Old 07-08-2015, 12:07 PM   #365
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Yeah, I always thought Full-Race was a bigger company since they have been in the Honda turbo game for as long as I can remember back to when I couldn't afford a Full-Race manifold, but I would have loved one. I came to find out they really aren't that big of a company and are kept quite busy. In the end I favored a low side mount configuration which Full-Race and Full Blown didn't provide.
Always though full race was huge, I guess from seeing their evo and s2k work like you said. Let's see what comes from this, still have my JDL and happy too, just wish things would have been better addressed or at least communicated. Oh well, that's how new business is earned and old business lost. Same upgrade I was getting found it else where, minus the oil cooler which I'll in turn get the full blown.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 07-08-2015, 12:10 PM   #366
yomny
yomny's Avatar
Originally Posted by erok81 View Post
Like everyone else said, just keep the kit. I can see you are pissed, but getting of the kit out of spite isn't the best idea. Unless you are Kanye West.
The communication definitely sucks sometimes from the, but they kits are really good. And yours is already installed. I've compared mine to some other local kits and the jdl one is better.
I agree lol and no i wish I was Kanye(Kim,Kim,Kim) lol. I have to agree after al I chose the kit for a number of reasons. The thing is when you want to upgrade, get more custom work and your provider does need or care for your business then you simply find another one. Got a guy here on the forum that does exquisite fab work. The problem is that this time the communication issue caused me to be short 2300, parked car and waiting on a refund so that's when I draw the line. Thanks for the advise man, it all really helps when my head is steaming, specially when it got me thinking of Kim lol.
Old 07-08-2015, 06:49 PM   #367
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
So are precision turbos just bad then? I don't think I've ever read anything go wrong with a Garrett turbo. @King Tut did you run a garrett turbo?
Alltezza is offline   Reply With Quote
Old 07-08-2015, 07:03 PM   #368
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Gtx is preferred do to the water cooling and ball bearing but that doesn't mean pte is bad. It all depends on the power ur trying to make
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 07-08-2015, 07:05 PM   #369
yomny
yomny's Avatar
Not sure if they're bad but I know Garret is better and my precision and another member here with the same setup were leaking around the same area. Currently dealing with their warranty services so I'll be able to tell you if that's bad or not.
Old 07-08-2015, 07:36 PM   #370
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
The only times we have had to send back PTE turbos they have all been journal bearing models. We always recommend a call bearing unit if you can afford it (Garrett or PTE)
JDLAutoDesign is offline   Reply With Quote
Old 07-09-2015, 01:13 AM   #371
Alltezza
Alltezza's Avatar
Lol thanks everyone, sorry for my ignorance. I just wanted to know, what to look out for if I was to purchase a turbo.
Old 07-09-2015, 08:37 AM   #372
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
It's alright. If you wanted to learn more about turbos and their applications, Garrett's website has good information on everything for turbos (Ball bearing vs journal, water cooling, A/R ratio, etc).
Take a look if you're curious.
Rybot is offline   Reply With Quote
Old 07-09-2015, 09:50 AM   #373
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My opinion is that Precision turbos are great for drag cars or high horsepower cars where frequent rebuilding is common. I love seeing them on the front ends of the cars on Street Outlaws (Discovery Channel show). I don't think they are designed to be run on cars for 100,000 miles without issue like the Garrett turbos are. I have only ever owned three turbos:
Garrett T3/T4
Garrett GT2871R
Garrett GTX3076R
I might be a little biased.
Old 07-09-2015, 09:59 AM   #374
Rybot
Rybot's Avatar
Garrett T3/T4
Garrett GT2871R
Garrett GTX3076R
That makes sense. Simple design allows for ease of maintenance and install but falls short on the longevity department.
All it took for me to choose a Garrett was the water cooling. It really increases longevity when things are meant to be kept cooler.
Old 07-09-2015, 10:59 AM   #375
yomny
yomny's Avatar
Garrett T3/T4
Garrett GT2871R
Garrett GTX3076R
This is my personal opinion as well, plus you don't see many PTE oem turbo's.
For discussion sake, what you do guys think about their new BB air cooled? Supposedly using ceramic ball bearings reduces the the "need" for water? Would our platform(or any other with a turbo in a tight space, which usually is the case) have adequate airflow for their air cooled design to work properly, or does the design doesn't need much air at all moving around the CHRA?
Have to say I'm interested(no water lines) but not sure if its practically the same as their oil cooled only units.
Old 07-09-2015, 11:00 AM   #376
yomny
yomny's Avatar
That and could avoid overheating the center housing after shutdowns lol and causing the drain flange to leak.. just kidding as this is not a fact but it always makes me wonder.
Old 07-09-2015, 11:10 AM   #377
Rybot
Rybot's Avatar
While BB turbos don't need as much cooling due to less contact friction at the same RPM, air cooling is a fickle design.
For an air cooled design, ducting would be necessary for proper cooling. Most things air cooled need to have things designed around them to be effective rather than throwing in water cooling and not having to worry about air flow in the engine bay.
Old 07-09-2015, 11:12 AM   #378
Rybot
Rybot's Avatar
Yeah, heat soak is the main reason I'd much rather have water cooled than oil only. That and I still plan on DDing mine, so longevity and reliability are very important.
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
