06-24-2014, 04:58 PM | #617 |
Turning is for Nerds
Drives: 35 characters is not enough
I'd like to be on this as well
06-24-2014, 06:03 PM | #618 |
Drives: Asphalt FR-S
Going Full exhaust I thought getting a tune was a good idea! I just wanted to make sure.. Sent from my Surface with Windows 8 Pro using Tapatalk
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
06-24-2014, 06:11 PM | #619 |
Any time you plan on changing the factory catalytic converters, a tune will be required. Catback exhausts and aftermarket overpipes will work with the CARB tune, but any modification to those OEM factory catalytic converters will pose a little problem.
06-24-2014, 06:12 PM | #620 |
If you guys would like to place deposits, please PM me.
Final details are not finalized yet, but it'll guarantee you a spot. The AIM Solo DL retails for $699, and is the unit that we've been using the past few years to datalog in FRS and BRZs. In the case if the Jackson Racing kit, it'll give you, in real time: - Manifold pressure (manifold - ambient = boost, up to 20 psi absolute) - Ambient pressure - Ambient temp - Intake charge temp - Engine coolant temp - Engine oil temp - lambda (afr) It does others, but these are the big things that apply to boosted cars. It also logs these parameters. |
The Following User Says Thank You to CSG Mike For This Useful Post: | SuperDave (07-04-2014) |
06-24-2014, 09:11 PM | #621 |
Drives: Fr-S
does anyone know if this can replace the 2 idler pulleys above the tensioner?(between the alternator) thanks again!
http://www.raceseng.com/revo-idler-p...r-s-subaru-brz
"mr.Balloon hands, no way, get real..."
06-25-2014, 02:13 AM | #622 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | bacon_cheese_beer (06-25-2014) |
06-27-2014, 08:47 AM | #623 |
Vtec Jesus
Hummmm
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
The Following User Says Thank You to TouchMyHonda For This Useful Post: | CSG Mike (06-27-2014) |
06-27-2014, 09:12 AM | #624 |
Anyone here tuned by Moto East? If so what was your experience?
06-27-2014, 09:24 AM | #625 |
Track Junkie
Drives: Argento Scion FR-S
A few if us are including myself. I am very satisfied with his tune. I'm considering going with his flex fuel setup since e85 is more readily available here in Houston.
Anyway checking back in from my track event. I now need new brakes. The new found speed has me overheating them in less then a lap lol! |
The Following User Says Thank You to The Slow One For This Useful Post: | CSG Mike (06-27-2014) |
06-27-2014, 12:08 PM | #626 | |
The Following 2 Users Say Thank You to CSG David For This Useful Post: | The Slow One (06-27-2014), Xerious (08-13-2014) |
06-28-2014, 02:08 AM | #627 | |
Drives: BRZ, STI, 535, Tiffin Allegro
I didn't install it but this appears to be an issue with the intake pipe not routing around the washer fluid reservoir well. Did you find a fix? |
06-28-2014, 09:27 AM | #628 |
driving smoother faster
Drives: Sold
Same issue
06-28-2014, 10:01 AM | #629 |
Drives: WRB JR BRZED
I've been too lazy to take off the bumper again.
06-28-2014, 12:02 PM | #630 |
Drives: 2013 Black FR-S
Not necessarily. Everyone gets this issue after removing the bumper a few times. The tabs that hold the bumper flush weaken and don't work after a few reinstalls.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post: | CxG (04-03-2018), Xero-Limit (07-03-2014) |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
