MisterSheep
Old 11-16-2019, 06:43 AM   #673
steve99
Drives: FT86
Originally Posted by 6ixfrs View Post
I tried, and i get the error ecu definitions not found.
You may need to edit the def as described in post
Old 01-21-2020, 11:24 AM   #674
Wil
Wil's Avatar
Drives: Drives like a crab.
Hi,
Does this look right to you?
Should I modify Base Timing A as well?
For OFH header + muffler delete.
I'm looking for something very conservative. No POP and BANGS but rather a smooth burble.
Thank you.
Wil is offline   Reply With Quote
Old 01-21-2020, 12:14 PM   #675
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by Wil View Post
Hi,
Thank you.
You don't have to modify the Base timing A, it's only being used when in Safe mode.
I find it better to use the overrun method. Better drive-ability and safer (I think).
I see you're from Belgium as well, don't know if your from the Flemisch or the French part of Belgium. I can help you in Dutch if you want, my French isn't the best.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is online now   Reply With Quote
Old 01-21-2020, 12:18 PM   #676
Wil
Wil's Avatar
Thank you for your answer!
I'm from Liège. I just helped a friend buy his first GT in Maasmechelen last Sunday!
Can you give me a bit more details about the overrun method (in English, I guess ahah), please?
I'm only looking for burbles on decel between let's say 3600-5500 rpm.
Old 01-21-2020, 01:36 PM   #677
elBarto
elBarto's Avatar
Drives: Toyota GT86
I'm just going to quote the original creator, he explained everything.
Pops are controlled with the accelerator, you can change the values (the -4.88) to anything you want. Going positive gives a softer result
Originally Posted by eddieflyinv View Post
@504 @sqd @dhuang finally got around to this.
Just an example of my current settings for overrun, not too much has changed from my previous experiment, mind you im just starting playing with it again
First 3 tables are located in Fueling - Overrun Folder
- Overrun Initial Enrichment @ 1.2
- Fuel Cut Threshold @ 6000
- Overrun Enrichment Activation Delta @ -15
Last 2 Tables found in Ignition Timing - Advance Folder
- Rescaled the Base Timing Idle (In Gear Above Speed Threshold) table, like I mentioned before, my preference was for this to only start occurring when the engine was almost warmed up
- Raised the value in Base Timing Idle Vehicle Speed Threshold table, this helped quite a bit to avoid low speed jerkiness (10km/h because canada)
As mentioned before, may have to play with the amount of Overrun Enrichment and the values used to retard timing in the Base Timing Idle table, previous tunes were Stage 1 with Stock headers and catless overpipe, and with the stage 2 tune and no cats I have reduced Initial Enrichment from 2.8-1.8 to 1.2
Things acheived
- Lots of explosive crackles at high rpm lift,
- Crackles between shifts (with slight delay, seems to be more time related than rpm related, so OL/CL transition delay settings may potentially alter that)
- downshift bangs, lately they seem to be singular (only had this tune up again since last night) but theyre loud, though they are not rpm limited anymore, (never used to get them above 3krpm before)
- feathering popping/crackle, find that spot and it will pop endlessly, often on tip in there is a slight initial crackle, and if you have your cruise on going down hill your car will sound like automatic gunfire the whole way down 🙊 not sure if the tip in crackles can be gotten rid of, seems to be table switching delay so maybe messing with the OL/CL transition delays could reduce or eliminate that as well.
Example of some softer settings:
+10 @ 2500
+5 @ 3500
+2.5 @ 4500
0 @ 5500
Old 01-21-2020, 02:05 PM   #678
Wil
Wil's Avatar
Thanks!
But with that method, I'm going to have crackles all the time, right?
I like this idea of being able to control them with the throttle, actually...
emh... this doesn't look right, does it?
Old 01-21-2020, 02:42 PM   #679
elBarto
elBarto's Avatar
Drives: Toyota GT86
Thanks!
No, you have old definitions.
Since you are using A00G (I have the same cal Id), I've linked updated definitions and a Stage2+ Popcorn tune. Adjust to your liking
A00G Def + Stage2+ Popcorn
Old 01-21-2020, 02:50 PM   #680
Wil
Wil's Avatar
Haven't used ROM Raider for a long time... Thanks for sharing
Old 01-21-2020, 03:07 PM   #681
Wil
Wil's Avatar
In your maps you only modify the base timing idle (in gear) table?
All else is identical to the OTS V4 stg2+ map?
Old 01-21-2020, 03:28 PM   #682
elBarto
elBarto's Avatar
Drives: Toyota GT86
No, I've changed some other settings as well, LC is at 4000rpm, some old Wayno mods, DBW, idle rpm's.
Popcorn tune has the posted settings.
Use the supplied definition to open them.
Old 01-21-2020, 04:59 PM   #683
Wil
Wil's Avatar
Thanks. Can you specify the mods and how they affect the car's behaviour in general? I kind of like the throttle as it is.
(Well, let's resume by PM so we don't pollute the thread too much, haha)
Old 02-28-2020, 11:17 AM   #684
JustunTime
Drives: 2-13 BRZ
Hardly any pops or crackles at -9
I followed the instructions to modify map B and set it at -8 and then -9 (using stage 2 plus AND stage to + E85) and neither give me any significant cracks or pops. Basically NONE. I might hear 2 or 3 low ones on a 20 minute drive. I have the Tomei UEL and nvidia catback... I do have a weaponX intake rather than stock airbox but I cant imagine that the issue...
What to I do?
Oh, I do have the O2 extension in the UEL still... Should I remove that?
JustunTime is offline   Reply With Quote
Old 02-28-2020, 11:44 AM   #685
tomm.brz
Drives: brz 2017 hksv2
put negative timings untill 0.3 of engine load and you will have them
Old 02-28-2020, 02:51 PM   #686
JustunTime
Drives: 2-13 BRZ
Still not getting much that I can hear....
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
