10-28-2017, 10:18 PM | #2577 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | shr133 (10-29-2017) |
10-29-2017, 04:31 AM | #2578 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
@shr133 just interested to know why you want to tune yourself... isn’t this 1 of those things best left to those with experience?
Don’t know anything about you of course, so just asking.
I like driving!
10-29-2017, 05:17 PM | #2579 | |
Drives: 2013 FRS
The only problem is building a map from scratch will be very time consuming. Plus each tuner has his own philosophy and they don't spend much time on the whole map and tune extra safe... Plus I don't want to pay for every tweak... Like if I want to adjust my torque maps, set up a traction control map, set up some custom maps and map switching...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
10-29-2017, 05:26 PM | #2580 |
Drives: 2013 FRS
That's what I figured, hoping someone had just a base safe map to start with..
That's one of the reasons I'm going supercharged, should be much easier to set up. I'll have to call some local tuners, but looks like I'm on my own.. Well I have all winter to work on it... I'm too hands on to have a caned map that's locked..
10-30-2017, 03:03 AM | #2581 | |
10-30-2017, 10:45 AM | #2582 | |
I like driving!
The Following User Says Thank You to 86 South Africa For This Useful Post: | shr133 (10-31-2017) |
10-31-2017, 12:50 AM | #2583 | |
Drives: 2013 FRS
So now it's time to go to the next level, although I'm still debating if I should convert to E85 first than add the supercharger or just go for it during my winter up grades.
The Following User Says Thank You to shr133 For This Useful Post: | CSG Mike (11-01-2017) |
11-01-2017, 10:46 PM | #2584 | |
I'd recommend doing the E85/flex tune while NA to reduce risk and also learn how ethanol affects everything, as well as getting your cold starts down, before going FI. In some ways, it's similar to tuning methanol, and when you have to make compensations that work across a range of gasoline and ethanol, it gets a bit more complicated |
The Following User Says Thank You to CSG Mike For This Useful Post: | shr133 (11-02-2017) |
11-02-2017, 10:17 PM | #2585 |
Drives: FRS hot lava
Any one have problem with belt squeal at start up? I have a conti belt.(only 2k on it) Just started after I put in my built engine. All the pulleys seem lined up correctly belt seems a little loose between the a.c. and water pump (longest run). Also it was on the car when last motor blew.
11-02-2017, 10:58 PM | #2586 | |
Drives: 2013 FRS
12-21-2017, 01:42 PM | #2587 |
Drives: 2017 BRZ Premium
Any news and questions...
Any news on th 2017 kit?
Is the jackson racing combo radiator the best cooling option? Works well with stock fans and lower temp tstat? Is a clutch needed for daily+spirited+trackdays? Cant wait for the kit to be released!!! |
12-21-2017, 04:49 PM | #2588 | |
A clutch is not needed, unless you're going to also run E85 with the kit. The JacksoN Racing DROC is the easiest and cost effective solution. Anything else will cost more. I recommend you PM and get your kit ordered so you can get in on the first batch the day it's released. |
12-25-2017, 01:54 AM | #2589 |
Sent you a PM Mike. Hope to order soon.
12-27-2017, 12:55 PM | #2590 |
Drives: Brz
Good thread.. I am currently on page 50.. slowly reading through the whole thing
Anyone knows if the kit would work on 2017 BRZ? (I am in Canada) Thanks |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
