Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-14-2018, 08:10 PM | #15 | |
Okaaaa. I had you placed smack dab in the middle of farm country, in Illinois... humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | danielmailrs (11-15-2018) |
11-15-2018, 12:22 AM | #16 |
Asphalt grinder
Drives: brz
11-15-2018, 12:28 AM | #17 |
Asphalt grinder
Drives: brz
11-15-2018, 04:02 AM | #18 |
6/22/12-2/6/24
I personally found the overflow tank has too much slack in the rubber hose that enters from above. I wrapped the black rubber hose with electrical tape and pushed the hose back into the overflow tank.
Doing this minimized my evaporation - this is not an air tight sealed system and nor should it be. The coolant fill cap still has a hole so pressure won't build up, just minimized evaporation. I used to top off every 3k miles, now I don't remember topping off for +10k miles.
The Following User Says Thank You to Bonburner For This Useful Post: | danielmailrs (11-15-2018) |
11-15-2018, 04:40 AM | #19 |
Asphalt grinder
Drives: brz
Thx mate
Sent from my SM-G960F using Tapatalk |
11-15-2018, 11:03 AM | #20 |
LOLOLOLOLOLOL
Come to a forum and ask "what are the common faults"? This is a minefield. There are guys here that are convinced that every little thing that happened to them is a "common" problem and that all of the cars no matter what year are spontaneously going to explode at any moment in time. If you want to know the true "common" problems just review the list of TSBs and the year ranges that they impact. If not there then the shopping list of various complaints may indeed be an occasional or isolated problem but not a "common" one.
11-15-2018, 12:48 PM | #21 |
Drives: car
Windows freezing stuck in the winter. There is a process for resetting the window switches after they get stuck. You'll know there's a fault if you press the window switch, and they blink back at you.
Wheel stud quality on my '13 was something to find fault with. Stripped 3 of them in one day last year, upgraded to ARP chromoly studs after that because i don't want to strip a stud on a track day etc. Condensation in the tail light. Everybody has this on older models, I think some people have found a fix. Rust forming on the window pillars. Newer models seemed to have fixed it with foam inserts but it might be good to check the corners around windows, perhaps fill gaps with grease. Bumper sag. After removing / reinstalling the bumper you might find the bumper sags a bit. There are some fixes for it but its probably not to everyone's taste. Transmission grinding when cold. I feel like this is pretty common. Usually have to work around it with double clutching, extra revving in neutral, etc. Works for me to do a few neutral revs in the morning after cold-start, then give it a jog around the block to make sure its all in good order before hitting the main road. Clutch throw out bearing. More of an issue on older cars, bearings were packed with improper high-temperature / high load grease, burns itself up. Not sure if '15's have the issue or not. Exhaust bolts seizing. If you're going to get any work done where your installer needs to remove the exhaust pieces, be sure to have a few extra exhaust studs on hand because the mechanic might need to cut through some bolts to get it out. Last edited by radroach; 11-15-2018 at 01:06 PM. |
The Following User Says Thank You to radroach For This Useful Post: | Bonburner (11-15-2018) |
Similar Threads | ||||
How common are 86/frs/brz where you live? | Thet | Scion FR-S / Toyota 86 GT86 General Forum | 107 | 04-09-2015 11:57 AM |
Article: Toyota to recall nearly 6.5 million vehicles for steering, other faults | Taro | Issues | Warranty | Recalls / TSB | 1 | 04-09-2014 11:56 AM |
Common Misconceptions | Pegasus | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-15-2014 11:29 PM |
86 factory faults | Ryan86 | AFRICA | 64 | 03-17-2013 07:47 PM |
electrical faults... | tibsy92 | AUSTRALIA | 22 | 08-19-2012 10:25 PM |
