Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-24-2014, 10:00 PM | #57 |
Drives: WRB BRZ Series.Blue
08-25-2014, 01:20 AM | #58 |
08-25-2014, 08:48 PM | #59 |
Just wanted to report back here with our findings using the OEM 2015 WRX Oil Cooler on our Project BRZ. As suspected it didn't do as much as would be required for us on track however, if you aren't a track junkie and you only see the track 1 or 2x a year it may be a more cost effective option.
Ambient Temp- 78-80 Deg Track- Thompson Motorsports Park Mods- Koyo Radiator, Continental 225-45-17 Slicks, MachV Awesome Wheels, Eibach Prokit Springs, Hawk HP+ Pads, Brake Ducts Coolant Temp Max- 215 Oil Temp Max- 265 This shows us that the Oil-Water cooler is taking out about 10 degrees from the Oil and transferring that into the Coolant. Prior to this we were seeing 195-205 Coolant and 275+ on the oil temps. Hope this helps out some folks. We will update after we get a more robust cooler in. -Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
08-27-2014, 05:43 AM | #60 | |
Lacking brains
Drives: frz
Ive been running an implementation of my own using the gr sti oil cooler plate on a rotorex sced car. I see roughly the generally recognized 10 degree drop, but more importantly much faster recovery times. Especially with the heat on full (side vents out window center closed). In new england (not sweat your balls off hot ambient) im seeing peaks of mid 260 range, typically in the mid 250 range and very quick drops into the 230s and below when letting up. Last week (thompson) by the time the cooldown lap was done my oil temps were into the 220 range pulling into the pit. The oe plates are absolutely not perfect, but they do have a clear positive effect and introduce less risk of hose issues or punctured cores. |
09-06-2014, 01:18 PM | #61 | |
With the Race tires, you are basically WOT all the time in this car so for me those temps get up to their max and just sit there for the entire session. We are currently putting together a setrab setup to hopefully bring these temps down to where we want them 215 even at WOT on the track. -Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
09-06-2014, 07:42 PM | #62 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Assuming you haven't already done so, what's your thinking about going to a heavier-weight oil - is that something you'd do if you're unable to get the temps down to where you want them with a cooler?
09-07-2014, 01:38 PM | #63 | |
When running that hot, I would feel more comfortable running 5w30 or even 5w40 as they will start to thin out at those temps down to a 20 weight anyway. Really though I would not want to see temps above 230 on track, and preferably 215 would be best. -Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
09-07-2014, 01:49 PM | #64 | |
09-07-2014, 02:01 PM | #65 | |
Really you want a cooler to keep the temps down. Keep logs or at least monitor the oil temps. If you only track a few times a year change the oil out before each event and after the event and call it a day coupled with the OEM '15 WRX cooler. -Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
The Following User Says Thank You to AZP Installs For This Useful Post: | dradernh (09-07-2014) |
09-07-2014, 03:14 PM | #66 |
Drives: WR blue
Any feedback on Sard oil cooler?I want to get the setrab oil cooler w mocal. Plate, but I saw someone post a review here shown that the sandwich plate is too tight needed modify to make clearance? Is that been solve yet?
09-07-2014, 04:49 PM | #67 | |
That's an important point re: logging/monitoring of oil temp. That and oil pressure are the first health items I check after a session. I've never gotten a warning light for either, but they still get looked at every time. |
09-07-2014, 10:01 PM | #68 | |
The P3 Cars vent gauge is good in that you get oil temp, coolant temp and can add in 2 analog sensors. We plan to put in an oil pressure gauge so we can constantly monitor that. If you get a low oil pressure light, that means it's triggered the "your engine is going to blow" low oil pressure point. -Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
09-08-2014, 02:00 AM | #69 | |
I've got a mechanical gauge that gets checked on each straight, and a dash that will flash the shift lights at me when (IIRC) the pressure is below 30 psi and the RPMs are over 3K. I haven't had them go off, but if they did and it was safe to do so I'd shut it off, park offline, and hope for the best. |
The Following User Says Thank You to dradernh For This Useful Post: | AZP Installs (09-08-2014) |
09-08-2014, 10:31 PM | #70 |
Has anyone seen the new avo Turbo oil cooler… Looks to be a decent unit with ducting similar to what MikeCSG showed on Rex's car
Similar Threads | ||||
Should I be worried ? | Brooklyn | BRZ First-Gen (2012+) -- General Topics | 8 | 03-12-2014 12:18 PM |
No CEL Should I be worried?? | Mr.Jay | Issues | Warranty | Recalls / TSB | 5 | 04-05-2013 10:51 AM |
a bit worried | MontrealFRS | Issues | Warranty | Recalls / TSB | 7 | 09-14-2012 06:46 PM |
5k oil change, worried about changes.... | bloomy116 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 09-11-2012 08:23 PM |
Anyone worried about not fitting in the car? | budakajana | AUSTRALIA | 35 | 06-27-2012 07:55 AM |
