cleaning. This issue only presented in high concentrations of eth and could be completely avoided by running a 30-50% blend. 30-50% was also a sufficient amount eth to hit MBT so running higher percentages provided minimal benefit.
Just some food for thought.
Seek comfort in discomfort.
09-28-2021, 03:18 PM | #97 |
Drives: 2019 Toyota GT86
I'm now 20k miles on my 2019 86 and no issues what so ever. Have never gone back to octane 93.
The Following User Says Thank You to Frankz54 For This Useful Post: | Lantanafrs2 (09-28-2021) |
09-28-2021, 04:49 PM | #98 |
My AVO kit went on at 5k miles, just over 30k now and still running strong 90+% E85. I track at 6 to 7psi and play at 9 to 10psi.
Similar Threads | ||||
Long term E85 use | redrocket89 | Engine, Exhaust, Transmission | 92 | 06-28-2021 05:40 AM |
Long-term adverse effects of Whiteline chassis inserts? | ApexEight | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 09-07-2017 07:13 AM |
long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
