Software Tuning Discuss all software tuning topics. |
04-11-2019, 10:36 PM | #1 |
Drives: Boosted
Ecutek showing boost target hitting 19.9?
I have a high boost map set on 10psi, but when I took a look at the logs it shows 19.9 on wot. Is this an overboost? It definitely did not seem anywhere near 20psi of boost.
04-11-2019, 10:48 PM | #2 |
Drives: 2017 Toyota 86
Units? 10 psi is almost 20 inHg.
The Following User Says Thank You to Mr_Eyo For This Useful Post: | incutebus (04-11-2019) |
04-11-2019, 11:37 PM | #3 |
Drives: Boosted
04-12-2019, 12:17 AM | #4 |
Drives: 2017 toyota 86
14.7 is ambient, ecutek is reading 5.2psi the max ecutek reads with stock uncalibrated map sensor.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | tomm.brz (04-12-2019) |
04-12-2019, 12:22 AM | #5 |
Drives: FT86
As above manifoid pressure is logged reliative to atmospheric. So actual boost is loiged boost minus about 14 psi. Log manifold pressure with ignition on and motor off you will see.
The Following User Says Thank You to steve99 For This Useful Post: | DeliciousTuning (04-12-2019) |
Similar Threads | ||||
Part out tails, boost controller, ecutek | Stevenduarte210 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 07-02-2018 04:30 PM |
FS: SBD Turbo kit with oil cooler, boost controller, ecutek cable | Sniper2606 | Engine, Exhaust, Bolt-Ons | 12 | 08-14-2014 10:52 AM |
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) | NickFRS | Software Tuning | 43 | 03-10-2014 04:10 AM |
Ecutek boost control with ebcs help. | gdrider77 | Software Tuning | 11 | 02-02-2014 09:06 PM |
Guys running EcuTek boost control | ATSAaron | Forced Induction | 14 | 09-14-2013 03:08 PM |
