go_a_way1
Old 09-23-2015, 11:49 AM   #911
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by jrockeezy View Post
Hello long time lurker here, so i'm planning on going to my first drift event; DDay56 at USAIR. BRZ is stock except for a track pipe and drop in filter.. Originally never thought I'd take this to a track but it's too fun to drive and Final Bout was insane.
Few questions:
- How many sets of tires should I expect to go through? Looking at some spares and sets of OEM wheels I might pick up. And knowing the lack of power..
- What are some decently priced helmet options?
- Things to expect at my first time at the track? Very new to the Chicago drift scene and there's gonna tons of experienced drivers lol
- Recently changed oil with OEM fluids, should I upgrade to something better?
I'm going to reply in here as well too.
Depending on the track layout and how long it is, chances are you will barely burn through a good set of tires with lots of tread on them.
Get an SA2005/SA2010 helmet, just about every organized racing event requires them (aside from some of the smaller grassroots events) ZAMP makes one thats pretty popular for those not looking to spend a lot of money
http://www.saferacer.com/zamp-racing...-racing-helmet.
Expect to spin out a lot. Don't worry about what anyone else thinks. Anyone whos driving at these events was in your shoes once, and I've never met a driver that did not have something nice/helpful to say at the events ive been to. If anyone talks shit, its usually someone sitting on the sidelines watching and think that because they watched the drift bible once they are experts, even though they have never actually drifted. It may take a few events to really get the hang of it, everyone is different. As long as you're having fun thats all that matters.
Don't be afraid to ask for rides with a better driver and watch them, also don't be afraid to have someone ride with you and watch you and give you tips.
OEM Fluids are fine. The only thing I run differently is I use Penzoil Platinum ultra for my oil..
Shady195 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shady195 For This Useful Post:
shifter907 (09-23-2015), Skidrcn (10-10-2015)
Old 09-23-2015, 01:13 PM   #912
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Few questions:
I will chime in as well!
Enjoy your first Clubfr DDay! Also don't be nervous everyone is very chill and friendly. If you need any help, there are several experienced drivers that will be able to give you some tips and pointers.
Oem fluids should be fine! But I suggest Motul or Amsoil
I suggest bringing a full set of spares. You will be starting off at the skid pad and that tends to eat tires the quickest but learning the basic fundamentals is a must!
Also don't forget to pull your abs fuse!
We do have some helmets in stock! Just stop by the shop and we'll be able to fit you as well!
Touge Factory
2181 Foster Ave.
Wheeling IL 60090
Touge Factory is offline   Reply With Quote
Old 09-23-2015, 07:54 PM   #913
slava
slava's Avatar
Drives: brZed
Few questions:
Yo!
-find out of there will be tire changer there (probably will be). one extra pair should be fine, but id bring two to be safe. buying oem wheels is a waste unless you can find them for practically free with tires on craiglist, use tires and resell wheels for dirt cheap.
-Definitely check in with @Touge Factory for helmet, fluids (I use Motul everything), and anything else you need. I know you're in the area but not sure if you've used them before. Seriously some of the nicest coolest people work there and they really know what they're doing. Everyone local supports the shop, and the shop supports the local drift scene, which is not typical with my experiences in other states. Their prices are very competitive as well. Also Mike at TF owns an FRS and hes great to talk to about setup and the order in which you should upgrade the car.
As said, pull ABS fuse, doing anything else (pushing tc off button or pedal dance) is a waste of time. For your first day don't worry too much about figuring things out, just focus on getting to know your car and getting plently of seat time. The car is snappy from the factory, use the handbrake to slow down transitions if you tend to spin a lot. Definitely get some ride alongs, Griff might be there and hopefully Josh can give you some tips too, he used to own one.
slava is offline   Reply With Quote
The Following User Says Thank You to slava For This Useful Post:
shifter907 (09-24-2015)
Old 10-06-2015, 08:00 AM   #914
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Originally Posted by iamhubert View Post
I would also recommend taking off the front sway bar to get the full use of the Megan inners
Thank you for this advice. It finally fixed my transitions. Now I only need a way to fix the increased body roll
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 10-06-2015, 07:47 PM   #915
Chillemall
Drives: Raven FRS
Get higher spring rates for the fronts
Chillemall is offline   Reply With Quote
Old 10-08-2015, 01:14 AM   #916
jrockeezy
Drives: 2014 BRZ Limited
Really appreciate all the responses! @CarzCarzCarz, @TylerLieberman @Shady195 @slava and @TougeFactory. Helped quite a bit getting an idea of how the day will go. Will be stopping by TF some time after work to check out some helmets.
It's a couple weeks away so i'll tell you guys how it went!
jrockeezy is offline   Reply With Quote
Old 10-08-2015, 08:18 AM   #917
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
GT86drifter is offline   Reply With Quote
The Following 3 Users Say Thank You to GT86drifter For This Useful Post:
dori. (10-14-2015), shifter907 (10-08-2015), Skidrcn (10-10-2015)
Old 10-14-2015, 03:56 PM   #918
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
What are your thoughts on the oem rear diff? My tirewear is really uneven. Does anyone here have an aftermarket one?
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 10-14-2015, 10:44 PM   #919
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Think the guy right above you is running a 2-way, at least at the last time we spoke.
Also, has anyone tried Nankang NS-20's? How does the grip level and wear compare to stock? There's a deal on slick deals
dori. is offline   Reply With Quote
Old 10-14-2015, 11:28 PM   #920
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I thought about switching to a clutch type 2 way, but honestly I never felt like I needed it, especially after adding the header and tune.
I ran -1.5 rear camber and the tires always wore out pretty evenly from side to side with very minimal camber wear. One pair of tires would last me nearly a full day at Mineral Wells (70-100mph entry speed).
Tried the Nankangs on one of my 240s back in the day. They were adequate for rears. Trash up front though in my opinion. I liked Kenda KR20, Federal 595, and 595EVO all better than the Nankangs up front. All of which are about the same in price.
Old 10-15-2015, 05:26 AM   #921
dori.
Señor Member
dori.'s Avatar
Should have specified that I just was talking about the rears, I have the Dunlop DZ102 and it has been treating me well.
Old 10-15-2015, 05:11 PM   #922
philstar
philstar's Avatar
Drives: Argento FR-S
So besides all the pro level vehicles running wisefab and such. Has anyone else decided to get rid of the electronic steering rack and opting for a power steering rack from a 240sx, rx7?
Super interested and curious in doing something like this
philstar is offline   Reply With Quote
Old 10-15-2015, 07:51 PM   #923
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
not trying to be a d*ck, just wondering why? its smooth like buttta?!?!
sweetfrs is offline   Reply With Quote
Old 10-16-2015, 10:20 AM   #924
RWDfun
RWDfun's Avatar
Drives: 2015 Asphalt FR-S
Guys from Russia installed from supra.
RWDfun is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 20 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
