04-26-2018, 01:17 AM | #267 | |
Drives: Q5 + BRZ + M796
04-26-2018, 01:42 AM | #268 | |
Drives: GTS 86
04-26-2018, 02:31 AM | #269 | |
For a car, the coolant is pumped via the water pump constantly through the engine. When the engine gets hot, the thermostat opens so hot coolant can be cooled via conduction at the radiator. Some external oil coolers have a thermostat, so that cool oil isn't circulated through the cooler when it is cold, which could delay getting the oil up to proper operating temperature, or it could keep the oil too cold and thick for those living in areas where the winters get colder. The JR setup doesn't have a thermostat at the cooler says you, so oil is constantly being sent to the cooler. This may not be a problem for those in cooler climates for the winter months because the warm coolant will keep the oil at a regulated temperature. Here is my point: the Forester XT regulator circulates coolant from the block or central system to the regulator. It doesn't pull any coolant from the radiator side. With the XT regulator, when the engine is cold and warming during initial driving, coolant raises in temperature faster than oil raises in temperature, which will help to warm the oil and get the car up to proper operating/racing temps faster. This is good. The JR setup won't do this because when the car is cold the thermostat is closed, so water is just sitting in the radiator, not circulating, not getting warm. So the idea is that the Forester XT setup helps to get the oil warm and keep it cool. The JR setup just helps with cooling, much better cooling, so that is why I would keep both. |
04-26-2018, 03:09 AM | #270 |
Drives: 2014 GT86
Irace86.2.0: i might be wrong, but doesn't water temps rise even faster then oil ones and in this case even without thermostat won't oil temps in cold weather/cold temps with JR dual-rad rise quicker then with thermostat in forester heat exchanger? Thus having no thermostat might be even beneficial, as one less part to fail and less expensive kit cost then might be, and adding thermostat will even slow down oil warming up, as path to rad with hotter water will be closed off for oil until oil itself warms up?
04-26-2018, 06:18 AM | #271 | |
Drives: Toyota GT86
04-26-2018, 08:59 AM | #272 |
Only users lose drugs.
Drives: All the time
Correct. And it evaps even quicker at 210F. So as I already said, getting the oil up to temp faster is more beneficial.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
04-26-2018, 01:19 PM | #273 |
Drives: 2017 DGM BRZ PP
From the bit of driving I've done I haven't noticed a much longer warm up time, but I don't have any data to back that up. It's possible it's longer but for the typical driving I do it hasn't made enough difference to notice so far. Once the engine is warm though, the oil temp has almost perfectly pegged the coolant temp, sitting 185 -195 F.
The basic mechanics suggest the oil isn't being warmed until the coolant comes up to temp, but once the coolant is hot and opens the thermostat, the oil is then warmed and quickly matches it (from my short experience). I think depending on the ambient temperature and how the car's being driven (both speed/air flow and engine load) the oil warmup may be slower or faster than without the cooler. We'd need some pretty thorough test methodology to really understand all of the variables. I personally think in the majority of cases it's probably not a large enough difference to worry about. |
04-26-2018, 11:36 PM | #274 | ||
Drives: Toyota GT86
There is a video on youtube with someone installing a Forrester heat exchanger. He made video with oil temp overlay before/after - there was no mentionable difference in the time it took to heat up. If you get that much water in your oil that is such a big problem, you need to check you head gaskets...
04-27-2018, 01:32 AM | #275 | |
How much it matters or to what difference it makes, I don’t know. |
04-27-2018, 08:08 AM | #276 | |
Ahh - YouTube....home of everything true and unbiased. I'm pretty sure I could post a video on YouTube 'proving' my car gets 100mpg.
04-27-2018, 08:47 AM | #277 | ||
Drives: Toyota GT86
When the coolant reaches 89 deg C there is a whooping 4 deg difference in oiltemp. Quote:
04-27-2018, 08:55 AM | #278 | |
I'm happy you feel confident that you 'debunked' a well engineered factory component, which many manufacturers use on both F/I and N/A applications. Maybe you should let them know.
04-27-2018, 10:09 AM | #279 | |
Remember, oil temp is directly related to RPM, and our version of the FA20 revs just a wee bit higher than an EJ or FA20DIT. The OEM cooler isn't able to keep up, at all, in this application. |
The Following User Says Thank You to CSG Mike For This Useful Post: | gtengr (04-27-2018) |
04-27-2018, 10:12 AM | #280 |
Drives: frs
Similar Threads | ||||
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 05:35 PM |
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 11:26 AM |
Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 02:00 AM |
Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 11:04 AM |
