10-30-2018, 11:56 PM | #29 |
Drives: Sapphire Blue ‘23
My car is doing the exact same thing. 2013 with just under 70k miles.
12-31-2018, 04:42 AM | #30 |
Drives: 2013 Toyota 86 (Hot Lave)
Guys, long time no update. Well, some information from my side, two people here in dubai got it fixed a few months back. Apparently, there is a small rubber which got broken in the steering column. Toyota UAE claims it was due to the summer heat. The rubber part is not available so you have to replace the whole thing. The part they got replaced was either SU003-00867 or 34500CA050. Toyota UAE is charging in excess of $1,000 for the part. Damn!
01-03-2019, 08:27 AM | #31 |
Drives: Toyota 86 2013 copper colour, TRD t
Hi Guys,
I have a similar problem in my car. Its not a clunking noise when i drive and turn the Steering wheel. Its basically when i go over some uneven surface like interlocks or even cobble stone it sound's like there is a noise under my steering wheel right above my legs. Anyways when i went to the Garage i checked what the problem was and they told me that the noise was comming from inside the power steering motor as they completely removed the power steering motor and the power steering column from my car, Apparently there is a bush in the power steering motor that is made of plastic or like some rubbery material which was broken apart more like disintegrated and is causing the metal part to hit an other metal part which is causing the noise. I did check with a couple of people and no luck . What i can see are that there are 2 options. Take it to the dealership and get it fixed there which would cost like 7k AED like 2000$ or search for the part in a scrap yard and hope the bush is in a good condition. I even checked on E bay and couldn't find that part as its not sold alone and doesn't have a part number. If you are staying i United states im sure that there would be workshops over that that would be able to custom build that part and help you out with the problem there isnt anything like that in the UAE as i have been to a couple of workshops and no one knew where to get the part from or how to fix the issue. Thanks and BR, Abhinav |
01-03-2019, 08:36 AM | #32 | |
Do you by any chance have the numbers of the guys that got it fixed. I need to contact them and find out how and where they fixed it. Any help would be great. Thanks and BR, Abhinav. |
01-07-2019, 03:51 AM | #33 | |
Hi, they got it fixed from the toyota dealer (Alfuttaim). Check your PM for contact details. |
02-04-2019, 07:17 PM | #34 | |
Drives: Blue
I am not happy about paying to be part of the manufacturers quality assurance testing. But, they are right that the part did fail outside the warranty period. I just wouldn't expect o have this kind of a failure after so few miles Last edited by WebslingerJ; 02-04-2019 at 07:18 PM. Reason: add info |
02-12-2019, 09:41 AM | #35 |
Drives: gt 86
Hi. Did you sort this problem. I too had the same problem. I found out what it was .. it's a flexible rubber coupler that has disintegrated inside the electric power steering motor.
Don't know how to attach a picture of it here. |
The Following 3 Users Say Thank You to gt86gh For This Useful Post: |
02-12-2019, 01:28 PM | #36 | |
When I attach pictures I usually upload the picture to imgur.com and then paste the link to the image in my post. |
The Following User Says Thank You to ermax For This Useful Post: | T0rt0r0 (02-12-2019) |
02-15-2019, 12:55 PM | #37 | |
I found a video talking about this problem on the Corolla. Unfortunately it's in Russian and doesn't translate well. From what I understand there is a rubber ring around this bearing and you can shim it up with plastic to solve the knocking sound. I am going to try and work on mine this weekend and will report back if I find a fix. There seems to be a lot of talk about this problem on various Toyotas with EPS but it's all in Russian and it's hard to understand the bad Google Translations. I guess they have a lot of bad roads over there which destroys the EPS rapidly. There is a hot Russian girl at my office that I am going to ask to help translate for me. Edit: I'm feeling good about this now. I found several more Russian articles on fixing this. Most of them involve popping that cap off the end of the motor, stripping the old rubber out and then replacing with new ruber. The fix will only require a flat head to pry the cap off, scissors to cut some ruber and a hammer to put the cap back on. Last edited by ermax; 02-15-2019 at 02:52 PM. |
The Following 3 Users Say Thank You to ermax For This Useful Post: |
02-16-2019, 01:19 PM | #38 |
Electric Power Steering (EPS) noisy
Making progress. When you pop this cap off it looks exactly like the other Toyota EPS units. My first experiment was to cut a wedge out of wood and then drive it up in there between the bearing and the outer housing and then took it for a spin. The rattle is completely eliminated the only problem is the steering wheel no longer returns to center. I pulled over and removed the wooden wedge and the steering was back to normal and the rattle returned only worse than before because the rubber ring was no longer in there. So the next plan is to cut some slivers of plastic out of a milk carton and then shim it between the rubber ring and the outer housing.
Okay. Have some shins cut. Now if I can get them crammed up in there. Last edited by ermax; 02-16-2019 at 01:31 PM. |
The Following 4 Users Say Thank You to ermax For This Useful Post: |
02-16-2019, 01:43 PM | #39 |
Drives: European gt86
Great !
Waiting for the next step to be tested |
02-16-2019, 01:58 PM | #40 |
義理チョコ
02-16-2019, 02:36 PM | #42 | |
It looks that way but I am having a hell of a time finding something that is just the right size to cram in there. I’m about to make a run to Home Depot. It’s hard to get my micrometer up in there but it looks like 30.5mm OD and 1.5mm thick. I tried one layer of milk carton but that didn’t work and I can’t seem to get a second layer in there. I also cut some rubber off a hose and wedged it in on one side so it forces the bearing off center similar to how the wooded wedge did. It didn’t work though. So far the only thing that has worked is the wooden stick but it has major side effects. I think this can be fixed with the right material. Luckily it’s easy to access without taking the car apart. It’s just a bitch working on your head. Especially when you are hung over. |
Similar Threads | ||||
FS: OEM Electric Power Steering Column, with Motor and Module | MicheleAbbate | Interior Parts (Incl. Lighting) | 12 | 12-31-2018 03:47 PM |
Recall for Electric power steering (EPS) | tm86 | AFRICA | 36 | 05-16-2017 07:04 AM |
Electric Power Steering | ArtS | Electronics | Audio | NAV | Infotainment | 0 | 10-31-2016 08:19 AM |
Electric Power Steering control module? | slicktop | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-21-2013 08:38 PM |
Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
