Old 03-12-2019, 08:23 PM   #85
Route
Route's Avatar
Drives: 2007 GT3 | 22' BRZ
Weather started to warm up so I thought it was a good time to take the FR-S into the sunlight.
Stuck on the old TRD shift pattern sticker onto the console plate cover and WC Lathe Werks titanium e-brake button was gifted to me by my friend.
Route is offline   Reply With Quote
Old 03-13-2019, 05:51 PM   #86
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Originally Posted by Route View Post
A few parts arrived in the mail today. TRD rear aero stabilizer, key case for the Corolla, TRD bolts and TRD shoulder pads.
Also installed the door cards to complete the interior for now. Blacked out the speaker rings to match the rest of the interior.
How did you black out the speaker rings?
derekbrz24 is offline   Reply With Quote
Old 03-13-2019, 06:25 PM   #87
Route
Route's Avatar
Blasted it with a few coats of matte black paint.
Old 03-14-2019, 01:07 AM   #88
Route
Route's Avatar
After a 3 month backorder, I finally received my Worksbell Rapfix GTC and hub adapter.
Attached the Nardi to the GTC and EVS cruise control adapter to it to make the install of the whole setup easier when the time comes.
Nardi horn buttons are a pain in the ass to install.
The Following User Says Thank You to Route For This Useful Post:
MCTeeJ (03-14-2019)
Old 03-17-2019, 03:43 AM   #89
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Nice choice in parts buddy
ottoyu34 is offline   Reply With Quote
The Following User Says Thank You to ottoyu34 For This Useful Post:
Route (03-17-2019)
Old 03-20-2019, 02:07 PM   #90
Route
Route's Avatar
Works Bell hub, Rapfix GTC, EVS cruise control bracket and Nardi wheel have been installed.
Feels pretty good but I haven't been able to drive the car much. Horn doesn't work since the connectors on the flipper don't mate up with the OEM horn/cruise harness unless I completely remove the cruise control harness and add the supplied harness. Only one resistor is supplied so my airbag light is on so another resistor is on the way to remedy it.
EVS Tuning adapter brings out the stalk pretty far out and there is a chance that it will hit my leg so take that into consideration if you plan on buying something like this.
TRD bolts have been installed front and rear. They are M6x1 threads so they won't fit on the back unless you tap M6 threads or place an insert which is what I did.
Lastly the Scion key shell was swapped out for the new Toyota one.
new2subaru (03-20-2019)
Old 04-02-2019, 07:38 PM   #91
Route
Route's Avatar
HKS dry carbon intake tube, oil cooler and Cleib exhaust finally arrived.
Had time to finish up the install of the KW Clubsports but with the bipolar weather we've been having here I haven't had a chance to drive it.
The Following 4 Users Say Thank You to Route For This Useful Post:
DaSilva3525 (04-02-2019), DustinS (04-17-2019), MCTeeJ (04-03-2019), new2subaru (05-10-2019)
Old 04-15-2019, 11:37 PM   #92
Scottish86
Drives: 13 BRZ
Love your car and that intake tube is badass!
Scottish86 is offline   Reply With Quote
The Following User Says Thank You to Scottish86 For This Useful Post:
Route (04-17-2019)
Old 04-17-2019, 10:12 AM   #93
Route
Route's Avatar
SPL suspension arms, EVS Tuning front pipe, Verus rear cam plate and the ARP extended wheel studs finally came in. Still waiting for the rest of the parts but at least I can get my suspension and exhaust finished before the season starts.
Picked up some Motul 300V to test out in a 0W-20 since I'm going to be installing the oil cooler this weekend.
The Following 2 Users Say Thank You to Route For This Useful Post:
DustinS (04-17-2019), MCTeeJ (04-22-2019)
Old 04-22-2019, 12:18 PM   #94
Route
Route's Avatar
Headlights, SPL suspension arms, EVS front pipe and Verus rear cover installed.
Old 04-23-2019, 01:46 PM   #95
Route
Route's Avatar
JUN mirrors finally came in. Super easy install and pain in the ass to adjust.
Old 05-04-2019, 01:43 AM   #96
Route
Route's Avatar
Oil cooler install is finally done after weeks of loafting around, Verus carbon sidemarker deletes and some Whiteline bushing inserts have arrived.
When I took apart the intake i forgot to cover the box with something so dust and all that wouldn't get in but I forgot so the MAF is dirty. I'm just assuming this since my car threw a check engine light saying that it is running rich.
Old 05-09-2019, 04:14 PM   #97
Route
Route's Avatar
Little update.
For those with fog lights and are looking to buy this HKS oil cooler it will not clear the turn signal connector unless you buy the harness from the non fog light model. The turn signal connector that connects to the bulb is much longer on the fog light model for some reason and I wasn't able to put the bumper on.
To be honest I have lost motivation to keep the build going as I'm constantly finding small issues like these turning me away from the car. Currently looking at purchasing a new vehicle so we will see where that goes.
Old 05-09-2019, 06:17 PM   #98
StraightOuttaCanadaEh
Wes
Ahh don't be that way. Maybe slow down and enjoy it as is for a little while til the motivation comes back?
But if you do decide to sell, I'd be quite interested in a few of those parts. And since you're local, I'd come by and pick them up.
Instagram: @gt86ws
14r, brz, frs, trd, voltex
My Asphalt FRS Build ZaneRL9 Member's Car Journals 14 06-13-2015 03:38 PM
hattrickey's Asphalt Build hattrickey Member's Car Journals 4 08-16-2014 12:00 PM
asphalt.frs.22's Evil fr-s build asphalt.frs.22 Member's Car Journals 1 05-30-2014 07:21 PM
Opposed Asphalt build Opposed Member's Car Journals 30 01-15-2014 11:03 PM
New FRS Asphalt build. Erik-Frs Member's Car Journals 24 09-18-2013 08:18 PM
