Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-13-2018, 10:28 PM | #1 |
Drives: 2013 Ultramarine Blue FRS
Engine Cooling options
Hello
I have been taking my car to the track and I have couple questions on engine cooling. 1. after 4 laps the car is at 250 degrees, I don't know if its too hot or not, can somebody tell me @ what temp will it become an issue for our engine? 2. if cooling is needed, should I be looking at a upgraded radiator as well as an oil cooler? what other options do I have? 3. also what brand do most people recommend? Thank you for your help! |
08-13-2018, 11:23 PM | #2 | |
The coolant temperature at 250 degrees F should be OK, as long as the coolant hasn't reached its boiling point. The boiling point is determined by the coolant composition and the pressure the coolant is under. So, with a coolant mixture of 50/50 water/ EG, and at a pressure of 15 psi, the engine should be OK running at 250 degrees F. However, I wouldn't run an engine too long at that temperature. Wait - someone is coming along - humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Magiclow (08-14-2018) |
08-13-2018, 11:56 PM | #3 |
250 oil or coolant temp?
08-14-2018, 10:27 AM | #4 |
08-14-2018, 10:34 AM | #5 |
You need to get that oil temp down. The rad is probably fine.
Give this a read http://www.ft86club.com/forums/showthread.php?t=114293
The Following User Says Thank You to Tcoat For This Useful Post: | Magiclow (08-16-2018) |
08-14-2018, 10:35 AM | #6 |
Drives: FRS
Max Temp
What is the safe maximum, constant, (lap after lap) oil temp for the twins on the track with thicker track oil ?
08-14-2018, 10:39 AM | #7 |
250 would be "safe" but if you are hitting that high on a regular basis then you are running the risk of going over which could be a problem.
08-14-2018, 10:44 AM | #8 |
Drives: 2016 Subaru BRZ
08-14-2018, 10:58 AM | #9 | |
Drives: FRS
What kind of oil pressure drops (in psi) are you seeing at high temp with 20 ? Last edited by RFB; 08-14-2018 at 11:00 AM. Reason: spelllink |
08-14-2018, 11:21 AM | #10 |
08-14-2018, 11:33 AM | #11 |
08-14-2018, 11:56 AM | #12 |
Drives: FRS
08-14-2018, 12:31 PM | #13 |
I hit 250 on every run at Laguna last weekend with my Forester XT oil cooler.
Sounds like we both need something more heavy duty. |
08-14-2018, 01:04 PM | #14 |
i don't think i would use 0w20 on the track m8.
Similar Threads | ||||
2jz to BRZ engine management options?? | Clash0901 | Engine Swaps | 21 | 12-02-2017 11:35 AM |
Smoke testing for FI engine bay cooling | mike the snake | Forced Induction | 16 | 04-30-2014 09:25 AM |
FS: Password JDM Carbon Fiber Engine Cover and Cooling Plates | FRSTRM | Engine, Exhaust, Bolt-Ons | 9 | 03-21-2014 01:22 PM |
New full carbon fiber engine cooling plate from APR | GuerillaRacing | Engine, Exhaust, Transmission | 6 | 01-22-2014 12:53 PM |
Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
