Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-26-2021, 02:14 PM | #1 |
Drives: 2017 860 Halo White
Steering Issues after minor Collision
Hello all
Last weekend during the storm my 86 hydroplaned in a roundabout and the front right wheel hit a curb bending the control arm (Which I have now replaced), along with that, I had gotten an alignment done yesterday. Post all of this, I have been having some issues with my steering on the right side, this side feels heavier to move, and when turned and letting go of the wheel, the wheel will not return back to the neutral position and stays turned (doing a little wobble). Furthermore, when in the neutral position, if you pull down slightly and release, the wheel will wobble (Video attached). Wondering how I should go about getting these issues resolved. Thank you!
(link to the wobble)
06-26-2021, 02:28 PM | #2 |
Drives: 2013 FR-S Series 10
did you inspect the wheel and tire ?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
06-26-2021, 02:46 PM | #3 |
I recommend inspecting the outer tie rods
06-26-2021, 03:42 PM | #4 |
Yes, the rim wasnt bent and the tire was still in good shape
06-26-2021, 03:42 PM | #5 |
06-26-2021, 04:07 PM | #6 |
I attached 2 images I took of the tie rods, anything look off?
06-26-2021, 09:01 PM | #7 |
Drives: 2013 frs base
Did you re-balance the wheel after the accident?
06-26-2021, 10:21 PM | #8 |
06-26-2021, 11:01 PM | #9 |
I'd suggest you rotate the wheels (front to back) just to insure a wheel/tire isn't causing the problem.
If that doesn't do it, I'd suggest you have the right front wheel bearing and assembly inspected closely. |
06-27-2021, 12:59 PM | #10 | |
has a funny hat
Drives: 2014 BRZ Limited
Personally, I’m concerned about the multiple shiny threads on the tie rods. Requiring that much lengthening to correct the toe makes me think you still have bent/broken parts under there. Strut, spindle, steering rack, subframe have it all checked. Also, as previously suggested by another, have the wheel rebalanced if it hasn’t been. And, remove the tire from the rim and have both inspected if that wasn’t done as well. |
The Following 2 Users Say Thank You to pope For This Useful Post: | Turdinator (06-27-2021), x808drifter (06-27-2021) |
06-30-2021, 08:35 PM | #11 |
07-05-2021, 09:21 PM | #12 | ||
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Now, about the original issue (s). A wheel balancing is ALWAYS recommended after a hit even if nothing seems visually bent. As for the steering effort, well... Quote:
Similar Threads | ||||
Steering column issues | kkronja | Issues | Warranty | Recalls / TSB | 3 | 11-18-2020 04:39 AM |
Minor issues after J02 recall... | nextcar | Issues | Warranty | Recalls / TSB | 3 | 11-13-2019 05:31 PM |
First BRZ Collision? | DjDATZ | BRZ First-Gen (2012+) -- General Topics | 17 | 07-09-2012 10:11 PM |
got into my first collision | statuskuo | Off-Topic Lounge [WARNING: NO POLITICS] | 48 | 02-14-2012 04:19 PM |
Steering Issues? (Toyota Recall) | Buggy51 | Other Vehicles & General Automotive Discussions | 8 | 11-10-2011 02:07 AM |
