01-20-2019, 05:20 PM | #15 |
Drives: 2014 Stock frs
Cost of the LS2 and trans.
Buying the wrecked 06 GTO 142,000miles 1 owner $7200. I drove the car 30miles home engine and trans were good. (win) Took LS2, trans, clutch, had tilton 13/16 master with braded hoses (win) Sold GTO rims $500, Sold GTO body$1000 Still have ECM E40,enging harness, GTO pedal and engine and trans mounts for the GTO to sell. Current cost of LS2, trans and clutch $5700 Min cost to convert 24tooth crank to 58tooth for MoteC. Crank, cam gear, main bearings, rod bearings, pan gasket, front and rear gasket sets, rod bearings, $570 (I got a good deal on the unused crankshaft and cam gear) I'm breaking up the engine overhaul separate from 24x to 58x. I took the engine down to bare block took to work and ran though the parts washer light hone the cyl bores. Took the heads down cleaned and installed new valve springs and seals. BTR stage 2 cam kit, ls7 lifters, oil pump, ARP rod bolts, ARP head bolts, ATI damper, updated air bleed kit and other necessary gaskets $2000 After this was done I realized I should have sold my running ls2 and bought a ls3. MoteC $5895. Sensors for MoteC $510 Sold FA20 and trans +$2000 CX racing mounts, headers, y-pipe $1400 Mishimoto rad and fans $588 Aluminum drive shaft local source $350 MagnaFlow exhaust $500 Rough number on misc parts $500 So LS swap no MoteC $9038 plus stand alone harness and vat removal $800. $9838 Minus $2000 for the FA Total $7838 My ls swap with MoteC, engine overhaul, cam kit $18,013 Minus $2000 for the FA Total $16,013 If anyone finds faults with numbers please let me know. Or if any questions. The car is running and driving. Had it tuned still needs more tuning, tuner not familiar MoteC for now making safe 360hp and 340tq at the tire. Starts and runs so far no major set backs. I was happy to drive it before winter came. |
The Following User Says Thank You to Corley For This Useful Post: | Sportsguy83 (01-22-2019) |
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
LQ4 V8 Swap | nmctacticz | Engine Swaps | 42 | 05-02-2017 04:24 PM |
WRX SWAP!!! | PowderfaceTr. | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 02-24-2015 06:29 PM |
Ej Swap | koyv90 | Engine Swaps | 50 | 11-14-2013 07:59 PM |
Looking for an STi Swap | Doug@WGP | NY / NJ / CT / PA | 31 | 11-27-2012 12:54 AM |
