12-26-2019, 10:58 AM | #5251 | |
Drives: '14 BRZ Limited
Initially, my car put down 345 whp but CSG Mike looked at the logs and said it wasn't good a good tune, at the point I had not taken it to the track because of driveability issues. After I switched to Delicious I lost 19 whp but the logs look much better. 4 track days later it's still running. Just because the dyno reads higher doesn't mean the car is running better. We're both giving advice based on experience, I lean towards safety. |
The Following User Says Thank You to peaches For This Useful Post: | tomm.brz (12-26-2019) |
12-26-2019, 01:50 PM | #5252 | |
Drives: brz 2017 hksv2
good! anyway thanks for proving my theory that more boost doesnt necessarily means more power |
12-26-2019, 03:46 PM | #5253 |
12-27-2019, 12:32 PM | #5254 |
Drives: 13 White MT FR-S
When JR says that pulley makes 12psi, is that measured at the MAP, or before the inter-cooler at the recirculator?
12-27-2019, 12:49 PM | #5255 |
12-27-2019, 05:46 PM | #5256 |
12-28-2019, 11:41 AM | #5257 |
Ate my first belt this morning, happened about the same time I saw 10 psi haha. looks like the blower might be sitting to far forward just a hair and caused the belt to rub on the back and then fail....thoughts?
12-30-2019, 05:57 PM | #5258 |
12-30-2019, 05:58 PM | #5259 | |
Also you have the wrong idler on the alternator. |
12-30-2019, 09:24 PM | #5260 |
Are lightweight crank pulleys no good with it? I’ve ran this Perrin one for like 7 years, I don’t even have the original anymore. And the idler pulley was the one the previous owner gave me. It’s exactly the same dimensions as the other one you are referring to.
12-31-2019, 10:27 AM | #5262 |
Nope, I had a similar issue. My belt was shifting, had to buy stock pulleys except for the crank since I have a fluid dampr. Go back to stock components and it should fix it.
01-01-2020, 09:42 AM | #5263 |
Happy new year! Sorry I know I have been asking a lot questions but I have one more: in the JRSC manual it mentions to put a one way valve on the PCV line which I do not have. But I do have a catch can on the PCV line. Do I still need he one way valve?
01-01-2020, 04:47 PM | #5264 | |
pessimistic skeptic
The Following User Says Thank You to mrg666 For This Useful Post: | ML (01-01-2020) |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
