Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
01-06-2013, 08:10 AM | #1 |
Drives: Toyota 86 GTS Man
interior light DOOR mode not working
does anyone know how to remedy the interior map light not working when in DOOR mode? it turns on when i switch it to ON, but doesn't seem to function when left in opening the doors in DOOR mode. I suspect a blown fuse, but i can't seem to find the correct location from the manual. Thanks in advance for your help.
01-06-2013, 01:27 PM | #2 |
Drives: 2013 WRB BRZ
I don't think the DOME light fuse in the relay box in the engine bay is the problem.
The wiring diagram (page 76 of BRZ wiring manual) shows it feeds off a signal from the main ecu to the door switch to the dome light for the door mode. IF the fuse was a problem at all then it would not work in direct on mode either. I would be tracing down the door switch and lastly the main ecu signal. Possibly even the wiring in the dome light if there was any disassembly such as installing a homelink dimming mirror. |
01-06-2013, 03:00 PM | #3 |
Custom User Title
Drives: Asphalt FR-S MT
Take it to a dealership. That's what a warranty is for.
01-13-2013, 03:36 AM | #4 | |
Drives: 13 CSB BRZ Ltd
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
10-28-2014, 04:31 PM | #5 | |
Drives:
Regards |
10-18-2017, 02:47 PM | #6 |
Drives: GT86
Hey Guys, i have the same issue! it seems like that on the power cable from the door is only 5V ! anyone have an idea what to do or where the issue is at...?
thanks in advance |
11-29-2019, 12:50 PM | #7 |
Drives: Gt86
Hi guys. i do have the same problem here with my dome light.
Was my mistake and i shortcircuit the dome light. Pluged the laptop to delete the dtc code, but since then only works when is the on position. If i put the door position wont came on at all. Anyone knows how to fix it without changing the ecu? |
12-04-2019, 01:23 AM | #8 |
Drives: 2017 Toyota 86
Stupid question but you know its a three way switch right?
12-06-2019, 05:24 PM | #9 |
Drives: Gt86
12-22-2019, 03:52 PM | #10 |
Drives: Gt86
Anyone know how to solve this??
12-24-2019, 05:51 PM | #11 |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
The door setting is directly ground controlled by the ECM. The dome light uses the same positive circuit in all positions. So if it lights up when switched to 'On' but doesn't work on 'Door', then it's either a problem with the wire going from the dome to the ECM or inside the ECM itself.
01-24-2020, 03:10 PM | #12 | |
Drives: Gt86
Need to have a better look. |
Similar Threads | ||||
Third brake light not working....what should i do before bringing it in? | Hotlava86 | Issues | Warranty | Recalls / TSB | 11 | 03-10-2016 12:12 PM |
Door Ajar Light will not turn off | Aznek | Issues | Warranty | Recalls / TSB | 15 | 02-02-2015 09:40 AM |
help! reverse light not working | nab335 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-14-2013 05:59 PM |
how to turn that rear triangle reflector into working brake light | chris's fr-s | DIY (Do-It-Yourself) Guides | 29 | 06-10-2013 07:25 AM |
OEM Fog Light install! ON and working! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 38 | 07-04-2012 07:11 PM |
