Old 08-12-2014, 01:08 AM   #29
SnapOv3st3r
Drives: 400whp Scion tC
The sexy has hit an Epic level.
SnapOv3st3r is offline   Reply With Quote
The Following 2 Users Say Thank You to SnapOv3st3r For This Useful Post:
kanundrum (08-12-2014), ptuning (08-12-2014)
Old 08-12-2014, 01:21 AM   #30
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by djliquidsteele View Post
What exactly does this particular firing order do?
A rotational firing order simply means that each cylinder fires through the 4-1 merge collector through adjacent ports on the collector. The cylinders basically fire in a sequence similar to an imaginary 4-bullet revolver. This rotational firing order results in the best possible exhaust gas scavenging effect for the next cylinder in line.
- Toan
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
djliquidsteele (08-12-2014), kanundrum (08-12-2014)
Old 08-12-2014, 01:21 AM   #31
SnapOv3st3r
Saw the Dyno numbers. That's some VOODOO sorcery there....LOVE IT.
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
Old 08-12-2014, 02:16 AM   #32
ptuning
ptuning's Avatar
Drives: White FR-S
It's nice having a dyno inside of an enclosed sound abatement chamber. It allows us to dyno tune round the clock without the cops showing up. Anyhow, as promised, we have dyno numbers for you guys.
Since everyone and their mother runs a header with some sort of exhaust system in place, we decided to do the same. Since we don't offer a 2.5" overpipe or front pipe, we decided to test our header with our 3" header-back exhaust system. This was intended to be used with front mount turbo systems, but the results here weren't too shabby. We just need to figure out what combination of additional resonators and mufflers are needed to keep the volume down a bit.
We kept the variables low by running a completely stock airbox and filter. The inlet snorkel and rubber intake pipe are also OEM and unmodified. The car was tuned using ECUTek on 93 pump gas.
The dyno numbers were achieved with ambient temps in the 75-77F range as verified by the dyno AIT sensor and an external air temp sensor box. Dynoruns for this car are always done in 5th gear (1:1). A stock FR-S/BRZ puts down around 160whp on our dyno. We'll post a dyno sheet tomorrow with a baseline for referencing.
The cams were dialed in to within 5 degrees. I would have gone down to 2-3 degrees, but at 5 degree increments I already found myself having to jump out of the car after each dyno pull to get a close up of the dyno monitor once we were near our target cam setting. BTW, for those that don't know, the high resolution data plotted by a Dyno Dynamics dyno allows you to analyze every pixel that gets plotted on the screen since it does not use a smoothing algorithm to plot a dyno curve.
Since a lot of folks going the NA route autocross and track their cars, we also wanted to test the header to 8k rpms to see if there was still enough usable power on tap to allow you to stay in gear without having to up shift or bounce of the rev limiter. The results were definitely acceptable given that 180whp was still available near 8k.
All in all our 4-1 Race Header performed extremely well and quite honestly, even exceeded our expectations.
- Toan
The Following 8 Users Say Thank You to ptuning For This Useful Post:
Dinko (08-12-2014), JonAvalon (08-12-2014), kanundrum (08-12-2014), lucid215 (08-12-2014), midnight23 (08-12-2014), rb6freak (08-13-2014), SnapOv3st3r (08-12-2014), srizzors25 (08-13-2014)
Old 08-12-2014, 06:18 AM   #33
KenTK808
Drives: White 2014 Scion FRS
Wow! This looks awesome. Please take my money, I would love to be one of the first ones to run this header!
KenTK808 is offline   Reply With Quote
The Following User Says Thank You to KenTK808 For This Useful Post:
Old 08-12-2014, 06:32 AM   #34
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@ptuning do you have the dyno graph showing before and after? I'm keen to see a comparison of the torque and power curves.
Also, do you have a timeline of when you might be offering an OFT map for those who aren't using ecutek?
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Old 08-12-2014, 10:16 AM   #35
EMS Guy
The cynic
Drives: An ambulance
Originally Posted by Mrc@ptuning View Post
We'll try to get some pictures in the next few days. Sorry but we've been busy with the 86Expo East Coast autox and show at our shop all weekend. The header is currently be dyno tested by our tuner and we'll post more pics and dyno results in the days to follow. Hang tight, we didn't forget.
MrC
I guess I will continue to wait....
- Toan
Just so I am clear, you tested this car with bolting on your header and 3" headerback exhaust and gained 40whp according to your dyno with tuning as well?
EMS Guy is offline   Reply With Quote
Old 08-12-2014, 01:10 PM   #36
lucid215
can i exchange my parts that i have now for that exhaust setup haha
lucid215 is offline   Reply With Quote
The Following User Says Thank You to lucid215 For This Useful Post:
Old 08-12-2014, 02:01 PM   #37
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
understandable why you guys dont want to do a catted version but sad also
Digitalanalog is offline   Reply With Quote
Old 08-12-2014, 02:04 PM   #38
ptuning
ptuning's Avatar
Drives: White FR-S
Yes, that is correct.
- Toan
Old 08-12-2014, 02:07 PM   #39
ptuning
ptuning's Avatar
Drives: White FR-S
IMHO, the best way to implement a high flow cat would be on the front pipe.
- Toan
The Following User Says Thank You to ptuning For This Useful Post:
SkAsphalt (08-12-2014)
Old 08-12-2014, 02:29 PM   #40
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Mother of god, it is beautiful.
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 08-12-2014, 02:30 PM   #41
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
- Toan
40 HP gain...your header + 3'' headerback exhaust and tune......Just sick. Absolutely sold. Buying this ASAP
Celigts is offline   Reply With Quote
The Following User Says Thank You to Celigts For This Useful Post:
Old 08-12-2014, 02:33 PM   #42
ptuning
ptuning's Avatar
Drives: White FR-S
Since there will be some folks that are naturally skeptical, given how some manufacturers only seem to post just a single "glory dyno-pull" that no one can ever seem to replicate, we thought we'd post a few more dyno sheets. In all, we made about 35-40+ dyno pulls over 195whp after tuning commenced.
Here are just 27 (3 runs per sheet) more dyno pulls for reference.
Also, WITHOUT a tune, we only managed to put down 173.xxwhp with our full header-back exhaust set-up. Hopefully, this sheds some light on the need to tune with a header. The stock tune is WAY too rich and the cam timing needs to be properly optimized. Below is a stock baseline, PTUNING 4-1 Header and 3" Exhaust with and without dyno tuning.
- Toan
The Following 10 Users Say Thank You to ptuning For This Useful Post:
buddy32 (08-12-2014), Calum (08-12-2014), Fizz (08-14-2014), flippy (08-12-2014), kanundrum (08-12-2014), lucid215 (08-12-2014), mkivsoopra (08-12-2014), Simpleviet (02-18-2015), SnapOv3st3r (08-14-2014), Turdinator (08-12-2014)
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 07:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 09:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 05:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 10:17 PM
