Software Tuning Discuss all software tuning topics. |
07-30-2018, 10:12 PM | #15 |
Drives: 2013 BRZ Premium
I'm using the RomRaider and ZA1JA01C v4 maps, unfortunately I can't find the last 3 tables and it looks like they are not defined. Any idea how to get to those on my version?
07-31-2018, 12:08 AM | #16 |
Drives: GT86
Load comp B is available in the stock definitions, it just looks different due to scaling (example 1:1 screenshot added). Important for open-loop fuel trims.
Everything left of -1.16 psi is for closed loop, part-throttle only and may vary from car to car. Zero'ing them out is not perfect, but not worse than leaving the stock corrections in. You may correct these much laaaaaaater, after you have verified your maf scale fits. Have not tested the definition, but looks ok in Romraider. Just remove the .txt suffix after downloading. |
07-31-2018, 08:18 PM | #17 |
That definition worked! I know the OFT guys always say to use their definitions but how safe is to use this particular one to modify the V4.03 bin? Don't wanna brick the ECU ...
08-01-2018, 06:14 AM | #18 |
Actually the data in the tables looks right but the parameters are not named correctly. IDK if that has any impact on actual calibration in this case.
08-01-2018, 10:27 AM | #19 |
Drives: GT86
Looks like the description has always been swapped around in the original xml.
I don't believe there's something to worry about. For example the tables in the OFT - guide to dialling in... -thread look similar. I think we would have heard of any problems right now, if there had been anything faulty. |
08-01-2018, 10:13 PM | #20 | |
The Following User Says Thank You to vtekdis For This Useful Post: | Bodalenko (08-20-2018) |
08-02-2018, 08:39 PM | #21 |
Last question ... What is the difference between the Safe and Normal AVCS tables. I can't find any info on when is one used vs the other. Romraider doesn't show any info under Table Properties either. Are you only modifying the Safe tables or both?
08-03-2018, 05:14 AM | #22 |
Drives: brz 2017 hksv2
Safe is used with am >0.7 normal with am between 0.4 and 0.7 or something like that.. Just put them the same
08-03-2018, 05:38 AM | #23 |
Drives: GT86
08-03-2018, 08:51 AM | #24 |
I dont think it uses base table when cold
At idle vvt are always 0,when cold and vvt not enabled vvt stay at 0 too When cold. But vvt enabled it just uses the safe. Table Base is used on particular conditions like limp mode or am less than 0.1 or less than 0.4 |
The Following User Says Thank You to tomm.brz For This Useful Post: | freerunner (08-03-2018) |
08-15-2018, 06:23 PM | #25 |
Here is a run with my new MAF scale:
https://datazap.me/u/bogusbrz/log-15....60&tmax=66.02 Let me know what you think. |
08-15-2018, 08:43 PM | #26 |
Drives: GT86
Looks healthy!
Do you feel any leftover of the torque dip at 3600/3800? PS: that's a smooth maf scale! |
08-16-2018, 07:17 AM | #27 |
It's pretty much gone.
08-16-2018, 07:36 AM | #28 |
Drives: '15 BRZ RA
Tags |
equal length, header, romraider |
Similar Threads | ||||
FS: Innovate I/C supercharger and Nameless header and option of install and tune | Lawnik | Canada Classifieds | 15 | 01-26-2015 11:01 AM |
stg1 custom tune add intake retune =??? | StormTrooper | Engine, Exhaust, Transmission | 11 | 12-23-2013 05:59 PM |
AVO STG1 Turbo Kit New in the Box w/Visconti map sensor upgrade and tune | JMPoole | Engine, Exhaust, Bolt-Ons | 8 | 04-04-2013 04:47 PM |
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! | Visconti | Forced Induction | 67 | 04-03-2013 03:56 PM |
Perrin STG1 tune | Celica00 | Engine, Exhaust, Transmission | 125 | 10-19-2012 11:59 PM |
