Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-06-2014, 09:29 PM | #15 | |
Drives: Scion FR-S 2013 Raven
Parts Shop Max subframe and differential risers
Yes but I want to say, at the beginning they was soft... Then diff inserts + sub insert will add more NVH compared to sub inserts only... But anyway it's ok, like you say, nothing we can't live with... Thanks!
o= FR-S =o |
The Following User Says Thank You to Mikepage For This Useful Post: | diss7 (04-06-2014) |
04-06-2014, 11:26 PM | #16 |
Drives: Smells like tires when I drive
@diss7
Would your friend be interested in selling a set? I no longer have access to a lathe and am not too keen on welding on the subframe of a car with 9k miles on it. Also, would you mind getting some more pics of the rear bushings where the cover meets the crossmember? It's a little obscured by the swaybar and it's hard to tell how eccentric the new mounting points are. |
04-07-2014, 12:24 AM | #17 | |
Drives: AE86, 2x GT86, TE27
The inserts to the cover are both eccentric. The left one only by a few mm though. |
04-07-2014, 12:30 AM | #18 | |
04-07-2014, 12:51 AM | #19 | |
04-07-2014, 12:59 AM | #20 |
06-04-2015, 05:45 PM | #21 | |
Racing Enthusiast
Drives: Bone stock 2019 BRZ manual
EDIT: I have also heard that shaft spacers would be another, maybe safer solution... but I don't see any on the market yet.
“$20 per diddle? I can diddle myself for free and do a fine job”
06-05-2015, 04:00 PM | #22 | |
i'm sorry, what?
Drives: Canada
neutral axle position is always a concern as an axle moves up or down it grows in length (the hypotenuse of a triangle is always the longest) obviously the axle is designed to function at angles, that is it's sole purpose, but the closer it remains to being a straight shot from the diff to the wheel during the majority of operation, the better. but if you raise the diff... and then lower the car, they equal out, which is the point. what's often the case with lowered cars is that this does not happen, and so the axles start to point up and stay that way for the majority of vehicle operation.
06-05-2015, 04:48 PM | #23 |
CV's are also under more load the greater the angle they're on and more likley to break if you put power through them at extreme angles.
06-10-2015, 10:13 AM | #24 |
Racing Enthusiast
I was asking about the angle of the driveshaft, as a result of using the diff risers to fix the axle angle. Sort of as a side effect of the diff risers. Is that something to worry about?
06-10-2015, 10:51 AM | #25 | |
i'm sorry, what?
Drives: Canada
sorry, when I say neutral I meant static no angle is better than angled, yes.
The Following User Says Thank You to 7thgear For This Useful Post: | AreteAuto (06-10-2015) |
08-30-2015, 11:36 PM | #26 |
Potato Farmer
Drives: #SLOBRZ
Getting them installed as we speak, car is fairly low at the moment with D2 coilovers and PBM lower control arms..
Plus 9.5in wheels..
Something something butter..
www.vic86brzclub.com |
08-31-2015, 05:17 AM | #27 | |
Drives: '14 GT86 project, '13 GT86 DD
Could you please confirm how much the subframe is lifted by and how much the diff is raised. I am making these bushes for my car, and am reckoning on around 15mm for the SF and 10mm for the Diff? I will also be drilling new holes for the inner ends of the front arms, lifting the rack and turreting the top mounts to reposition the front in and back and retain travel on the oh so short rear coil overs.
08-31-2015, 10:13 PM | #28 | |
Potato Farmer
Drives: #SLOBRZ
No measurements as yet, will need to jack it up on the weekend and have a look see. Some pics in here though http://imgur.com/a/v1P6J
Similar Threads | ||||
Parts Shop MAX USA prototyping | philstar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-04-2014 12:14 PM |
Need a Shop for Aftermarket Parts Installation in Portland - Suggestions? | Ammunition | Northwest | 11 | 12-23-2013 02:19 AM |
RallySportDirect 2011 STi Shop Car for Sale. Over 50K in Parts, under 3500 Miles! | RallySport Direct | Cars for Sale/Trade | 14 | 06-21-2013 11:52 AM |
Installing TRD Parts / Locating a good shop | Re~Mix | Engine, Exhaust, Transmission | 9 | 06-12-2012 12:05 PM |
