Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-18-2015, 03:30 AM | #1 |
Drives: 13 BRZ, 18 STI
Which Intake should I get?
Hey guys, just wanted to see if you all could help me decide which intake system I should get. I'm getting ready to have the car tuned, and I figured I might as well get the intake system before I do so I don't have to have it tuned twice.
There are three intakes I have been looking at, which are: -Perrin 3" Big MAF -Grimmspeed -Skunk2 I'm looking to get the most power out of the system that I can, trying to set the car up for SCCA STX, but I'm also going to be daily driving the car during the summer. I like that the filters are easy to access and clean on the Grimmspeed and skunk2, but I've also read that there can be fitment issues between the air box and the oil lines when using an oil cooler. Any insight or opinions you all can provide would be greatly appreciated. Currently I'm running a drop in filter and a perrin silicone inlet hose, along with a perrin 3" resonated CBE. Just ordered some JDL UEL Headers w/o cat and a catted FP/OP (Yay tax season sale!) and will be tuning the car as soon as those get delivered. |
02-18-2015, 03:48 AM | #2 |
Turning is for Nerds
Drives: 35 characters is not enough
Drop in filter and tune, anything else is within margin of error on most dynos. Stock airbox is a well designed piece.
Perrin allows the most room for oil cooler lines. |
The Following User Says Thank You to Decay107 For This Useful Post: | SkAsphalt (02-18-2015) |
02-18-2015, 11:29 AM | #3 |
Drives: rocketship
Skunk2 has their own oil cooler which will fit fine with their intake.
I have my intake being delivered today. Oil cooler will go on in a month or so. |
02-18-2015, 11:43 AM | #4 |
Ridge Racerrrrrrrrr
None of them!
Mic drop
The Following 3 Users Say Thank You to SkAsphalt For This Useful Post: |
02-18-2015, 01:23 PM | #5 |
I'd be careful running the skunk 2 oil cooler in the PNW, no thermostat. Hell even my thermostatically controlled sandwich plate over-cools in the winter (they are never 100% bypassed).
The Following User Says Thank You to Decay107 For This Useful Post: | sachu (02-18-2015) |
02-18-2015, 01:49 PM | #6 | |
Sweeper
Here you go! All the answers and discussion you'll need to make an informed decision. |
The Following User Says Thank You to Koa For This Useful Post: | raven1231 (02-18-2015) |
02-18-2015, 01:49 PM | #7 |
ALL OF THEM!
02-18-2015, 06:47 PM | #8 |
Seņor Member
I have the Grimmspeed intake and am happy with it, I haven't tried the other options however. The Grimmspeed is the only stock sized MAF of the three you listed so MAY cost you a little in the top end but it MAY be better down low. In reality if you are getting a tune you will do well with any of those three.
1974 TA22 Celica
2013 86 GT |
02-18-2015, 08:17 PM | #9 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
They will all make a few HP here and there. I haven't tested the GS one directly, but the skunk2 made about 5 hp, and we have many folks with the Perrin 3" and they seem to do well. IMO the biggest issues with the stock intake are the OEM snorkel in the bumper, and the elbow closest to the throttle body. The s2 intake fixes both of these by using a massive elbow and a replacement snorkel. The Perrin unit is quite nice and I definitely prefer that for FI given the sound with blowers etc....but the aluminum loses out to plastic when it comes to heat retention. And I'm not a fan of the oiled filters. We do have a non-oiled filter that will work with it though, and still fit in the stock location.
So that's my take...frankly those are probably the better of the intakes currently available for the 86 chassis. Quote:
02-18-2015, 08:38 PM | #10 | |
Racecar spelled backwards is racecaR, because RacecaR
02-19-2015, 01:25 AM | #11 |
Drives: rocketship
installed skunk2 intake..did some dyno runs, can corroborate what 3 other dyno charts are saying about the intake.
With the insert in and stock tune picked up 5-6 WHP from stock airbox with drop in filter. will post up dyno charts tomorrow. |
02-19-2015, 01:31 AM | #12 |
Comparing intakes without adjusting the MAF scale is pretty useless.
02-19-2015, 02:14 AM | #13 | |
Drives: rocketship
I know the OFT stage 2 flash removes this torque dip with just my header before the intake was installed, so its a matter of some tuning. |
02-19-2015, 08:12 AM | #14 |
Drives: Fast
I have the Grimmspeed intake and got it dialed in and tuned by Nelsmar. Overall a pretty good intake according to the logs and flow. Much better than the TRD one that was previously tuned and had to compensate for the turbulence because of the larger box.
I'd probably put the Grimmspeed, Perrin, and Skunk2 intakes in the top categories for intakes on this platform right now. |
Similar Threads | ||||
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube | SoCalArgento | Engine, Exhaust, Bolt-Ons | 4 | 02-06-2015 10:40 PM |
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake | eauto | Engine, Exhaust, Bolt-Ons | 299 | 10-15-2014 01:44 PM |
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. | Speed Element | Engine, Exhaust, Bolt-Ons | 14 | 05-20-2013 06:06 PM |
