Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-17-2015, 12:12 PM | #1 |
Drives: 14 WRB BRZ
Dome light flashes on door setting
My dome light when out on "door" just constantly flashes if I put it on "on" it stays on solid. Any thoughts?
11-18-2015, 06:41 PM | #2 | |
Drives: WRB Subaru BRZ Limited 6MT
1) Have you done anything to the electrical system recently? In particular, anything with the rearview mirror harness (e.g. BlendMount tap), changed the dome light bulb, installed an alarm system, changed anything in one of the fuse boxes (esp. the one under the steering wheel)? 2) Are any other interior lights flashing? Is the door ajar light (on the dash) staying on with the doors and trunk shut? Is the door ajar light flashing with doors and trunk shut? |
02-28-2020, 03:03 AM | #3 |
Drives: 2013 Asphalt FRS
Did anyone figure this out?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
02-28-2020, 11:14 AM | #4 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (02-29-2020), spike021 (02-29-2020) |
02-28-2020, 01:12 PM | #5 |
That trunk monkey is pissing me off lol
The Following 3 Users Say Thank You to FRS Justin For This Useful Post: |
02-28-2020, 02:04 PM | #6 |
Drives: Subaru BRZ
The Following 2 Users Say Thank You to JD001 For This Useful Post: | humfrz (02-28-2020), soundman98 (02-29-2020) |
02-28-2020, 05:20 PM | #7 |
Take apart the dome light. You’ll see the back of the dome light knob has a metal strip on it which corresponds to the 3 thin metal “fingers” that power the 3 dome light settings. I think over time these metal fingers get bent with use of the knob, so bend them back into place so they have a tight contact with the metal strip on the knob.
02-28-2020, 08:04 PM | #8 |
This is a different issue as its being controlled. If you hook up techstream you can see the light being activated.
Similar Threads | ||||
Engine oil light briefly flashes after start up | shu5892001 | Issues | Warranty | Recalls / TSB | 6 | 09-24-2014 12:52 PM |
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light | F1point4 | DIY (Do-It-Yourself) Guides | 9 | 03-25-2014 09:39 PM |
Door does not trigger dome light | modena | Issues | Warranty | Recalls / TSB | 24 | 03-17-2014 06:27 PM |
FS: Cool White LED Lighting (dome, door, and trunk lights) | fourvalleys | Interior Parts (Incl. Lighting) | 0 | 11-18-2013 06:55 PM |
Interior Dome Light in DOOR mode works in reverse! | shaoster | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-07-2013 01:37 AM |
