Old 08-06-2012, 04:09 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Kiwi View Post
One thing I don't understand.
How do they measure the spring rates on a progressive coil design?
Did they measure the rate of the first, middle or last section of compression??
IIRC, in this case (and in the case of the Sportlines) it's initial, then the main spring portion (progressive springs compressed) and then with deflection of the bump stops. So the highest measurement you don't really want to use
On the sportlines the progressive portion is mostly (or maybe entirely) compressed from the car itself I believe.
I will be testing the sportlines once they get produced and I receive them. I'll have some datalogged track data before, and after, plus street driving and autocross opinions to post in a review.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ultra (08-06-2012)
Old 08-06-2012, 07:41 PM   #44
paulieblaze
paulieblaze's Avatar
Drives: 2013 Scion FRS/Whiteout
eibach springs
I just had mine installed a few days ago, what a nice ride. Heres mine.
paulieblaze is offline   Reply With Quote
Old 08-07-2012, 02:43 AM   #45
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by ultra View Post
Interested to hear your driving impressions of the Eibachs vs. The D2s.
I will be updating the D2 topic soon with some more driving impressions... but not so much about the Eibach springs vs the D2 coilovers. I can say that the coilovers are even stiffer than the Eibachs... and that's about all you can feel from behind the wheel.
The Eibachs ease communication between the road and the steering wheel, it feels like a naturally, sportier setup. The D2s are a little on the harsh side, but right now I have them on the stiffest setting.
If you just want a slightly sportier stance then go with the Eibachs for the mid-$200 range. But if you want to tweak your setup I would definitely go for some coilovers.
Old 08-08-2012, 10:20 AM   #46
Mengsta
Mengsta's Avatar
Drives: Scion tC, Gen Coupe,
Send a message via AIM to Mengsta
awesome pictures!
Mengsta is offline   Reply With Quote
The Following User Says Thank You to Mengsta For This Useful Post:
paulieblaze (08-09-2012)
Old 08-09-2012, 11:33 AM   #47
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Thanks for the thorough write up Darren.
Slapping these on this weekend as you did while I ponder coilover selection.
Jeff86 is offline   Reply With Quote
Old 08-09-2012, 11:36 PM   #48
detainu
Drives: 2014 Scion FRS Monogram W/O 6mt
Looks great!
detainu is offline   Reply With Quote
Old 08-21-2012, 02:56 AM   #49
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
can someone post up some pictures on stock wheels? thanks!
thatWESguy is offline   Reply With Quote
Old 08-21-2012, 03:01 AM   #50
newkid185
Drives: 2013 Scion FR-S Whiteout-M
i m waiting for my eibach prokit to lower 1 inch my frs too. I also replace my wheel an tire from stock to 17x8 OZ aggrellega and 235/40/17 michelin tire. Is it a good combination??
newkid185 is offline   Reply With Quote
Old 08-21-2012, 05:15 AM   #51
newkid185
Also...i m wondering that if i install the prokit, how is the alignment ? do we need to do the alignment? thanks
Old 08-21-2012, 01:34 PM   #52
thatWESguy
Power Ranger
thatWESguy's Avatar
Drives: 86
^^ what's the offset of your new wheels? I'm sure it'll be fine, and anytime you lower your car, you should be getting an alignment.
Old 08-21-2012, 04:22 PM   #53
blkwrxwag
Drives: DS FRS
You need to have your alignment checked for sure. After my install, I was at zero toe all the way around, so I did not adjust it. I have no idea what it was before the install!
blkwrxwag is offline   Reply With Quote
Old 08-21-2012, 07:24 PM   #54
newkid185
Im still waiting for them...what offset u recommend for those wheels and tires???
Old 08-24-2012, 12:04 PM   #55
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
I appreciate if someone could give some impressions on the handling with the Eibach Pro's and stock shocks. Is the advantage of lower centre of gravity killed by the shocks working in a non-optimal area? Can you feel any difference in cornering speed up or down? Thanks!
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 08-24-2012, 12:25 PM   #56
blkwrxwag
Drives: DS FRS
Car feels a little lower and stiffer. Not much, but just a little. No negatives from my point of view.
The Following User Says Thank You to blkwrxwag For This Useful Post:
BAE (08-24-2012)
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! Racecomp Engineering Brakes, Suspension, Chassis 141 10-07-2012 08:12 PM
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 15 07-21-2012 11:46 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 11:04 AM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 02:05 PM
