Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
02-19-2020, 02:03 PM | #29 |
Two things, Tcoat, love the first vid of shifting. That was how we were thought on a four speed while racing as your hand position helped get the right gear. Not so good with a six speed.
Any time your are pushing the gear lever against resistance going into a gear you are wearing the syncros. Getting a rev match will reduce wear. It does not apply to racing as most parts are wear items and expected to be replaced. Side note: Complaining about stiff shifting while cold is like saying your steak is tough while eating it frozen. |
The Following 3 Users Say Thank You to ls1ac For This Useful Post: |
02-19-2020, 02:14 PM | #30 | |
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
02-19-2020, 02:46 PM | #31 |
Early 2 1/2 ton dump going up a hill with a load of gravel!!! Do not miss the shift or you start all over.
The Following 2 Users Say Thank You to ls1ac For This Useful Post: | soundman98 (02-19-2020), Tcoat (02-19-2020) |
02-19-2020, 03:11 PM | #32 |
One of the vehicles I learned MT on was a 1952 International dump truck my dad had for a while. Too bad that cell phone videos didn't exist back then because 10 year old me trying to clutch and shift must have been hilarious to watch. I can still hear those poor gears screaming.
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (02-20-2020) |
02-20-2020, 01:13 AM | #33 | |
humfrz |
02-20-2020, 01:30 AM | #34 |
Welp, this is the type of truck I learnt how to shift a vehicle with rubber tires.
1941 Ford 2 ton truck, loaded with hay, going across a rough hay field made for some "interesting" shifts from this kid - humfrz |
02-20-2020, 01:37 AM | #35 |
Drives: Subaru
So is this a thing with this tranny? I thought this was a similar Aisin tranny to the STI’s Aisin, just slightly less robust. Is 2nd gear grind a common occurrence?
Are they like that new or is it a degradation over time as the synchros wear? The times I’ve driven (mostly brand new) BRZs, I haven’t experienced any grind at all. |
02-20-2020, 01:55 AM | #36 |
ProCrastinationConsultant
I think it's a PEBCAC issue.
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | LimitedSlip (02-20-2020), milanojess (02-27-2020) |
02-21-2020, 11:43 AM | #37 |
Drives: 2016 Scion FR-S
With my FR-S the 1-2 shift is the one I have to be extra careful about. Going into 1st can also be difficult. Once the car/transmission is warmed up most of those quirks go away. Many times going into 2nd I can feel the synchros through the shifter. Like actually feel them spinning. This car really connects you to the driving experience.
02-21-2020, 01:22 PM | #38 | |
02-21-2020, 02:05 PM | #39 |
Rust bucket enthusiast
The Following User Says Thank You to DarkPira7e For This Useful Post: | soundman98 (02-21-2020) |
02-21-2020, 08:39 PM | #40 |
Senior Citizen Member
The Following 2 Users Say Thank You to LimitedSlip For This Useful Post: | DarkPira7e (02-21-2020), soundman98 (02-21-2020) |
02-21-2020, 09:19 PM | #41 |
Make sure to take your foot completely off the throttle between shifts. In normal driving, I find that helps smooth out the shifts, especially 1-2.
For high RPM shifting at the track it's not a problem though, only normal driving.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | JesseG (02-23-2020) |
Similar Threads | ||||
2nd Gear Grind | Stonewall | CANADA | 12 | 04-06-2018 01:36 PM |
5th gear grind | Hugo | Issues | Warranty | Recalls / TSB | 7 | 06-08-2016 08:33 AM |
4th gear grind | aaguirre123 | Engine, Exhaust, Transmission | 8 | 08-03-2015 04:58 PM |
2nd gear grind (yup another one) | SmartedPanda | Issues | Warranty | Recalls / TSB | 17 | 09-10-2014 04:02 PM |
4th gear grind | Moetivegt86 | Issues | Warranty | Recalls / TSB | 10 | 03-07-2014 11:50 AM |
