Old 01-07-2015, 01:50 PM   #15
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by rh9 View Post
what ecu and wiring are you guys gonna use ?
and what rear end setup are you putting on her ?
Custom wiring setup, @FullBlown Rear end
Pure Automotive is offline   Reply With Quote
Old 01-07-2015, 03:27 PM   #16
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Hydra?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
AZ BRZ (01-06-2016)
Old 01-07-2015, 09:51 PM   #17
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Originally Posted by Pure Automotive View Post
I couldn't begin to tell you that without a 30 question interview about goals, turbo, manifold, piping, exhaust, etc. There's so many variables. The only thing I can say is, don't listen to anyone who tells you it can be done on the cheap. If you want to do it right and reliable, it will cost you a sizeable about of money. At least $20k as a starting point for a professional to do the job.
Well said!
Drift&Drag is offline   Reply With Quote
The Following User Says Thank You to Drift&Drag For This Useful Post:
xxscaxx (03-22-2015)
Old 01-15-2015, 07:18 PM   #18
07jazzrs5gt86
Drives: Firestorm 86
I couldn't begin to tell you that without a 30 question interview about goals, turbo, manifold, piping, exhaust, etc. There's so many variables. The only thing I can say is, don't listen to anyone who tells you it can be done on the cheap. If you want to do it right and reliable, it will cost you a sizeable about of money. At least $20k as a starting point for a professional to do the job. I will give you an example breakdown of bare minimum parts that you need that make up a large part of the total:
Engine/Trans, if you go V160, you're talking $8k
Custom Wiring Harness, starting at $800
Custom Driveshaft, at least $500 if you get it deal
Custom intercooler piping, WG, BOV $1000 +
Turbo Manifold $1500 and up for quality setups
Custom downpipe and dump tube $500+
Turbo $1000-25000 depending on what kind/size
Clutch, Flywheel, Custom Shifter- If you plan to make real power $1400+
Stand Alone Engine Management $2000
RacePack Dash $800
Custom hoses for radiator, heat, A/C, etc. $500+
Axles to support 600+hp
Rear end to support 600+
^ This puts you around $13k and we haven't even opened this used motor to build or do maintenance on anything. You're going to want cams, cam gears, valve springs, retainers, new water pump, new timing belt, new gaskets, at a MINIMUM before you put it in the car, there's another $1500 not including labor.
Now you're talking $15k in parts alone, now someone has to spend xx amount of days properly installing everything, clearencing everything, tuning, etc.
I don't mean to sound ignorant, arrogant, presumptuous, etc. But this is my 3rd engine/trans setup in this car and I can tell you from experience, its ALOT of work and ALOT of unexpected expenses that you come across as you do a swap. I wish I could tell you we do 2JZ swaps for $10k installed but I would be lying and giving you false hope.
*** Disclaimer: This is NOT an advertisement. None of the prices I have put above are in any way an actual price quote for any services/parts. I am simply using numbers for an explanation that people need to see to understand. Please don't delete this as an attempt to advertise, it is NOT.
Thanks for a quick summary of cost Iwas planning of doing this swap 3-5years down.
Seem like i'll just gotta pay off the car then do another 20k+ loan for the swap. A never ending payments
Also side note how much you spent on the ls2 swap?
07jazzrs5gt86 is offline   Reply With Quote
Old 01-21-2015, 04:33 AM   #19
Kwoodrow3
Drives: SRT4
What size rim and tire are you able to get underneath er?
Kwoodrow3 is offline   Reply With Quote
Old 03-22-2015, 01:25 AM   #20
Streetthrowback
Drives: 2015 brz
Subscribed
Streetthrowback is offline   Reply With Quote
Old 03-23-2015, 11:47 PM   #21
Pure Automotive
Updated! Stay Tuned, Our Startup Goal is mid April, still waiting for a transmission!
Engine Is Nearly Complete! Just have to degree the cams and she's all set!
Meanwhile, the car is getting a massive face lift. Partially shaved bay and fixing all the small knicks and bumps.
Before
After
The Following User Says Thank You to Pure Automotive For This Useful Post:
limitedblkwrx (03-24-2015)
Old 03-24-2015, 04:00 PM   #22
Pure Automotive
The Following 8 Users Say Thank You to Pure Automotive For This Useful Post:
Darryljr11 (03-24-2015), flippy (12-15-2015), kanundrum (04-28-2015), limitedblkwrx (03-25-2015), spdfreak (05-25-2015), Valentino (04-22-2015), Xero-Limit (03-25-2015), zoth (04-25-2015)
Old 03-25-2015, 12:03 PM   #23
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
that's kind of funny...
RacePack Dash $800
but I don't remember EVER hearing anyone say that they could get a professional to install it for less than $20K...
Everyone who has said it can be done for less than $20K has talked about doing the work themselves with maybe some contracting out for fab work or buying a kit to do the install.
That being said, I love this build and I can understand selling the lsx if the price was right. Most things are for sale for the right price.
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
Pure Automotive (03-31-2015)
Old 03-25-2015, 07:57 PM   #24
2much
I wanna go fast
Drives: 2013 FR-S 6MT
:boner:
2much is offline   Reply With Quote
The Following 2 Users Say Thank You to 2much For This Useful Post:
ohhwilliam (03-29-2016), Pure Automotive (03-31-2015)
Old 03-31-2015, 09:41 PM   #25
Pure Automotive
Updates!
Thanks to @spitfire481 the car is looking "Purer" than ever haha! It's so greeeeeen!
Wraps and great, plastidip is cheap, but there is no replacement for the hard work and art of a full paint job!
Starting to piece the bay back together for insertion, transmission is on it's way!
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
Fast_Freddy (04-16-2015), kanundrum (04-01-2015), Lonewolf (03-31-2015), spdfreak (04-01-2015)
Old 04-01-2015, 12:45 PM   #26
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 04-01-2015, 01:44 PM   #27
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
*fapfapfap*
Good lord that's gorgeous!
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Old 04-01-2015, 03:46 PM   #28
SirBrass
SirBrass's Avatar
I really hope he says "screw it!" and puts ITB's on.
DustinS (04-02-2015)
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 06:11 PM
The New Consolidated Install Thread @Pure Automotive Performance, FT86 Specialists! Pure Automotive Mid-Atlantic 14 09-26-2013 10:28 PM
**The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive Pure Automotive Brakes, Suspension, Chassis 1 02-06-2013 02:32 PM
*Pure Automotive Performance: Project Whiteout FRS Build Thread* Pure Automotive Member's Car Journals 6 01-18-2013 11:34 AM
