02-10-2024, 07:35 PM | #267 | |
Drives: Crapcan
02-17-2024, 03:03 PM | #268 | |
Drives: 2015 FR-S
02-17-2024, 03:59 PM | #269 |
Drives: Crapcan
You can get complete used FA24’s for about 6500. He just needs the cam trigger wheels from the FA20. 13-16 uses a different style of cam trigger and crank trigger then the 17-20 which is the same as the 2nd gen.
02-17-2024, 05:15 PM | #270 |
Drives: '13 BRZ TLM Spec
That is currently to be seen. Ideally I'd love to be able to use the FA20 valves and springs, but haven't researched at all the specs of each. I want the FA24 heads with the FA24 short block to maintain the proper piston the head clearance and compression ratio. FA20 cam & phazers to keep the computer happy.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
02-17-2024, 08:22 PM | #271 |
義理チョコ
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
02-18-2024, 09:51 AM | #272 | |
Drives: 2013 frs base
I think there a change in some of the rocker arm/valve and maybe cam assemblies in early gen 1's. It may have been done to help eliminate rocker arm ejections. On my rebuild, my motor guy ordered a new set of rocker arms but they didn't match the original ones. He ended up sourcing a couple early rocker arms to replace my damaged ones. If you get 2014-2015 heads, you're prolly be ok. |
The Following User Says Thank You to blsfrs For This Useful Post: | Opie (02-18-2024) |
04-18-2024, 08:51 AM | #273 |
Now that I'm looking at engine/car options.
Is using an FA24 in 2013 FRS as simple as switching the cam phasers, intake, and other external items? What am I missing? |
04-20-2024, 10:32 AM | #275 |
Drives: Crapcan
I don’t think it is going to be quite that simple, but until I get my hands on one I don’t know for sure. There is a lot of misinformation I have come across on the swap.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (04-21-2024), Ultramaroon (04-21-2024) |
04-21-2024, 11:03 PM | #276 | |
I've got the car home now. Next weekend, I'll try to figure exactly what's broke. |
04-21-2024, 11:12 PM | #277 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (04-22-2024) |
04-22-2024, 11:34 AM | #278 | |
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (04-22-2024) |
04-22-2024, 02:26 PM | #279 | |
Drives: X5 35d, D90, CX-5 Turbo
I have to imagine its still quite a bit more difficult (sensors differences, wiring harness/plug differences, etc), but have to admit to being curious..
~Scott T.
'95 NAS D-90 ST '13 BMW X5 35d '22 CX-5 Turbo '?? 86 one day soon? |
The Following User Says Thank You to LRNAD90 For This Useful Post: | blsfrs (04-22-2024) |
04-22-2024, 04:00 PM | #280 |
Drives: None
There are FA24 first gens running around with a variety of sensor/harness configurations at this point, given that people stand to make money doing this the details are being kept fairly quiet. It'll be public eventually.
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
