Old 06-15-2016, 03:44 PM   #15
Longjohnstrokems
Drives: Red Scion FR-S
Originally Posted by tofurun View Post
the next question coming at you is gonna be. turn the car off. put the car in 1st gear. start the car with the clutch all the way down (<--obviously LOL) with the car still in first. whats it do? make sure there is nothing in front of u when u do this just incase. does the car sit still (dont hit the brakes) or do you feel it creep or hop when car turn on.
-if it creeps then clutch could be going out/bad/worn clutch fluid leaking Master clutch cylinder going out. alot of time if its leaking or master clutch cylinder then you will lose the pedal ever now and again
No matter what 38k is under 60k warranty so its covered unless ur modded or tuned
No it's still starts normal. I forgot to mention that it actually goes into first gear like butter until the car is warmed up which is why I though the whole thing was odd. Cause once it's warmed up trying to go into first gear is like trying to push through a brick wall
Longjohnstrokems is offline   Reply With Quote
Old 06-15-2016, 04:08 PM   #16
jasonojordan
Drives: 2013 satin white brz limited
Sounds like burnt fluid.
jasonojordan is offline   Reply With Quote
Old 06-15-2016, 04:37 PM   #17
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
If only does it when hot then idk what it would be besides fluid. Try changing trans fluids. Motul 300 75w-90
tofurun is offline   Reply With Quote
Old 06-15-2016, 07:24 PM   #18
humfrz
I'd suggest you bleed the hydrolytic clutch system. There might be air in it.
humfrz
Old 06-15-2016, 11:21 PM   #19
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I have the same issue, but with a aftermarket clutch. Nothing has fixed it.
Replaced the clutch twice, new clutch fork, two new throw out bearings, upgraded clutch lines, bled lines a couple of times, and adjusted the engagement point. I gave up trying to fix it.
I have taken to just shutting off the car to get it in to first when at a stop.
good luck. Hope you find a solution.
clayrush is offline   Reply With Quote
Old 06-15-2016, 11:40 PM   #20
Ultramaroon
義理チョコ
Ultramaroon's Avatar
Clutch friction disk warps after it heats up. Defective part. Take it back to the dealer and show them...
edit: ...before you completely wear down your first gear syncro.
Old 06-16-2016, 12:04 AM   #21
tofurun
tofurun's Avatar
humfrz
Wouldn't he experience a dead clutch off and on, not just in first due to air??
Old 06-16-2016, 01:24 AM   #22
humfrz
Well, that could be.
The OP mentioned that when the car was cold, it went into first gear fine, but not so after the car warmed up.
I was thinking that maybe if there was air in the hydrolytic lines, that the air would take up more space and compress less with a warm car, thus making it harder to get into gear.
humfrz
Old 06-16-2016, 01:28 AM   #23
humfrz
I'd say that your car just doesn't like that clutch ......
humfrz
Old 06-16-2016, 05:02 PM   #24
mad_sb
Drives: 2013 Asphalt FR-S
for sure the clutch is not disengaging fully when you depress the pedal. I went through the exact scenario as the OP right before i replaced the clutch in my old M3. The fingers on the pressure plate were worn and flexing on pedal press not allowing the disk to release all the way.
On flat ground with engine running clutch pedal to the floor, trying to go into first will cause it to roll forward slightly.
Could be the dealer did not replace all the parts (worn pressure plate, just replaced the disk), air in the hydraulic line, warped disk, etc.
Don't waste your time trying to change the trans fluid.
Old 06-16-2016, 05:03 PM   #25
mad_sb
Old 06-17-2016, 12:52 AM   #26
clayrush
humfrz
yeah probably. I was going to just put it back to stock. but my pocketbook is a bit cross with me. And so is the girlfriend.
Old 06-17-2016, 01:50 AM   #27
humfrz
Well, having to take off in 2nd gear will beat the hell out of having a pissed off girlfriend .......
humfrz
Old 06-17-2016, 04:11 AM   #28
TMW
Drives: 2013 Subaru BRZ
do you have any mods?
TMW is offline   Reply With Quote
Search this Thread:
Advanced Search
Balky 1st gear shift ogrowup Scion FR-S / Toyota 86 GT86 General Forum 26 07-31-2015 12:16 PM
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) -- General Topics 31 03-24-2015 01:50 PM
Gear shift 'step'. -Tom- Cosmetic Modification (Interior/Exterior/Lighting) 1 01-05-2015 03:13 PM
brz series.blue gear shift from 1st - 2nd -3rd? iarefluffy Engine, Exhaust, Transmission 0 10-21-2014 04:41 AM
How to Smoothly and Quickly Up-shift from 1st to 2nd Gear? DemonRawr BRZ First-Gen (2012+) -- General Topics 20 10-20-2014 04:51 PM
