BT, dpfarr
Old 05-11-2016, 12:06 PM   #1219
GT86Asia
Drives: 2016 BRZ
Originally Posted by B T View Post
looks, didn't have to decrease the pulley diameter to get those numbers?
Right, it's the stock pulley. Mechanic warned, if I want to go to a smaller pulley, then for best reliability, definately should build up the motor. Mainly the rods and pistons and a few other things.
BTW, if anyone is going to the Edelbrock Car Show this Saturday May 14th, I'll be there showing the car. Admission is free. Should be loads of fun!
Cheers,
J
GT86Asia is offline   Reply With Quote
The Following User Says Thank You to GT86Asia For This Useful Post:
CSG Mike (05-12-2016)
Old 05-11-2016, 01:57 PM   #1220
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
So is that 3" front to back with no cat?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 05-11-2016, 10:22 PM   #1221
GT86Asia
Drives: 2016 BRZ
yes it is, 3" from headers to rear tips. There is a small cat inside the midpipe.
My car smells like Kettle Corn!!! Hahahah, that's all I can think about now!!
Freude am Fahren (05-12-2016)
Old 05-11-2016, 10:30 PM   #1222
GT86Asia
Drives: 2016 BRZ
Alright, today I picked up my Supercharged BRZ!
Alright!,
HEre are some photos of the car and setup!
I'll be doing a video edit! and I'll share the link later. Cheers!
The Following 3 Users Say Thank You to GT86Asia For This Useful Post:
Dadhawk (05-12-2016), Kostamojen (05-11-2016), superleggera (05-11-2016)
Old 05-12-2016, 12:21 AM   #1223
GT86Asia
Drives: 2016 BRZ
Talking
HEre is the Video! Yeey!
Phantobe (05-12-2016)
Old 05-12-2016, 09:12 AM   #1224
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Is your air filter resting on the header?
Freeman is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeman For This Useful Post:
ATL BRZ (05-12-2016), brandonblt2 (04-20-2020)
Old 05-12-2016, 09:47 AM   #1225
kamikaze7
@CSG Mike
Can you please update the first post and remove the Mishimoto oil cooler as a confirmed fitment with this kit? I ordered the kit based on this info only to find out it doesn't fit and don't see the need for others to go through this as well.
What oil cooler kits are people using with the Edelbrock kit? I was going FA20DIT route but keep reading it's not sufficient even for occasional track duty.
kamikaze7 is offline   Reply With Quote
Old 05-12-2016, 10:24 AM   #1226
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Originally Posted by GT86Asia View Post
Alright!,
Dude...
You should really take some intake air temperature logs....
The Following 7 Users Say Thank You to ATL BRZ For This Useful Post:
BigFatFlip (05-12-2016), brandonblt2 (04-20-2020), byun (05-12-2016), ML (05-12-2016), Phantobe (05-12-2016), R2 (05-12-2016), Silverfox (06-08-2016)
Old 05-12-2016, 02:01 PM   #1227
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The following oil cooling setups are being done or have been done:
1. DIY lines and brackets for a large Setrab core. There is an awesome writeup for one.
2. Perrin Oil Cooler. with some possible relocation, but the core is fairly small.
3. Jackson Racing Dual Radiator/Oil Cooler.
CounterSpace Garage is offline   Reply With Quote
Old 05-12-2016, 02:15 PM   #1228
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Alright!,
...so can you make 300whp with the hood closed?
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
Old 05-12-2016, 02:22 PM   #1229
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Unfortunately, nothing that is a "direct bolt-on" solution for our kit. Everything mentioned previously had to be modified one way or another, apart from the JR radiator, which no one has posted on fitment yet. Depending on your intended use, you also have the Forester OEM oil cooler as an option, which maybe a much cheaper route.
I, myself, had to build my own custom cooler set-up. Did a track day on Monday and was holding steady at 210-220 F as it warmed up in the afternoon (granted, it was relatively mild, about 75F). In the end, it wasn't cheap and it was a huge pain in the ass, but a fun project and well worth it. (thanks to @NotSoJDM for the idea!)
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
clayrush (05-12-2016), NotSoJDM (06-24-2016)
Old 05-12-2016, 02:25 PM   #1230
BigFatFlip
BigFatFlip's Avatar
On a separate note, has anyone done a boost gauge install? I know somebody mentioned there was a 1/8 NPT port in the back of the manifold that can be easily tapped for manifold pressure.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 05-12-2016, 03:49 PM   #1231
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Yes, I would like an answer to this, too! Just thinking about this as I would like to monitor it just to ensure those seals are good.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 05-12-2016, 04:26 PM   #1232
BigFatFlip
BigFatFlip's Avatar
@NotSoJDM was that you who did a AEM boost gague?
I've been making due with Torque App but find it a bit lacking and little late to react/display data. I know it seems a little dumb to have a boost gauge for an SC since its basically dependent on rpm, but I think our set-up is a special case. The by-pass valve is very dependent on your throttle input, so if you are on partial throttle, you are probably not on boost.
paiceyfan (05-12-2016)
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
